Used Zammad version: 6.2.0-1711375558.ce1240f3.bookworm
Used Zammad installation type: (source, package, docker-compose, …): package
Operating system: Debian 12
Browser + version: All
How do I pass through the client IP using nested NGINX servers?
For example I have NGINX SERVER → Zammad HOST (running it’s own NGINX).
I see the nginx on the host is setting the CLIENT_IP to the $remote_addr, but how can I pass through the $remote_addr on the main NGINX proxy thru to CLIENT_IP for zammd to get the correct IP?
One solution, depending on your setup, that you could apply is to disable the “zammad nginx” and point your nginx directly to the zammad host ip and port 3000
