After upgrading to Zammad 4.1 from 3.*, which happened by accident via apt upgrade using Ansible (so no backup), I cannot rebuild the ES index.
I have tried already to:
install ingest-attachment
add the suggested configuration to /etc/elasticsearch/elasticsearch.yml
restart elastic service
run zammad run rake searchindex:rebuild
As a result, the user’s list is not populated on my Zammad instance.
Any suggestions?
Used Zammad version: 4.1
Operating system: Debian 9
$ zammad run rake searchindex:rebuild
drop indexes...done
create indexes...done
create pipeline (pipeline)... done
reload data...
reload Group
- started at 2021-06-22 11:16:47 UTC
4/4
- took 0 seconds
reload Chat::Session
rake aborted!
SystemStackError: stack level too deep
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.6/lib/active_record/coders/yaml_column.rb:26:in `load'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.6/lib/active_record/store.rb:196:in `load'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.6/lib/active_record/type/serialized.rb:22:in `deserialize'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activemodel-5.2.4.6/lib/active_model/attribute.rb:165:in `type_cast'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activemodel-5.2.4.6/lib/active_model/attribute.rb:42:in `value'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activemodel-5.2.4.6/lib/active_model/attribute_set.rb:28:in `transform_values'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activemodel-5.2.4.6/lib/active_model/attribute_set.rb:28:in `to_hash'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.6/lib/active_record/attribute_methods.rb:327:in `attributes'
/opt/zammad/app/models/application_model/can_lookup_search_index_attributes.rb:22:in `search_index_attribute_lookup'
/opt/zammad/app/models/chat/session/search_index.rb:19:in `search_index_attribute_lookup'
/opt/zammad/app/models/application_model/can_lookup_search_index_attributes.rb:81:in `search_index_value_by_attribute'
/opt/zammad/app/models/application_model/can_lookup_search_index_attributes.rb:48:in `block in search_index_attribute_lookup'
/opt/zammad/app/models/application_model/can_lookup_search_index_attributes.rb:23:in `each'
/opt/zammad/app/models/application_model/can_lookup_search_index_attributes.rb:23:in `search_index_attribute_lookup'
/opt/zammad/app/models/chat/session/search_index.rb:29:in `block in search_index_attribute_lookup'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.6/lib/active_record/relation/delegation.rb:71:in `each'
/opt/zammad/app/models/chat/session/search_index.rb:26:in `search_index_attribute_lookup'
[.... the same repeats too many times and eventually ....]
/opt/zammad/app/models/concerns/has_search_index_backend.rb:177:in `search_index_update_backend'
/opt/zammad/app/models/concerns/has_search_index_backend.rb:226:in `block (2 levels) in search_index_reload'
/opt/zammad/app/models/concerns/has_search_index_backend.rb:222:in `each'
/opt/zammad/app/models/concerns/has_search_index_backend.rb:222:in `block in search_index_reload'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.6/lib/active_record/relation/batches.rb:136:in `block in find_in_batches'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.6/lib/active_record/relation/batches.rb:238:in `block in in_batches'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.6/lib/active_record/relation/batches.rb:222:in `loop'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.6/lib/active_record/relation/batches.rb:222:in `in_batches'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.6/lib/active_record/relation/batches.rb:135:in `find_in_batches'
/opt/zammad/app/models/concerns/has_search_index_backend.rb:221:in `with_index'
/opt/zammad/app/models/concerns/has_search_index_backend.rb:221:in `search_index_reload'
/opt/zammad/lib/tasks/search_index_es.rake:48:in `block (3 levels) in <main>'
/opt/zammad/lib/tasks/search_index_es.rake:44:in `each'
/opt/zammad/lib/tasks/search_index_es.rake:44:in `block (2 levels) in <main>'
/opt/zammad/lib/tasks/search_index_es.rake:63:in `block (2 levels) in <main>'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/rake-12.3.3/exe/rake:27:in `<top (required)>'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/cli/exec.rb:74:in `load'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/cli/exec.rb:74:in `kernel_load'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/cli/exec.rb:28:in `run'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/cli.rb:463:in `exec'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/vendor/thor/lib/thor/command.rb:27:in `run'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/vendor/thor/lib/thor/invocation.rb:126:in `invoke_command'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/vendor/thor/lib/thor.rb:387:in `dispatch'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/cli.rb:27:in `dispatch'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/vendor/thor/lib/thor/base.rb:466:in `start'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/cli.rb:18:in `start'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/exe/bundle:30:in `block in <top (required)>'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/friendly_errors.rb:124:in `with_friendly_errors'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/exe/bundle:22:in `<top (required)>'
Not sure how to reproduce
itkfm
June 22, 2021, 12:43pm
#2
Similar thing going on here. Don’t know whether there were any updates in before, all I know, updating to the latest available version via apt did not fix it.
** Execute environment
** Invoke searchindex:configured (first_time)
** Execute searchindex:configured
** Execute searchindex:rebuild
** Execute searchindex:drop
** Execute searchindex:drop_pipeline
** Execute searchindex:create
** Execute searchindex:create_pipeline
** Execute searchindex:reload
rake aborted!
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/arel-9.0.0/lib/arel/visitors/to_sql.rb:822:in `block in inject_join'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/arel-9.0.0/lib/arel/visitors/to_sql.rb:820:in `each'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/arel-9.0.0/lib/arel/visitors/to_sql.rb:820:in `each_with_index'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/arel-9.0.0/lib/arel/visitors/to_sql.rb:820:in `inject'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/arel-9.0.0/lib/arel/visitors/to_sql.rb:820:in `inject_join'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/arel-9.0.0/lib/arel/visitors/to_sql.rb:639:in `visit_Arel_Nodes_And'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/arel-9.0.0/lib/arel/visitors/reduce.rb:15:in `visit'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/arel-9.0.0/lib/arel/visitors/to_sql.rb:601:in `visit_Arel_Nodes_On'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/arel-9.0.0/lib/arel/visitors/to_sql.rb:593:in `visit_Arel_Nodes_InnerJoin'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/arel-9.0.0/lib/arel/visitors/to_sql.rb:824:in `block in inject_join'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/arel-9.0.0/lib/arel/visitors/to_sql.rb:550:in `visit_Arel_Nodes_JoinSource'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/arel-9.0.0/lib/arel/visitors/to_sql.rb:251:in `visit_Arel_Nodes_SelectCore'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/arel-9.0.0/lib/arel/visitors/to_sql.rb:217:in `block in visit_Arel_Nodes_SelectStatement'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/arel-9.0.0/lib/arel/visitors/to_sql.rb:216:in `each'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/arel-9.0.0/lib/arel/visitors/to_sql.rb:216:in `inject'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/arel-9.0.0/lib/arel/visitors/to_sql.rb:216:in `visit_Arel_Nodes_SelectStatement'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/arel-9.0.0/lib/arel/visitors/reduce.rb:8:in `accept'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.6/lib/active_record/connection_adapters/determine_if_preparable_visitor.rb:10:in `accept'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.6/lib/active_record/connection_adapters/abstract/database_statements.rb:25:in `to_sql_and_binds'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.6/lib/active_record/connection_adapters/abstract/database_statements.rb:61:in `select_all'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.6/lib/active_record/connection_adapters/abstract/query_cache.rb:106:in `select_all'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.6/lib/active_record/relation/calculations.rb:197:in `block in pluck'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.6/lib/active_record/relation.rb:584:in `skip_query_cache_if_necessary'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.6/lib/active_record/relation/calculations.rb:197:in `pluck'
/opt/zammad/app/models/tag.rb:153:in `tag_list'
/opt/zammad/app/models/concerns/has_tags.rb:55:in `tag_list'
/opt/zammad/app/models/chat/session/search_index.rb:22:in `search_index_attribute_lookup'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/rake-12.3.3/lib/rake/task.rb:273:in `block in execute'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/rake-12.3.3/lib/rake/task.rb:273:in `each'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/rake-12.3.3/lib/rake/task.rb:273:in `execute'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/rake-12.3.3/lib/rake/task.rb:214:in `block in invoke_with_call_chain'
/opt/zammad/vendor/ruby-2.6.6/lib/ruby/2.6.0/monitor.rb:235:in `mon_synchronize'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/rake-12.3.3/lib/rake/task.rb:194:in `invoke_with_call_chain'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/rake-12.3.3/lib/rake/task.rb:183:in `invoke'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/rake-12.3.3/lib/rake/application.rb:160:in `invoke_task'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/rake-12.3.3/lib/rake/application.rb:116:in `block (2 levels) in top_level'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/rake-12.3.3/lib/rake/application.rb:116:in `each'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/rake-12.3.3/lib/rake/application.rb:116:in `block in top_level'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/rake-12.3.3/lib/rake/application.rb:125:in `run_with_threads'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/rake-12.3.3/lib/rake/application.rb:110:in `top_level'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/rake-12.3.3/lib/rake/application.rb:83:in `block in run'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/rake-12.3.3/lib/rake/application.rb:186:in `standard_exception_handling'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/rake-12.3.3/lib/rake/application.rb:80:in `run'
/opt/zammad/vendor/bundle/ruby/2.6.0/bin/rake:23:in `load'
/opt/zammad/vendor/bundle/ruby/2.6.0/bin/rake:23:in `<top (required)>'
OS: Debian 10 (4.19.0-17-amd64 #1 SMP Debian 4.19.194-1 (2021-06-10) x86_64)
ES: elasticsearch/stable,now 7.13.2 amd64
(from https://artifacts.elastic.co/packages/7.x/apt
SSH into our vServer
You may have been affected by this bug:
opened 10:37AM - 24 Jun 21 UTC
closed 03:41PM - 24 Jun 21 UTC
bug
chat
prioritised by payment
verified
Please post:
- Feature requests
- Development questions
- Technical questions
### Infos:
* Used Zammad version: zammad.x86_64 0:4.1.0-1623318856.fa8592c0.centos7
* Installation method (source, package, ..): Package (RPM with yum)
* Operating system: CentOS 7.4
* Database + version: psql (PostgreSQL) 13.3
* Elasticsearch version: 7.13.2
* Browser + version: Chromium 91.0.4472.114
* Ticket: #1088629
### Expected behavior:
* When Zammad was updated the reindexing should still work.
### Actual behavior:
* The rebuild of the index is failing, after it was updated to version zammad.x86_64 0:4.1.0-1624523276.7163a88f.centos7.
(it was zammad.x86_64 0:4.1.0-1623318856.fa8592c0.centos7 before)
* Check behavior before Update:
drop indexes...done
reload data...
- started at 2021-06-24 09:57:46 UTC
67/67
- took 1 seconds
reload Cti::Log
- started at 2021-06-24 09:57:48 UTC
- took 0 seconds
reload KnowledgeBase::Answer::Translation
67/67
- took 6 seconds
reload KnowledgeBase::Category::Translation
- started at 2021-06-24 09:57:54 UTC
36/36
- took 0 seconds
reload KnowledgeBase::Translation
- started at 2021-06-24 09:57:55 UTC
1/1
- took 0 seconds
reload Ticket::Priority
3/3
- took 0 seconds
reload Ticket::State
7/7
- took 0 seconds
reload Group
6/6
- took 0 seconds
reload Organization
26/26
- took 0 seconds
reload StatsStore
- started at 2021-06-24 09:57:56 UTC
81/81
- took 1 seconds
reload Ticket
- started at 2021-06-24 09:57:57 UTC
100/2248
200/2248
300/2248
400/2248
500/2248
600/2248
700/2248
800/2248
900/2248
1000/2248
1100/2248
1200/2248
1300/2248
1400/2248
1500/2248
1600/2248
1700/2248
1800/2248
1900/2248
2000/2248
2100/2248
2200/2248
2248/2248
- took 156 seconds
reload User
- started at 2021-06-24 10:00:34 UTC
100/556
200/556
300/556
400/556
500/556
556/556
- took 6 seconds
* then Upgrade:
> yum update zammad
yum update zammad Geladene Plugins: fastestmirror, langpacks
Loading mirror speeds from cached hostfile
epel/x86_64/metalink | 34 kB 00:00:00
* base: mirror.fra10.de.leaseweb.net
* epel: ftp-stud.hs-esslingen.de
* extras: ftp.rz.uni-frankfurt.de
* updates: centos.mirror.net-d-sign.de
base | 3.6 kB 00:00:00
elasticsearch-7.x | 1.3 kB 00:00:00
epel | 4.7 kB 00:00:00
extras | 2.9 kB 00:00:00
updates | 2.9 kB 00:00:00
zammad/x86_64/signature | 473 B 00:00:00
zammad/x86_64/signature | 1.3 kB 00:00:00
(1/4): epel/x86_64/updateinfo | 1.0 MB 00:00:00
(2/4): epel/x86_64/primary_db | 6.9 MB 00:00:00
(3/4): zammad/x86_64/primary | 8.0 MB 00:00:01 ETA
(4/4): zammad/x86_64/primary | 45 kB 00:00:00
zammad: [ ] 1/157
zammad: [############################################################################################## ] 156/157
zammad 157/157
Abhängigkeiten werden aufgelöst
--> Transaktionsprüfung wird ausgeführt
---> Paket zammad.x86_64 0:4.1.0-1623318856.fa8592c0.centos7 markiert, um aktualisiert zu werden
---> Paket zammad.x86_64 0:4.1.0-1624523276.7163a88f.centos7 markiert, um eine Aktualisierung zu werden
--> Abhängigkeitsauflösung beendet
Abhängigkeiten aufgelöst
Package Arch Version Paketquelle Größe
Aktualisieren:
zammad x86_64 4.1.0-1624523276.7163a88f.centos7 zammad 122 M
Transaktionsübersicht
Aktualisieren 1 Paket
Gesamte Downloadgröße: 122 M
Is this ok [y/d/N]: y
Downloading packages:
No Presto metadata available for zammad
zammad-4.1.0-1624523276.7163a88f.centos7.x 0% [ ] 0.0 B/s | 0 B --:--:-- ETA
zammad-4.1.0-1624523276.7163a88f.centos7.x86_64.rpm | 122 MB 00:00:03
Running transaction check
Running transaction test
Transaction test succeeded
Running transaction
Aktualisieren : zammad-4.1.0-1624523276.7163a88f.centos7.x [ ] 1/2
Aktualisieren : zammad-4.1.0-1624523276.7163a88f.centos7.x [########################################## ] 1/2
Aktualisieren : zammad-4.1.0-1624523276.7163a88f.centos7.x86_64 1/2
# (Re)creating init scripts
Nothing to do.
Nothing to do.
Nothing to do.
# Enabling Zammad on boot
# Stopping Zammad
== 20210617051913 Issue3618GoogleCalendarUrlHttps: migrating ==================
== 20210617051913 Issue3618GoogleCalendarUrlHttps: migrated (0.0040s) =========
# Updating translations...
-> removing [ingest-attachment]...
-> Installing ingest-attachment
-> Downloading ingest-attachment from elastic
[ ] 1%Â Â
[=================================================] 100%Â Â
@ WARNING: plugin requires additional permissions @
* java.lang.RuntimePermission accessClassInPackage.sun.java2d.cmm.kcms
* java.lang.RuntimePermission accessDeclaredMembers
* java.lang.RuntimePermission getClassLoader
* java.lang.reflect.ReflectPermission suppressAccessChecks
* java.security.SecurityPermission createAccessControlContext
See http://docs.oracle.com/javase/8/docs/technotes/guides/security/permissions.html
for descriptions of what these permissions allow and the associated risks.
-> Installed ingest-attachment
-> Please restart Elasticsearch to activate any plugins installed
# Starting Zammad
# Restarting webserver nginx
/etc/nginx/conf.d/zammad.conf and restart nginx process.
Remember to enable selinux and firewall rules!
Use the following commands:
setsebool httpd_can_network_connect on -P
firewall-cmd --zone=public --add-service=http --permanent
firewall-cmd --zone=public --add-service=https --permanent
firewall-cmd --reload
Aufräumen : zammad-4.1.0-1623318856.fa8592c0.centos7.x86_64 2/2
Überprüfung läuft: zammad-4.1.0-1624523276.7163a88f.centos7.x86_64 1/2
Überprüfung läuft: zammad-4.1.0-1623318856.fa8592c0.centos7.x86_64 2/2
Aktualisiert:
Komplett!
yum update zammad 64,30s user 9,01s system 38% cpu 3:08,97 total
> systemctl restart elasticsearch.service
* And finally try to reindex again:
[bug.txt](https://github.com/zammad/zammad/files/6708453/bug.txt)
Update to the latest available stable Zammad version to fix it and try again.
system
closed
November 13, 2021, 12:27pm
#4
