- Used Zammad version: 4.1
- Operating system: Debian 10
- extend Zammad with additional gems
- Error when additional gems in Gemfile.local
# Want to extend Zammad with additional gems?
# ZAMMAD USERS: Specify them in Gemfile.local
# (That way, you can customize the Gemfile
# without having your changes overwritten during upgrades.)
I created the file Gemfile.local and entered gem 'mySpecialGem'
in it
If I now run zammad run rails c
I get the message
You are trying to install in deployment mode after changing
your Gemfile. Run `bundle install` elsewhere and add the
updated Gemfile.lock to version control.
If this is a development machine, remove the /opt/zammad/Gemfile freeze
by running `bundle install --no-deployment`.
The list of sources changed
The dependencies in your gemfile changed
You have added to the Gemfile:
* mySpecialGem
When I run zammad run bundle install --no-deployment
I get the same message
In 4.0 the --no-deployment
option works
How can I add additional gems in 4.1?
