- Used Zammad version: 5.2.3
- Operating system: Debian (Server), Windows 10 (Client)
- Browser + version: Google Chrome Version 101.0.4951.67 (Official Build) (64-bit)
Creating a ticket with a simple template modificated from the one found here:
https://docs.zammad.org/en/latest/api/ticket/index.html#create
Using Python requests to post it. It does not work, I tried using Postman and it worked properly so I suppose the payload is correct.
I receive 500 response with the following reason:
{“error”:“no implicit conversion of Symbol into Integer”}
Here is the complete python script to create the ticket:
#! /usr/bin/python3
import json, requests
token = '5j6s....'
auth = f'Token token={token}'
def create_ticket():
url = 'http://172.18.0.70/api/v1/tickets'
new_ticket = {
"title": "Help me!",
"group": "PRUEBAS_SOPORTE",
"customer": "fpardo@example.com",
"article": {
"subject": "My subject",
"body": "I am a message!",
"type": "note",
"internal": False
req = requests.post(url, headers={'Authorization': auth} ,data=new_ticket)
print (req.status_code)
print(f'{req.text}')
create_ticket()
Adding also production.log results in case it helps:
Any advice would be appreciated.
Best Regards,
