Error connect to Elasticsearch on CentOS 9
Hello.
I try configure zammad 5.4 with elasticsearch
I using Centos 9
  1. I have installed elasticsearch 8.9.0
  2. Installed zammad 5.4 from package
When I try connect zammad to elasticsearch I run command zammad run rails r “Setting.set(‘es_url’, ‘http://localhost:9200’)”
system returns error:
/opt/zammad/vendor/bundle/ruby/3.1.0/gems/bootsnap-1.16.0/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:32:in `require': libssl.so.1.1: cannot open shared object file: No such file or directory - /opt/zammad/vendor/bundle/ruby/3.1.0/gems/openssl-3.1.0/lib/openssl.so (LoadError)
 from /opt/zammad/vendor/bundle/ruby/3.1.0/gems/bootsnap-1.16.0/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:32:in `require'
        from /opt/zammad/vendor/bundle/ruby/3.1.0/gems/openssl-3.1.0/lib/openssl.rb:13:in `<main>'
        from /opt/zammad/vendor/bundle/ruby/3.1.0/gems/activesupport-6.1.7.3/lib/active_support/key_generator.rb:4:in `<main>'
        from /opt/zammad/vendor/bundle/ruby/3.1.0/gems/railties-6.1.7.3/lib/rails/application.rb:6:in `<main>'
        from /opt/zammad/vendor/bundle/ruby/3.1.0/gems/railties-6.1.7.3/lib/rails.rb:13:in `<main>'
        from /opt/zammad/vendor/bundle/ruby/3.1.0/gems/railties-6.1.7.3/lib/rails/all.rb:5:in `<main>'
        from /opt/zammad/config/application.rb:5:in `<main>'
        from /opt/zammad/vendor/bundle/ruby/3.1.0/gems/railties-6.1.7.3/lib/rails/command/actions.rb:22:in `require_application!'
        from /opt/zammad/vendor/bundle/ruby/3.1.0/gems/railties-6.1.7.3/lib/rails/command/actions.rb:14:in `require_application_and_environment!'
        from /opt/zammad/vendor/bundle/ruby/3.1.0/gems/railties-6.1.7.3/lib/rails/commands/runner/runner_command.rb:33:in `perform'
        from /opt/zammad/vendor/bundle/ruby/3.1.0/gems/thor-1.2.1/lib/thor/command.rb:27:in `run'
        from /opt/zammad/vendor/bundle/ruby/3.1.0/gems/thor-1.2.1/lib/thor/invocation.rb:127:in `invoke_command'
        from /opt/zammad/vendor/bundle/ruby/3.1.0/gems/thor-1.2.1/lib/thor.rb:392:in `dispatch'
        from /opt/zammad/vendor/bundle/ruby/3.1.0/gems/railties-6.1.7.3/lib/rails/command/base.rb:69:in `perform'
        from /opt/zammad/vendor/bundle/ruby/3.1.0/gems/railties-6.1.7.3/lib/rails/command.rb:48:in `invoke'
        from /opt/zammad/vendor/bundle/ruby/3.1.0/gems/railties-6.1.7.3/lib/rails/commands.rb:18:in `<main>'
        from /opt/zammad/bin/rails:5:in `<main>'
file openssl.so exists in dir /opt/zammad/vendor/bundle/ruby/3.1.0/gems/openssl-3.1.0/lib/
libssl.so.1.1 exists in dir /usr/lib/
What I do wrong?
There’s no package support for CentOS 9.
Packages are distribution specific and thus you shouldn’t “just use” non fitting packages.
Thanks. I tried install Zammad on Centos 7. It’s work
