Hello to all, I’m an enthusiastic user of Zammad, but a very geek in linux enviroment.
Running on ubuntu sever 24.04.2 LTS
I have update to the last avilable zammad version but elasticsearch can’t load.
Here the log, anyone can help me to understand the reason
... 6 more
[2025-04-09T14:53:04,092][INFO ][o.e.n.Node ] [bszammad] version[7.17.28], pid[3198127], build[default/deb/139cb5a961d8de68b8e02c45cc47f5289a3623af/2025-02-20T09:05:31.349013687Z], OS[Linux/6.8.0-31-generic/amd64], JVM[Oracle Corporatio>
[2025-04-09T14:53:04,097][INFO ][o.e.n.Node ] [bszammad] JVM home [/usr/share/elasticsearch/jdk], using bundled JDK [true]
[2025-04-09T14:53:04,098][INFO ][o.e.n.Node ] [bszammad] JVM arguments [-Xshare:auto, -Des.networkaddress.cache.ttl=60, -Des.networkaddress.cache.negative.ttl=10, -XX:+AlwaysPreTouch, -Xss1m, -Djava.awt.headless=true, -Dfile.encoding=UT>
[2025-04-09T14:53:07,357][ERROR][o.e.b.Bootstrap ] [bszammad] Exception
java.lang.IllegalArgumentException: Plugin [ingest-attachment] was built for Elasticsearch version 7.17.23 but version 7.17.28 is running
at org.elasticsearch.plugins.PluginsService.verifyCompatibility(PluginsService.java:391) ~[elasticsearch-7.17.28.jar:7.17.28]
at org.elasticsearch.plugins.PluginsService.loadBundle(PluginsService.java:700) ~[elasticsearch-7.17.28.jar:7.17.28]
at org.elasticsearch.plugins.PluginsService.loadBundles(PluginsService.java:533) ~[elasticsearch-7.17.28.jar:7.17.28]
at org.elasticsearch.plugins.PluginsService.(PluginsService.java:170) ~[elasticsearch-7.17.28.jar:7.17.28]
at org.elasticsearch.node.Node.(Node.java:411) ~[elasticsearch-7.17.28.jar:7.17.28]
at org.elasticsearch.node.Node.(Node.java:309) ~[elasticsearch-7.17.28.jar:7.17.28]
at org.elasticsearch.bootstrap.Bootstrap$5.(Bootstrap.java:234) ~[elasticsearch-7.17.28.jar:7.17.28]
at org.elasticsearch.bootstrap.Bootstrap.setup(Bootstrap.java:234) ~[elasticsearch-7.17.28.jar:7.17.28]
