- Used Zammad version: 6.3.0-1713527245.bf4df2a1.jammy
- Operating system: Ubuntu 22.04 LTS
- Browser + version: Reproduceable on all Browsers (64-bit)
- Registering new account, entering the info, and pressing ‘Create My Account’ should create the account.
- Status Code 500
- Error ID xyz (not these, but a series of letters specific to my installation)
- Attempt to Register to create an account
or - (As an admin) create an account for the user and attempt to login
After reading some other topics here, trying to find someone with an issue like mine, I did learn to check my production.log,
- I setup Zammad to use my own email server for the initial email channel (notification).
When I entered in the settings for the email account I wanted Zammad to use, helpdesk@mydomainname.net, I got the green light, which seemed to indicate to me my settings are correct.
The only user I’ve ever logged in was the initial admin user when I first setup Zammad a few days ago. I’ve not logged that user out yet until I could work through the issues I’ve had.
Using the initial admin account, I created a user as an Agent with an email.
The account seems to create just find, but I kept running into errors trying to log the user in.
So I decided to try to Register as a new customer.
Upon entering all the necessary info, I get the Status Code 500 and the Error ID message.
Checking the production log, I can see where it fails, but do not fully understand it.
I, [2024-04-26T00:31:52.049490#2073-148640] INFO -- : Running job thread for 'Generate 'Session' data.' (Sessions.jobs) status is: sleep
I, [2024-04-26T00:31:52.049570#2073-148640] INFO -- : Running job thread for 'Execute planned jobs.' (Job.run) status is: sleep
I, [2024-04-26T00:31:53.020801#2067-930140] INFO -- : Completed 200 OK in 25069ms (Views: 0.3ms | ActiveRecord: 3.9ms | Allocations: 150866)
I, [2024-04-26T00:31:53.138892#2067-930140] INFO -- : Started POST "/api/v1/message_receive" for 192.168.1.16 at 2024-04-26 00:31:53 +0000
I, [2024-04-26T00:31:53.146411#2067-930140] INFO -- : Processing by LongPollingController#message_receive as JSON
I, [2024-04-26T00:31:53.146477#2067-930140] INFO -- : Parameters: {"client_id"=>"992e35c7-f93e-442f-bbd8-b7787b28b3f2"}
I, [2024-04-26T00:31:55.713564#2067-4615040] INFO -- : Started POST "/api/v1/users" for 192.168.1.16 at 2024-04-26 00:31:55 +0000
I, [2024-04-26T00:31:55.719787#2067-4615040] INFO -- : Processing by UsersController#create as JSON
I, [2024-04-26T00:31:55.719869#2067-4615040] INFO -- : Parameters: {"login"=>"anotheremail@yahoo.com", "firstname"=>"Dave", "lastname"=>"Bob", "email"=>"anotheremail@yahoo.com", "password"=>"[FILTERED]", "role_ids"=>[], "signup"=>tr ue, "id"=>"c-0"}
I, [2024-04-26T00:31:57.735620#2073-148700] INFO -- : 2024-04-26T00:31:57+0000: [Worker(host:help pid:2073)] Job AvatarCreateJob [c959c751-6af4-4f1f-9928-a74929b677a0] from DelayedJob(default) with arguments: [{"_aj_globalid"=>"gid://za mmad/User/8"}] (id=18418) (queue=default) RUNNING
E, [2024-04-26T00:31:58.065427#2067-4615040] ERROR -- : Can't use Channel::Driver::Smtp: #<Net::SMTPFatalError: Net::SMTPFatalError>
E, [2024-04-26T00:31:58.065528#2067-4615040] ERROR -- : 554 5.7.1 <anotheremail@yahoo.com>: Recipient address rejected: Sender is not same as SMTP authenticate username
(Net::SMTPFatalError)
app/models/channel/driver/smtp.rb:98:in `deliver'
app/models/channel.rb:263:in `deliver'
lib/notification_factory/mailer.rb:172:in `deliver'
lib/notification_factory/mailer.rb:225:in `notification'
app/services/service/user/signup.rb:39:in `execute'
app/controllers/users_controller.rb:1024:in `create_signup'
app/controllers/users_controller.rb:98:in `create'
app/controllers/application_controller/has_download.rb:17:in `block (4 levels) in <module:HasDownload>'
app/controllers/application_controller/has_download.rb:16:in `block (3 levels) in <module:HasDownload>'
app/controllers/application_controller/has_download.rb:15:in `block (2 levels) in <module:HasDownload>'
E, [2024-04-26T00:31:58.082588#2067-4615040] ERROR -- : Can't use Channel::Driver::Smtp: #<Net::SMTPFatalError: Net::SMTPFatalError> (Channel::DeliveryError)
app/models/channel.rb:289:in `handle_delivery_error!'
app/models/channel.rb:270:in `rescue in deliver'
app/models/channel.rb:251:in `deliver'
E, [2024-04-26T00:31:58.084109#2067-4615040] ERROR -- : Error ID bTgia3w-: Can't use Channel::Driver::Smtp: #<Net::SMTPFatalError: Net::SMTPFatalError>
I, [2024-04-26T00:31:58.084370#2067-4615040] INFO -- : Completed 500 Internal Server Error in 2364ms (Views: 0.1ms | ActiveRecord: 34.8ms | Allocations: 26524)
I, [2024-04-26T00:31:58.167638#2067-930140] INFO -- : Completed 200 OK in 5021ms (Views: 3.6ms | ActiveRecord: 3.6ms | Allocations: 39777)
I, [2024-04-26T00:31:58.399710#2073-148700] INFO -- : Can't fetch image for 'wolfgang28612@yahoo.com' (maybe no avatar available), http code: 404
I, [2024-04-26T00:31:58.418320#2073-148700] INFO -- : 2024-04-26T00:31:58+0000: [Worker(host:help pid:2073)] Job AvatarCreateJob [c959c751-6af4-4f1f-9928-a74929b677a0] from DelayedJob(default) with arguments: [{"_aj_globalid"=>"gid://za mmad/User/8"}] (id=18418) (queue=default) COMPLETED after 0.6826
I, [2024-04-26T00:31:58.501512#2067-930060] INFO -- : Started POST "/api/v1/message_receive" for 192.168.1.16 at 2024-04-26 00:31:58 +0000
I, [2024-04-26T00:31:58.506830#2067-930060] INFO -- : Processing by LongPollingController#message_receive as JSON
I, [2024-04-26T00:31:58.506894#2067-930060] INFO -- : Parameters: {"client_id"=>"992e35c7-f93e-442f-bbd8-b7787b28b3f2"}
In this copied text above, I used a yahoo email I have, but previously, I used other emails from the same domain I have zammad’s notification email channel setup on.
The first visible error above seems to say, "Can’t use Channel::Driver::Smtp: #<Net::SMTPFatalError: Net::SMTPFatalError>
Not sure if that means I can’t use the default notification channel as the email channel for account creation?
I believe subsequent errors are part of a domino effect starting at this error.
Thanks to anyone who has any insight on this.
