- Used Zammad version: 3.1.x
 - Used Zammad installation source: (source, package, …) RPM
 - Operating system: CentOS
 - Browser + version: All
- The Elasticsearch service is working properly
- After updating CentOS, the elasticsearch service does not start
- yun update
Here are the LOGs I have collected
[2019-07-13T18:50:55,793][ERROR][o.e.b.Bootstrap          ] Exception
java.lang.IllegalArgumentException: plugin [ingest-attachment] is incompatible with version [5.6.16]; was designed for version [5.6.15]
at org.elasticsearch.plugins.PluginInfo.readFromProperties(PluginInfo.java:146) ~[elasticsearch-5.6.16.jar:5.6.16]
at org.elasticsearch.bootstrap.Spawner.spawnNativePluginControllers(Spawner.java:80) ~[elasticsearch-5.6.16.jar:5.6.16]
at org.elasticsearch.bootstrap.Bootstrap.setup(Bootstrap.java:168) ~[elasticsearch-5.6.16.jar:5.6.16]
at org.elasticsearch.bootstrap.Bootstrap.init(Bootstrap.java:342) [elasticsearch-5.6.16.jar:5.6.16]
at org.elasticsearch.bootstrap.Elasticsearch.init(Elasticsearch.java:132) [elasticsearch-5.6.16.jar:5.6.16]
at org.elasticsearch.bootstrap.Elasticsearch.execute(Elasticsearch.java:123) [elasticsearch-5.6.16.jar:5.6.16]
at org.elasticsearch.cli.EnvironmentAwareCommand.execute(EnvironmentAwareCommand.java:70) [elasticsearch-5.6.16.jar:5.6.16]
at org.elasticsearch.cli.Command.mainWithoutErrorHandling(Command.java:134) [elasticsearch-5.6.16.jar:5.6.16]
at org.elasticsearch.cli.Command.main(Command.java:90) [elasticsearch-5.6.16.jar:5.6.16]
at org.elasticsearch.bootstrap.Elasticsearch.main(Elasticsearch.java:91) [elasticsearch-5.6.16.jar:5.6.16]
at org.elasticsearch.bootstrap.Elasticsearch.main(Elasticsearch.java:84) [elasticsearch-5.6.16.jar:5.6.16]
[2019-07-13T18:50:55,807][WARN ][o.e.b.ElasticsearchUncaughtExceptionHandler] [] uncaught exception in thread [main]
org.elasticsearch.bootstrap.StartupException: java.lang.IllegalArgumentException: plugin [ingest-attachment] is incompatible with version [5.6.16]; was designed for version [5.6.15]
at org.elasticsearch.bootstrap.Elasticsearch.init(Elasticsearch.java:136) ~[elasticsearch-5.6.16.jar:5.6.16]
at org.elasticsearch.bootstrap.Elasticsearch.execute(Elasticsearch.java:123) ~[elasticsearch-5.6.16.jar:5.6.16]
at org.elasticsearch.cli.EnvironmentAwareCommand.execute(EnvironmentAwareCommand.java:70) ~[elasticsearch-5.6.16.jar:5.6.16]
at org.elasticsearch.cli.Command.mainWithoutErrorHandling(Command.java:134) ~[elasticsearch-5.6.16.jar:5.6.16]
at org.elasticsearch.cli.Command.main(Command.java:90) ~[elasticsearch-5.6.16.jar:5.6.16]
at org.elasticsearch.bootstrap.Elasticsearch.main(Elasticsearch.java:91) ~[elasticsearch-5.6.16.jar:5.6.16]
at org.elasticsearch.bootstrap.Elasticsearch.main(Elasticsearch.java:84) ~[elasticsearch-5.6.16.jar:5.6.16]
Caused by: java.lang.IllegalArgumentException: plugin [ingest-attachment] is incompatible with version [5.6.16]; was designed for version [5.6.15]
at org.elasticsearch.bootstrap.Bootstrap.init(Bootstrap.java:342) ~[elasticsearch-5.6.16.jar:5.6.16]
at org.elasticsearch.bootstrap.Elasticsearch.init(Elasticsearch.java:132) ~[elasticsearch-5.6.16.jar:5.6.16]
… 6 more
