- Used Zammad version: 2.5.x
- Used Zammad installation source: (source, package, …) apt
- Operating system: ubuntu 16.04.4 64 bit
- Browser + version: chrome 67
- show the real client ip
- always uses 127.0.0.1
- install zammad, and log in from the local network (private subnets)
installed everything like the documentation says
nginx conf:
upstream zammad-railsserver {
server localhost:3000;
upstream zammad-websocket {
server localhost:6042;
server {
listen 80;
server_name zammad.int.example.org;
root /opt/zammad/public;
client_max_body_size 50M;
expires max;
location /ws {
proxy_http_version 1.1;
proxy_read_timeout 86400;
location / {
proxy_read_timeout 300;
gzip on;
gzip_proxied any;
in /var/log/nginx/zammad.access.log are the real ip’s, so it seems to be a zammad problem.
