Title: Enable SAML-Authenticated Sessions to persist past Browser restart
The user is required to login again after closing the browser if they authenticated using SAML.
This behaviour may be present in other authentication methods (see related posts).
This behaviour introduces an additional point of friction to the login process. While I acknowdlege that this friction is relatively minor, in daily use this nonetheless has the potential to add up.
I was unable to locate a setting to modify this behaviour.
As such, until proven otherwise, this is not solvable.
I propose the addition of a Setting similar to the “Remember Me” checkbox used in the native login process. This would modify the session (cookie?) to persist past browser restarts.
Related Posts:
- SAML-Authenticated Sessions do not persist on Browser restart
- Zammad re-login required when closing browser (Google Auth)
Your Zammad environment:
- Average concurrent agent count: 3
- Average tickets a day: 20
- What roles/people are involved: IT and Application Groups (Agent), Users
