Enhance webhooks to better work with Zammad API
    Webhooks are great, but not when you actually try to call a Zammad API.
  • Authentication by Token is not possible, when calling Webhooks.
  • Request-Method cannot be changed.
    Because Webhooks are limited to POST-request.
  2. What is your expectation/what do you want to achieve?
    Call your own or another Zammad-Instance with a webhook
Maybe also a possible extension, to have it collected together: Enhancement for the webhooks - Custom headers
Hello here!
I was just diving into how to add the bearer token to Webhooks when calling Zabbix (for example, to acknowledge a problem from Zammad) and found myself wondering where exactly to put it. After some digging I found this feature request and realized why I couldn’t do it.
So, I just wanted to throw my support behind the feature request to make sure Zammad webhooks are compatible with a broader range of APIs! This would definitely make integration smoother and more flexible for everyone.
I found my way here trying to figure out how to automagically add checklist when a tag is added to a ticket. I would also love this feature.
