- Used Zammad version: 2.8.x
- Used Zammad installation source: docker
- Operating system: ubuntu 16.04
- Browser + version: Firefox 63
- Get Twitter DMs
- Cannot recieve the twitter DMs. This is the railsserver error logs. Do I have to update the database structure in a way?
zammad-railsserver_1 | I, [2018-12-15T14:31:41.809764 #1-47403279508800] INFO -- : Started POST "/api/v1/channels_twitter_webhook" for ::ffff:172.27.0.5 at 2018-12-15 14:31:41 +0000
zammad-railsserver_1 | I, [2018-12-15T14:31:41.815521 #1-47403279508800] INFO -- : Processing by ChannelsTwitterController#webhook_incoming as HTML
zammad-railsserver_1 | I, [2018-12-15T14:31:41.815973 #1-47403279508800] INFO -- : Parameters: {"for_user_id"=>"946030858967896064", "follow_events"=>[{"type"=>"follow", "created_timestamp"=>"1544898157248", "target"=>{"id"=>"946030858967896064", "default_profile_image"=>false, "profile_background_image_url"=>"", "friends_count"=>117, "favourites_count"=>13, "profile_link_color"=>-1, "profile_background_image_url_https"=>"", "utc_offset"=>0, "screen_name"=>"C3Auti", "is_translator"=>false, "followers_count"=>135, "name"=>"C3Auti", "lang"=>"en", "profile_use_background_image"=>false, "created_at"=>"Wed Dec 27 14:51:47 +0000 2017", "profile_text_color"=>-1, "notifications"=>false, "protected"=>false, "statuses_count"=>32, "url"=>"", "contributors_enabled"=>false, "default_profile"=>true, "profile_sidebar_border_color"=>-1, "time_zone"=>"", "geo_enabled"=>false, "verified"=>false, "profile_image_url"=>"http://pbs.twimg.com/profile_images/1065349138915700736/2_p2xCDW_normal.jpg", "following"=>false, "profile_image_url_https"=>"https://pbs.twimg.com/profile_images/1065349138915700736/2_p2xCDW_normal.jpg", "profile_background_tile"=>false, "listed_count"=>10, "profile_sidebar_fill_color"=>-1, "location"=>"", "follow_request_sent"=>false, "description"=>"", "profile_background_color"=>-1}, "source"=>{"id"=>"96750314", "default_profile_image"=>false, "profile_background_image_url"=>"", "friends_count"=>1917, "favourites_count"=>8133, "profile_link_color"=>-1, "profile_background_image_url_https"=>"", "utc_offset"=>0, "screen_name"=>"mr_ligi", "is_translator"=>false, "followers_count"=>1503, "name"=>"ligi", "lang"=>"en", "profile_use_background_image"=>false, "created_at"=>"Mon Dec 14 12:17:19 +0000 2009", "profile_text_color"=>-1, "notifications"=>false, "protected"=>false, "statuses_count"=>4203, "url"=>"https://t.co/Qm4PmNlgJu", "contributors_enabled"=>false, "default_profile"=>true, "profile_sidebar_border_color"=>-1, "time_zone"=>"", "geo_enabled"=>false, "verified"=>false, "profile_image_url"=>"", "following"=>false, "profile_image_url_https"=>"", "profile_background_tile"=>false, "listed_count"=>55, "profile_sidebar_fill_color"=>-1, "location"=>"earth, Miliway", "follow_request_sent"=>false, "description"=>"#android #foss #decentralization #ethereum", "profile_background_color"=>-1}}]}
zammad-railsserver_1 | E, [2018-12-15T14:31:41.827659 #1-47403279508800] ERROR -- : No such channel for user id '946030858967896064'! (Exceptions::UnprocessableEntity)
zammad-railsserver_1 | /opt/zammad/app/controllers/channels_twitter_controller.rb:32:in `validate_webhook_signature!'
zammad-railsserver_1 | /usr/local/bundle/gems/activesupport-5.1.6.1/lib/active_support/callbacks.rb:413:in `block in make_lambda'
zammad-railsserver_1 | /usr/local/bundle/gems/activesupport-5.1.6.1/lib/active_support/callbacks.rb:178:in `block (2 levels) in halting_and_conditional'
zammad-railsserver_1 | /usr/local/bundle/gems/actionpack-5.1.6.1/lib/abstract_controller/callbacks.rb:12:in `block (2 levels) in <module:Callbacks>'
zammad-railsserver_1 | /usr/local/bundle/gems/activesupport-5.1.6.1/lib/active_support/callbacks.rb:179:in `block in halting_and_conditional'
zammad-railsserver_1 | /usr/local/bundle/gems/activesupport-5.1.6.1/lib/active_support/callbacks.rb:507:in `block in invoke_before'
zammad-railsserver_1 | /usr/local/bundle/gems/activesupport-5.1.6.1/lib/active_support/callbacks.rb:507:in `each'
zammad-railsserver_1 | /usr/local/bundle/gems/activesupport-5.1.6.1/lib/active_support/callbacks.rb:507:in `invoke_before'
zammad-railsserver_1 | /usr/local/bundle/gems/activesupport-5.1.6.1/lib/active_support/callbacks.rb:130:in `run_callbacks'
zammad-railsserver_1 | /usr/local/bundle/gems/actionpack-5.1.6.1/lib/abstract_controller/callbacks.rb:19:in `process_action'
zammad-railsserver_1 | /usr/local/bundle/gems/actionpack-5.1.6.1/lib/action_controller/metal/rescue.rb:20:in `process_action'
zammad-railsserver_1 | /usr/local/bundle/gems/actionpack-5.1.6.1/lib/action_controller/metal/instrumentation.rb:32:in `block in process_action'
zammad-railsserver_1 | /usr/local/bundle/gems/activesupport-5.1.6.1/lib/active_support/notifications.rb:166:in `block in instrument'
zammad-railsserver_1 | /usr/local/bundle/gems/activesupport-5.1.6.1/lib/active_support/notifications/instrumenter.rb:21:in `instrument'
zammad-railsserver_1 | /usr/local/bundle/gems/activesupport-5.1.6.1/lib/active_support/notifications.rb:166:in `instrument'
zammad-railsserver_1 | /usr/local/bundle/gems/actionpack-5.1.6.1/lib/action_controller/metal/instrumentation.rb:30:in `process_action'
zammad-railsserver_1 | /usr/local/bundle/gems/actionpack-5.1.6.1/lib/action_controller/metal/params_wrapper.rb:252:in `process_action'
zammad-railsserver_1 | /usr/local/bundle/gems/activerecord-5.1.6.1/lib/active_record/railties/controller_runtime.rb:22:in `process_action'
zammad-railsserver_1 | /usr/local/bundle/gems/actionpack-5.1.6.1/lib/abstract_controller/base.rb:124:in `process'
zammad-railsserver_1 | /usr/local/bundle/gems/actionview-5.1.6.1/lib/action_view/rendering.rb:30:in `process'
zammad-railsserver_1 | /usr/local/bundle/gems/actionpack-5.1.6.1/lib/action_controller/metal.rb:189:in `dispatch'
zammad-railsserver_1 | /usr/local/bundle/gems/actionpack-5.1.6.1/lib/action_controller/metal.rb:253:in `dispatch'
zammad-railsserver_1 | /usr/local/bundle/gems/actionpack-5.1.6.1/lib/action_dispatch/routing/route_set.rb:49:in `dispatch'
zammad-railsserver_1 | /usr/local/bundle/gems/actionpack-5.1.6.1/lib/action_dispatch/routing/route_set.rb:31:in `serve'
zammad-railsserver_1 | /usr/local/bundle/gems/actionpack-5.1.6.1/lib/action_dispatch/journey/router.rb:50:in `block in serve'
zammad-railsserver_1 | /usr/local/bundle/gems/actionpack-5.1.6.1/lib/action_dispatch/journey/router.rb:33:in `each'
zammad-railsserver_1 | /usr/local/bundle/gems/actionpack-5.1.6.1/lib/action_dispatch/journey/router.rb:33:in `serve'
zammad-railsserver_1 | /usr/local/bundle/gems/actionpack-5.1.6.1/lib/action_dispatch/routing/route_set.rb:844:in `call'
zammad-railsserver_1 | /usr/local/bundle/gems/omniauth-1.7.1/lib/omniauth/strategy.rb:190:in `call!'
zammad-railsserver_1 | /usr/local/bundle/gems/omniauth-1.7.1/lib/omniauth/strategy.rb:168:in `call'
zammad-railsserver_1 | /usr/local/bundle/gems/omniauth-1.7.1/lib/omniauth/builder.rb:63:in `call'
zammad-railsserver_1 | /usr/local/bundle/gems/rack-2.0.6/lib/rack/etag.rb:25:in `call'
zammad-railsserver_1 | /usr/local/bundle/gems/rack-2.0.6/lib/rack/conditional_get.rb:38:in `call'
zammad-railsserver_1 | /usr/local/bundle/gems/rack-2.0.6/lib/rack/head.rb:12:in `call'
zammad-railsserver_1 | /usr/local/bundle/gems/rack-2.0.6/lib/rack/session/abstract/id.rb:232:in `context'
zammad-railsserver_1 | /usr/local/bundle/gems/rack-2.0.6/lib/rack/session/abstract/id.rb:226:in `call'
zammad-railsserver_1 | /usr/local/bundle/gems/actionpack-5.1.6.1/lib/action_dispatch/middleware/cookies.rb:613:in `call'
zammad-railsserver_1 | /usr/local/bundle/gems/actionpack-5.1.6.1/lib/action_dispatch/middleware/callbacks.rb:26:in `block in call'
zammad-railsserver_1 | /usr/local/bundle/gems/activesupport-5.1.6.1/lib/active_support/callbacks.rb:97:in `run_callbacks'
zammad-railsserver_1 | /usr/local/bundle/gems/actionpack-5.1.6.1/lib/action_dispatch/middleware/callbacks.rb:24:in `call'
zammad-railsserver_1 | /usr/local/bundle/gems/actionpack-5.1.6.1/lib/action_dispatch/middleware/debug_exceptions.rb:59:in `call'
zammad-railsserver_1 | /usr/local/bundle/gems/actionpack-5.1.6.1/lib/action_dispatch/middleware/show_exceptions.rb:31:in `call'
zammad-railsserver_1 | /usr/local/bundle/gems/railties-5.1.6.1/lib/rails/rack/logger.rb:36:in `call_app'
zammad-railsserver_1 | /usr/local/bundle/gems/railties-5.1.6.1/lib/rails/rack/logger.rb:26:in `call'
zammad-railsserver_1 | /usr/local/bundle/gems/actionpack-5.1.6.1/lib/action_dispatch/middleware/remote_ip.rb:79:in `call'
zammad-railsserver_1 | /usr/local/bundle/gems/actionpack-5.1.6.1/lib/action_dispatch/middleware/request_id.rb:25:in `call'
zammad-railsserver_1 | /usr/local/bundle/gems/rack-2.0.6/lib/rack/method_override.rb:22:in `call'
zammad-railsserver_1 | /usr/local/bundle/gems/rack-2.0.6/lib/rack/runtime.rb:22:in `call'
zammad-railsserver_1 | /usr/local/bundle/gems/activesupport-5.1.6.1/lib/active_support/cache/strategy/local_cache_middleware.rb:27:in `call'
zammad-railsserver_1 | /usr/local/bundle/gems/actionpack-5.1.6.1/lib/action_dispatch/middleware/executor.rb:12:in `call'
zammad-railsserver_1 | /usr/local/bundle/gems/rack-2.0.6/lib/rack/sendfile.rb:111:in `call'
zammad-railsserver_1 | /usr/local/bundle/gems/railties-5.1.6.1/lib/rails/engine.rb:522:in `call'
zammad-railsserver_1 | /usr/local/bundle/gems/puma-3.11.0/lib/puma/configuration.rb:225:in `call'
zammad-railsserver_1 | /usr/local/bundle/gems/puma-3.11.0/lib/puma/server.rb:624:in `handle_request'
zammad-railsserver_1 | /usr/local/bundle/gems/puma-3.11.0/lib/puma/server.rb:438:in `process_client'
zammad-railsserver_1 | /usr/local/bundle/gems/puma-3.11.0/lib/puma/server.rb:302:in `block in run'
zammad-railsserver_1 | /usr/local/bundle/gems/puma-3.11.0/lib/puma/thread_pool.rb:120:in `block in spawn_thread'
zammad-railsserver_1 | /usr/local/bundle/gems/logging-2.2.2/lib/logging/diagnostic_context.rb:474:in `block in create_with_logging_context'
zammad-railsserver_1 | I, [2018-12-15T14:31:41.829354 #1-47403279508800] INFO -- : Rendering inline template
zammad-railsserver_1 | I, [2018-12-15T14:31:41.830151 #1-47403279508800] INFO -- : Rendered inline template (0.6ms)
zammad-railsserver_1 | I, [2018-12-15T14:31:41.830532 #1-47403279508800] INFO -- : Completed 422 Unprocessable Entity in 14ms (Views: 1.4ms | ActiveRecord: 3.5ms)
- always
Best fairsein
