Error connecting to Redis on localhost:6379 (Errno::ECONNREFUSED)
  • Used Zammad version: 6.5.0-1753334673.cc7247b2.noble
  • Rail Server running
  • Websockets active
  • Nothing is listening on ports 3000 and 6042
  • The systemd services are active (running)
Not sure to be honest. I have installed Zammad last week. Started configuring everything. Haven’t looked at it until know and cannot get it back to work :confused:
Apparently, there is a problem connecting to Redis
$ sudo zammad run rails r "Setting.set('es_url', 'http://127.0.0.1:9200')"
There was an error trying to connect to Redis via redis://localhost:6379.
Please provide a Redis instance at localhost:6379 or set REDIS_URL to point to a different location.
#<Redis::CannotConnectError: Error connecting to Redis on localhost:6379 (Errno::ECONNREFUSED)>
$ tail -f /var/log/redis/redis-server.log
# Configuration loaded
* monotonic clock: POSIX clock_gettime
* Running mode=standalone, port=6379.
# Server initialized
* Loading RDB produced by version 7.0.15
* RDB age 0 seconds
* RDB memory usage when created 0.84 Mb
* Done loading RDB, keys loaded: 0, keys expired: 0.
* DB loaded from disk: 0.000 seconds
* Ready to accept connections
^C
redis-cli -h 127.0.0.1 -p 6379 connects just fine though.
Not much going on in production.log except for repeating the following two lines over and over:
Using Zammad's file store as Rails cache store.
Using the File back end for Zammad's web socket session store.
I hope somebody has an idea how to fix this :hugs:
Connecting to localhost is not the same as connecting to 127.0.0.1
Is Redis both listening on IPv4 127.0.0.1 and IPv6 ::1 loopback addresses? Check with:
ss -tunapl|grep 6379
Is localhost configured as the hostname for both IPv4 and IPv6 loopback addresses? Check with:
host localhost
Also, what is the status of the Redis service? Check with:
systemctl status redis
Thank you very much. Your comment “connecting to localhost is not the same as connecting to 127.0.0.1” was spot on. localhost was set to 127.0.1.1 :man_shrugging: Redis itself was operating as intended.
