- Used Zammad version:
4.1.0-1630076259.40e648b8.focal amd64 - Used Zammad installation type: (source, package, docker-compose, …)
Package - Operating system:
Ubuntu 20.04.2 - Browser + version:
Google Chrome 92.0.4515.159
I’ve backuped a Zammad instance from a host and would like to restore it now on another device.
Everythings goin’ good until the restore script is clearing the cache in the end. Then it throws this error:
66: from bin/rails:9:in `<main>'
65: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.4.5/lib/active_support/dependencies.rb:291:in `require'
64: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.4.5/lib/active_support/dependencies.rb:257:in `load_dependency'
63: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.4.5/lib/active_support/dependencies.rb:291:in `block in require'
62: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.3.2/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:29:in `require'
61: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.3.2/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:20:in `require_with_bootsnap_lfi'
60: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.3.2/lib/bootsnap/load_path_cache/loaded_features_index.rb:65:in `register'
59: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.3.2/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:21:in `block in require_with_bootsnap_lfi'
58: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.3.2/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:21:in `require'
57: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/railties-5.2.4.5/lib/rails/commands.rb:18:in `<main>'
56: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/railties-5.2.4.5/lib/rails/command.rb:46:in `invoke'
55: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/railties-5.2.4.5/lib/rails/command/base.rb:69:in `perform'
54: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/thor-1.1.0/lib/thor.rb:392:in `dispatch'
53: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/thor-1.1.0/lib/thor/invocation.rb:127:in `invoke_command'
52: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/thor-1.1.0/lib/thor/command.rb:27:in `run'
51: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/railties-5.2.4.5/lib/rails/commands/runner/runner_command.rb:29:in `perform'
50: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/railties-5.2.4.5/lib/rails/command/actions.rb:15:in `require_application_and_environment!'
49: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/railties-5.2.4.5/lib/rails/command/actions.rb:28:in `require_environment!'
48: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/railties-5.2.4.5/lib/rails/application.rb:337:in `require_environment!'
47: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.4.5/lib/active_support/dependencies.rb:291:in `require'
46: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.4.5/lib/active_support/dependencies.rb:257:in `load_dependency'
45: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.4.5/lib/active_support/dependencies.rb:291:in `block in require'
44: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.3.2/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:29:in `require'
43: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.3.2/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:20:in `require_with_bootsnap_lfi'
42: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.3.2/lib/bootsnap/load_path_cache/loaded_features_index.rb:65:in `register'
41: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.3.2/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:21:in `block in require_with_bootsnap_lfi'
40: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.3.2/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:21:in `require'
39: from /opt/zammad/config/environment.rb:5:in `<main>'
38: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/railties-5.2.4.5/lib/rails/application.rb:361:in `initialize!'
37: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/railties-5.2.4.5/lib/rails/initializable.rb:60:in `run_initializers'
36: from /opt/zammad/vendor/ruby-2.6.6/lib/ruby/2.6.0/tsort.rb:205:in `tsort_each'
35: from /opt/zammad/vendor/ruby-2.6.6/lib/ruby/2.6.0/tsort.rb:226:in `tsort_each'
34: from /opt/zammad/vendor/ruby-2.6.6/lib/ruby/2.6.0/tsort.rb:347:in `each_strongly_connected_component'
33: from /opt/zammad/vendor/ruby-2.6.6/lib/ruby/2.6.0/tsort.rb:347:in `call'
32: from /opt/zammad/vendor/ruby-2.6.6/lib/ruby/2.6.0/tsort.rb:347:in `each'
31: from /opt/zammad/vendor/ruby-2.6.6/lib/ruby/2.6.0/tsort.rb:349:in `block in each_strongly_connected_component'
30: from /opt/zammad/vendor/ruby-2.6.6/lib/ruby/2.6.0/tsort.rb:431:in `each_strongly_connected_component_from'
29: from /opt/zammad/vendor/ruby-2.6.6/lib/ruby/2.6.0/tsort.rb:350:in `block (2 levels) in each_strongly_connected_component'
28: from /opt/zammad/vendor/ruby-2.6.6/lib/ruby/2.6.0/tsort.rb:228:in `block in tsort_each'
27: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/railties-5.2.4.5/lib/rails/initializable.rb:61:in `block in run_initializers'
26: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/railties-5.2.4.5/lib/rails/initializable.rb:32:in `run'
25: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/railties-5.2.4.5/lib/rails/initializable.rb:32:in `instance_exec'
24: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/railties-5.2.4.5/lib/rails/application/finisher.rb:69:in `block in <module:Finisher>'
23: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/railties-5.2.4.5/lib/rails/application/finisher.rb:69:in `each'
22: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/railties-5.2.4.5/lib/rails/engine.rb:356:in `eager_load!'
21: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/railties-5.2.4.5/lib/rails/engine.rb:475:in `eager_load!'
20: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/railties-5.2.4.5/lib/rails/engine.rb:475:in `each'
19: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/railties-5.2.4.5/lib/rails/engine.rb:477:in `block in eager_load!'
18: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/railties-5.2.4.5/lib/rails/engine.rb:477:in `each'
17: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/railties-5.2.4.5/lib/rails/engine.rb:478:in `block (2 levels) in eager_load!'
16: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.4.5/lib/active_support/dependencies.rb:246:in `require_dependency'
15: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.3.2/lib/bootsnap/load_path_cache/core_ext/active_support.rb:80:in `depend_on'
14: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.4.5/lib/active_support/dependencies.rb:334:in `depend_on'
13: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.3.2/lib/bootsnap/load_path_cache/core_ext/active_support.rb:45:in `require_or_load'
12: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.3.2/lib/bootsnap/load_path_cache/core_ext/active_support.rb:16:in `allow_bootsnap_retry'
11: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.3.2/lib/bootsnap/load_path_cache/core_ext/active_support.rb:46:in `block in require_or_load'
10: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.4.5/lib/active_support/dependencies.rb:356:in `require_or_load'
9: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.4.5/lib/active_support/dependencies.rb:37:in `load_interlock'
8: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.4.5/lib/active_support/dependencies/interlock.rb:13:in `loading'
7: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.4.5/lib/active_support/concurrency/share_lock.rb:151:in `exclusive'
6: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.4.5/lib/active_support/dependencies/interlock.rb:14:in `block in loading'
5: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.4.5/lib/active_support/dependencies.rb:37:in `block in load_interlock'
4: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.4.5/lib/active_support/dependencies.rb:378:in `block in require_or_load'
3: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.4.5/lib/active_support/dependencies.rb:291:in `require'
2: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.4.5/lib/active_support/dependencies.rb:257:in `load_dependency'
1: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.4.5/lib/active_support/dependencies.rb:291:in `block in require'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.3.2/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:32:in `require': No such file to load -- observer/chat/leave/background_job.rb (LoadError)
62: from bin/rails:9:in `<main>'
61: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.3.2/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:29:in `require'
60: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.3.2/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:20:in `require_with_bootsnap_lfi'
59: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.3.2/lib/bootsnap/load_path_cache/loaded_features_index.rb:65:in `register'
58: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.3.2/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:21:in `block in require_with_bootsnap_lfi'
57: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.3.2/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:21:in `require'
56: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/railties-5.2.4.5/lib/rails/commands.rb:18:in `<main>'
55: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/railties-5.2.4.5/lib/rails/command.rb:46:in `invoke'
54: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/railties-5.2.4.5/lib/rails/command/base.rb:69:in `perform'
53: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/thor-1.1.0/lib/thor.rb:392:in `dispatch'
52: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/thor-1.1.0/lib/thor/invocation.rb:127:in `invoke_command'
51: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/thor-1.1.0/lib/thor/command.rb:27:in `run'
50: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/railties-5.2.4.5/lib/rails/commands/runner/runner_command.rb:29:in `perform'
49: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/railties-5.2.4.5/lib/rails/command/actions.rb:15:in `require_application_and_environment!'
48: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/railties-5.2.4.5/lib/rails/command/actions.rb:28:in `require_environment!'
47: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/railties-5.2.4.5/lib/rails/application.rb:337:in `require_environment!'
46: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.3.2/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:29:in `require'
45: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.3.2/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:20:in `require_with_bootsnap_lfi'
44: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.3.2/lib/bootsnap/load_path_cache/loaded_features_index.rb:65:in `register'
43: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.3.2/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:21:in `block in require_with_bootsnap_lfi'
42: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.3.2/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:21:in `require'
41: from /opt/zammad/config/environment.rb:5:in `<main>'
40: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/railties-5.2.4.5/lib/rails/application.rb:361:in `initialize!'
39: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/railties-5.2.4.5/lib/rails/initializable.rb:60:in `run_initializers'
38: from /opt/zammad/vendor/ruby-2.6.6/lib/ruby/2.6.0/tsort.rb:205:in `tsort_each'
37: from /opt/zammad/vendor/ruby-2.6.6/lib/ruby/2.6.0/tsort.rb:226:in `tsort_each'
36: from /opt/zammad/vendor/ruby-2.6.6/lib/ruby/2.6.0/tsort.rb:347:in `each_strongly_connected_component'
35: from /opt/zammad/vendor/ruby-2.6.6/lib/ruby/2.6.0/tsort.rb:347:in `call'
34: from /opt/zammad/vendor/ruby-2.6.6/lib/ruby/2.6.0/tsort.rb:347:in `each'
33: from /opt/zammad/vendor/ruby-2.6.6/lib/ruby/2.6.0/tsort.rb:349:in `block in each_strongly_connected_component'
32: from /opt/zammad/vendor/ruby-2.6.6/lib/ruby/2.6.0/tsort.rb:431:in `each_strongly_connected_component_from'
31: from /opt/zammad/vendor/ruby-2.6.6/lib/ruby/2.6.0/tsort.rb:350:in `block (2 levels) in each_strongly_connected_component'
30: from /opt/zammad/vendor/ruby-2.6.6/lib/ruby/2.6.0/tsort.rb:228:in `block in tsort_each'
29: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/railties-5.2.4.5/lib/rails/initializable.rb:61:in `block in run_initializers'
28: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/railties-5.2.4.5/lib/rails/initializable.rb:32:in `run'
27: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/railties-5.2.4.5/lib/rails/initializable.rb:32:in `instance_exec'
26: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/railties-5.2.4.5/lib/rails/application/finisher.rb:69:in `block in <module:Finisher>'
25: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/railties-5.2.4.5/lib/rails/application/finisher.rb:69:in `each'
24: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/railties-5.2.4.5/lib/rails/engine.rb:356:in `eager_load!'
23: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/railties-5.2.4.5/lib/rails/engine.rb:475:in `eager_load!'
22: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/railties-5.2.4.5/lib/rails/engine.rb:475:in `each'
21: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/railties-5.2.4.5/lib/rails/engine.rb:477:in `block in eager_load!'
20: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/railties-5.2.4.5/lib/rails/engine.rb:477:in `each'
19: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/railties-5.2.4.5/lib/rails/engine.rb:478:in `block (2 levels) in eager_load!'
18: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.3.2/lib/bootsnap/load_path_cache/core_ext/active_support.rb:79:in `depend_on'
17: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.3.2/lib/bootsnap/load_path_cache/core_ext/active_support.rb:84:in `rescue in depend_on'
16: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.3.2/lib/bootsnap/load_path_cache/core_ext/active_support.rb:8:in `without_bootsnap_cache'
15: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.3.2/lib/bootsnap/load_path_cache/core_ext/active_support.rb:84:in `block in depend_on'
14: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.3.2/lib/bootsnap/load_path_cache/core_ext/active_support.rb:45:in `require_or_load'
13: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.3.2/lib/bootsnap/load_path_cache/core_ext/active_support.rb:16:in `allow_bootsnap_retry'
12: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.3.2/lib/bootsnap/load_path_cache/core_ext/active_support.rb:46:in `block in require_or_load'
11: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.4.5/lib/active_support/dependencies/interlock.rb:13:in `loading'
10: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.4.5/lib/active_support/concurrency/share_lock.rb:151:in `exclusive'
9: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.4.5/lib/active_support/dependencies/interlock.rb:14:in `block in loading'
8: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.3.2/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:29:in `require'
7: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.3.2/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:20:in `require_with_bootsnap_lfi'
6: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.3.2/lib/bootsnap/load_path_cache/loaded_features_index.rb:65:in `register'
5: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.3.2/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:21:in `block in require_with_bootsnap_lfi'
4: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.3.2/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:21:in `require'
3: from /opt/zammad/app/models/observer/chat/leave/background_job.rb:1:in `<main>'
2: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.3.2/lib/bootsnap/load_path_cache/core_ext/active_support.rb:57:in `load_missing_constant'
1: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.3.2/lib/bootsnap/load_path_cache/core_ext/active_support.rb:16:in `allow_bootsnap_retry'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.3.2/lib/bootsnap/load_path_cache/core_ext/active_support.rb:58:in `block in load_missing_constant': uninitialized constant Observer (NameError)
- Afterwards it says that everything has been restored successfully, but I’m getting a 502 Error in the browser. Is there anything I forgot? I’ve already moved and restored this instance to another device half a year ago, it did work back then.
- Install Zammad from package and try to restore a backup. In my case it throws that error.
