- Used Zammad version: 5.0.x
- Browser + version: Chrome Version 94.0.4606.81
Migration data from OTRS is completed
When starting import I shortly got the message “ActiveRecord::InvalidForeignKey (Mysql2::Error: Cannot add or update a child row: a foreign key constraint fails (zammad
.ticket_priorities
, CONSTRAINT fk_rails_d43af6872e
FOREIGN KEY (updated_by_id
) REFERENCES users
(id
Tested from cli and here is the full log:
From Command Line :
sudo zammad run rails c
Loading production environment (Rails 6.0.4.6)
irb(main):001:0> Setting.set('import_otrs_endpoint', 'https://xxx/otrs/public.pl?Action=ZammadMigrator') Setting.reset_change_id: set new cache, bff13acb-cf29-46b4-a6a3-45d66c2339d3
Setting.set('import_otrs_endpoint', "https://xxx/otrs/public.pl?Action=ZammadMigrator")
=> true
irb(main):002:0> Setting.set('import_otrs_endpoint_key', 'xxx') Setting.reset_change_id: set new cache, 5b6672e0-0328-4cf1-be08-41e5c903230d
Setting.set('import_otrs_endpoint_key', "xxx")
irb(main):003:0> Setting.set('import_mode', true) Setting.reset_change_id: set new cache, b4bff099-35f7-4b6e-b0af-5381ba40d522
=> true
irb(main):004:0> Import::OTRS.start thread#-: Start import...
thread#-: POST: https://xxx/otrs/public.pl?Action=ZammadMigrator
thread#-: PARAMS: {:Action=>"ZammadMigrator", :Key=>"xxx"}
thread#-: loading SysConfig...
thread#-: PARAMS: {:Subaction=>"Export", :Object=>"SysConfig", :Limit=>"", :Offset=>"", :Diff=>0, :Action=>"ZammadMigrator", :Key=>"xxx"}
Setting.reset_change_id: set new cache, 82163fd9-fe24-4f20-bed1-fbb12c25acd5
Setting.set('http_type', "https")
Setting.reset_change_id: set new cache, d5816c35-5794-4002-9095-861addf9d5dd
Setting.set('organization', "XXX")
Setting.reset_change_id: set new cache, 8e636ee9-6273-4afd-9bf9-7679bb0862b6
Setting.set('system_id', "04")
Setting.reset_change_id: set new cache, 12229fe7-b973-4c4a-8d73-65d7dcf6e832
Setting.set('ticket_hook', "Ticket#")
Setting.reset_change_id: set new cache, 0b4583af-4016-4663-8153-490380c95975
Setting.set('ticket_number', "Ticket::Number::Date")
Setting.reset_change_id: set new cache, ff4f97e8-ed20-4116-8ec7-da36c61aec89
Setting.set('ticket_number_date', {:checksum=>true})
thread#-: loading DynamicField...
thread#-: PARAMS: {:Subaction=>"Export", :Object=>"DynamicField", :Limit=>"", :Offset=>"", :Diff=>0, :Action=>"ZammadMigrator", :Key=>"xxx"}
thread#-: loading State...
thread#-: PARAMS: {:Subaction=>"Export", :Object=>"State", :Limit=>"", :Offset=>"", :Diff=>0, :Action=>"ZammadMigrator", :Key=>"xxx"}
thread#-: update Ticket::State.find_by(id: 1)
thread#-: update Ticket::State.find_by(id: 10)
thread#-: update Ticket::State.find_by(id: 2)
thread#-: update Ticket::State.find_by(id: 3)
thread#-: update Ticket::State.find_by(id: 4)
thread#-: update Ticket::State.find_by(id: 5)
thread#-: update Ticket::State.find_by(id: 6)
thread#-: update Ticket::State.find_by(id: 7)
thread#-: update Ticket::State.find_by(id: 8)
thread#-: update Ticket::State.find_by(id: 9)
thread#-: loading Priority...
thread#-: PARAMS: {:Subaction=>"Export", :Object=>"Priority", :Limit=>"", :Offset=>"", :Diff=>0, :Action=>"ZammadMigrator", :Key=>"xxx"}
thread#-: update Ticket::Priority.find_by(id: 1)
16: from (irb):4
15: from lib/import/otrs.rb:28:in `start'
14: from lib/import/otrs.rb:149:in `updateable_objects'
13: from lib/import/otrs.rb:58:in `import'
12: from lib/import/otrs.rb:134:in `import_action'
11: from lib/import/base_factory.rb:9:in `import_action'
10: from lib/import/otrs/priority_factory.rb:12:in `import_loop'
9: from lib/import/base_factory.rb:40:in `import_loop'
8: from lib/import/base_factory.rb:40:in `each'
7: from lib/import/base_factory.rb:12:in `block in import_action'
6: from lib/import/base_factory.rb:36:in `create_instance'
5: from lib/import/base_factory.rb:36:in `new'
4: from lib/import/otrs/priority.rb:20:in `initialize'
3: from lib/import/otrs/priority.rb:26:in `import'
2: from lib/import/otrs/priority.rb:30:in `create_or_update'
1: from lib/import/otrs/priority.rb:40:in `updated?'
ActiveRecord::InvalidForeignKey (Mysql2::Error: Cannot add or update a child row: a foreign key constraint fails (`zammad`.`ticket_priorities`, CONSTRAINT `fk_rails_d43af6872e` FOREIGN KEY (`updated_by_id`) REFERENCES `users` (`id`)))
irb(main):005:0> exit
I understand that something in the database is not working but how exactly I can solve it is unclear to me as I have very little experience with SQL. Any suggestions? I would appreciate it if anyone could help )
