Hello everyone,
I’m currently testing Zammad, as we might want to switch from Znuny.
I successfully installed Zammad on Debian 12. Initially, everything worked perfectly.
Now I wanted to start the statistics in Zammad. I noticed that a window with a status code of 500 appears.
I then checked if the service was running on the Debian machine.
However, I’m getting an error message. I don’t really have any idea how to narrow down the problem.
Error message:
× elasticsearch.service - Elasticsearch
Loaded: loaded (/lib/systemd/system/elasticsearch.service; enabled; preset: enabled)
Active: failed (Result: signal) since Mon 2025-12-01 12:47:35 UTC; 16s ago
Duration: 1h 1min 17.603s
Docs: https://www.elastic.co
Process: 144832 ExecStart=/usr/share/elasticsearch/bin/systemd-entrypoint -p ${PID_DIR}/elasticsearch.pid --quiet (code=killed, signal=KILL)
Main PID: 144832 (code=killed, signal=KILL)
CPU: 7.601s
Dec 01 12:47:29 Zammad-Server systemd[1]: Starting elasticsearch.service - Elasticsearch…
Dec 01 12:47:35 Zammad-Server systemd[1]: elasticsearch.service: Main process exited, code=killed, status=9/KILL
Dec 01 12:47:35 Zammad-Server systemd[1]: elasticsearch.service: Failed with result ‘signal’.
Dec 01 12:47:35 Zammad-Server systemd[1]: Failed to start elasticsearch.service - Elasticsearch.
Dec 01 12:47:35 Zammad-Server systemd[1]: elasticsearch.service: Consumed 7.601s CPU time.
Can you help me narrow down the problem?
Thanks!
Best regards, Matthias
