From version 7 it is not compatible.
opened 01:08PM - 11 Jun 20 UTC
closed 03:24PM - 16 Mar 21 UTC
enhancement
blocker
verified
integration
prioritised by payment
Please post:
- Feature requests
- Development questions
- Technical questions
### Infos:
* Used Zammad version: 3.3
* Installation method (source, package, ..): any
* Operating system: any
* Database + version: any
* Elasticsearch version: any
* Browser + version: Google Chrome latest
* Ticket-ID: 1076705, 1076758 , 1076759
### Expected behavior:
Authentication against facebook, no matter if using the "add account" functionality for adding a new facebook channel or authentication itself for logging in to Zammad, the process will function successfully.
### Actual behavior:
If enabling API version 7, facebook complains about invalid scopes which are requested by Zammad during autorisation against facebook.
Old scopes are:
* publish_pages
* manage_pages
These scopes are, as far as I can tell, replaced by:
* pages_manage_engagement
* pages_manage_metadata
* pages_manage_posts
If provided with above mentioned permissions, Zammad will function with API version 6.
### Currently working solution:
Don't upgrade facebook Apps to API version 7 (neither for endusers nor developers).
facebook Apps up to API version 6 seems to be working without issues.
*Note: Downgrading developers API version from 7 to 6 is not possible - however, it is for endusers.*
* have a app with required permissions ( `pages_manage_engagement, pages_manage_metadata, pages_manage_posts, email, default` )
* try to authenticate against facebook for either logging in to Zammad or adding a facebook page to the facebook channel
* to double tab you can test this with API version 6 and less and API version 7
* keep in mind that, as soon you upgrade API version to v7 for the developer, there's no way back
Thanks. So this means Zammad cannot be used with Facebook until this ticket is resolved or unless you have an app previous created with a lower version of the API.
Unfortunately, it is not possible to downgrade version
system
Closed
March 3, 2021, 3:40pm
5
