Hi!
I would like to suggest a great improvement on the check mk integration:
It would be great to nest the the current config.
It would be great to have multiple endpoints (by the Token after /api/v1/integration/check_mk/).
Each endpoint should have different target-group and maybe also different sender and closing behaviour.
Then we could map by cmk contact-group to different zammad groups which would be really awesome!
Thanks David!
