- Used Zammad version:
root@desk:~# dpkg -l | grep "zammad\|elastic"
ii elasticsearch 7.10.2 amd64 Distributed RESTful search engine built for the cloud
ii zammad 3.6.0-1610545422.444c3a5d.buster amd64 Zammad is a web based open source helpdesk/customer support system
- Used Zammad installation source: (source, package, …):
root@desk:~# apt info zammad
Package: zammad
Version: 3.6.0-1610545422.444c3a5d.buster
Priority: extra
Section: default
Maintainer: support@packager.io
Installed-Size: 736 MB
Provides: zammad
Depends: mysql-common, libpq5, libsqlite3-0, openssl, libxml2, libxslt1.1, curl, elasticsearch, nginx|apache2, postgresql|mariadb-server|sqlite, libimlib2
Homepage: https://zammad.org
License: unknown
Vendor: Packager.io <https://packager.io>
Download-Size: 266 MB
APT-Manual-Installed: yes
APT-Sources: https://dl.packager.io/srv/deb/zammad/zammad/stable/debian 10/main amd64 Packages
Description: Zammad is a web based open source helpdesk/customer support system
- Operating system:
root@desk:~# cat /etc/debian_version
10.7
Browser + version: Firefox Developer 85.0b8
Elastic log (boot until now):
root@desk:~# tail -f /var/log/elasticsearch/elasticsearch.log
[2021-01-15T01:01:37,014][INFO ][o.e.n.Node ] [desk] version[7.10.2], pid[169], build[default/deb/747e1cc71def077253878a59143c1f785afa92b9/2021-01-13T00:42:12.435326Z], OS[Linux/5.4.73-1-pve/amd64], JVM[AdoptOpenJDK/OpenJDK 64-Bit Server VM/15.0.1/15.0.1+9]
[2021-01-15T01:01:37,028][INFO ][o.e.n.Node ] [desk] JVM home [/usr/share/elasticsearch/jdk], using bundled JDK [true]
[2021-01-15T01:01:37,029][INFO ][o.e.n.Node ] [desk] JVM arguments [-Xshare:auto, -Des.networkaddress.cache.ttl=60, -Des.networkaddress.cache.negative.ttl=10, -XX:+AlwaysPreTouch, -Xss1m, -Djava.awt.headless=true, -Dfile.encoding=UTF-8, -Djna.nosys=true, -XX:-OmitStackTraceInFastThrow, -XX:+ShowCodeDetailsInExceptionMessages, -Dio.netty.noUnsafe=true, -Dio.netty.noKeySetOptimization=true, -Dio.netty.recycler.maxCapacityPerThread=0, -Dio.netty.allocator.numDirectArenas=0, -Dlog4j.shutdownHookEnabled=false, -Dlog4j2.disable.jmx=true, -Djava.locale.providers=SPI,COMPAT, -Xms1g, -Xmx1g, -XX:+UseG1GC, -XX:G1ReservePercent=25, -XX:InitiatingHeapOccupancyPercent=30, -Djava.io.tmpdir=/tmp/elasticsearch-12443500619269445740, -XX:+HeapDumpOnOutOfMemoryError, -XX:HeapDumpPath=/var/lib/elasticsearch, -XX:ErrorFile=/var/log/elasticsearch/hs_err_pid%p.log, -Xlog:gc*,gc+age=trace,safepoint:file=/var/log/elasticsearch/gc.log:utctime,pid,tags:filecount=32,filesize=64m, -XX:MaxDirectMemorySize=536870912, -Des.path.home=/usr/share/elasticsearch, -Des.path.conf=/etc/elasticsearch, -Des.distribution.flavor=default, -Des.distribution.type=deb, -Des.bundled_jdk=true]
[2021-01-15T01:01:40,586][INFO ][o.e.p.PluginsService ] [desk] loaded module [aggs-matrix-stats]
[2021-01-15T01:01:40,586][INFO ][o.e.p.PluginsService ] [desk] loaded module [analysis-common]
[2021-01-15T01:01:40,587][INFO ][o.e.p.PluginsService ] [desk] loaded module [constant-keyword]
[2021-01-15T01:01:40,587][INFO ][o.e.p.PluginsService ] [desk] loaded module [flattened]
[2021-01-15T01:01:40,587][INFO ][o.e.p.PluginsService ] [desk] loaded module [frozen-indices]
[2021-01-15T01:01:40,587][INFO ][o.e.p.PluginsService ] [desk] loaded module [ingest-common]
[2021-01-15T01:01:40,588][INFO ][o.e.p.PluginsService ] [desk] loaded module [ingest-geoip]
[2021-01-15T01:01:40,588][INFO ][o.e.p.PluginsService ] [desk] loaded module [ingest-user-agent]
[2021-01-15T01:01:40,588][INFO ][o.e.p.PluginsService ] [desk] loaded module [kibana]
[2021-01-15T01:01:40,588][INFO ][o.e.p.PluginsService ] [desk] loaded module [lang-expression]
[2021-01-15T01:01:40,588][INFO ][o.e.p.PluginsService ] [desk] loaded module [lang-mustache]
[2021-01-15T01:01:40,589][INFO ][o.e.p.PluginsService ] [desk] loaded module [lang-painless]
[2021-01-15T01:01:40,589][INFO ][o.e.p.PluginsService ] [desk] loaded module [mapper-extras]
[2021-01-15T01:01:40,589][INFO ][o.e.p.PluginsService ] [desk] loaded module [mapper-version]
[2021-01-15T01:01:40,589][INFO ][o.e.p.PluginsService ] [desk] loaded module [parent-join]
[2021-01-15T01:01:40,589][INFO ][o.e.p.PluginsService ] [desk] loaded module [percolator]
[2021-01-15T01:01:40,590][INFO ][o.e.p.PluginsService ] [desk] loaded module [rank-eval]
[2021-01-15T01:01:40,590][INFO ][o.e.p.PluginsService ] [desk] loaded module [reindex]
[2021-01-15T01:01:40,590][INFO ][o.e.p.PluginsService ] [desk] loaded module [repositories-metering-api]
[2021-01-15T01:01:40,590][INFO ][o.e.p.PluginsService ] [desk] loaded module [repository-url]
[2021-01-15T01:01:40,590][INFO ][o.e.p.PluginsService ] [desk] loaded module [search-business-rules]
[2021-01-15T01:01:40,591][INFO ][o.e.p.PluginsService ] [desk] loaded module [searchable-snapshots]
[2021-01-15T01:01:40,591][INFO ][o.e.p.PluginsService ] [desk] loaded module [spatial]
[2021-01-15T01:01:40,591][INFO ][o.e.p.PluginsService ] [desk] loaded module [systemd]
[2021-01-15T01:01:40,592][INFO ][o.e.p.PluginsService ] [desk] loaded module [transform]
[2021-01-15T01:01:40,592][INFO ][o.e.p.PluginsService ] [desk] loaded module [transport-netty4]
[2021-01-15T01:01:40,592][INFO ][o.e.p.PluginsService ] [desk] loaded module [unsigned-long]
[2021-01-15T01:01:40,593][INFO ][o.e.p.PluginsService ] [desk] loaded module [vectors]
[2021-01-15T01:01:40,593][INFO ][o.e.p.PluginsService ] [desk] loaded module [wildcard]
[2021-01-15T01:01:40,593][INFO ][o.e.p.PluginsService ] [desk] loaded module [x-pack-analytics]
[2021-01-15T01:01:40,593][INFO ][o.e.p.PluginsService ] [desk] loaded module [x-pack-async]
[2021-01-15T01:01:40,594][INFO ][o.e.p.PluginsService ] [desk] loaded module [x-pack-async-search]
[2021-01-15T01:01:40,594][INFO ][o.e.p.PluginsService ] [desk] loaded module [x-pack-autoscaling]
[2021-01-15T01:01:40,594][INFO ][o.e.p.PluginsService ] [desk] loaded module [x-pack-ccr]
[2021-01-15T01:01:40,594][INFO ][o.e.p.PluginsService ] [desk] loaded module [x-pack-core]
[2021-01-15T01:01:40,594][INFO ][o.e.p.PluginsService ] [desk] loaded module [x-pack-data-streams]
[2021-01-15T01:01:40,595][INFO ][o.e.p.PluginsService ] [desk] loaded module [x-pack-deprecation]
[2021-01-15T01:01:40,595][INFO ][o.e.p.PluginsService ] [desk] loaded module [x-pack-enrich]
[2021-01-15T01:01:40,595][INFO ][o.e.p.PluginsService ] [desk] loaded module [x-pack-eql]
[2021-01-15T01:01:40,595][INFO ][o.e.p.PluginsService ] [desk] loaded module [x-pack-graph]
[2021-01-15T01:01:40,595][INFO ][o.e.p.PluginsService ] [desk] loaded module [x-pack-identity-provider]
[2021-01-15T01:01:40,596][INFO ][o.e.p.PluginsService ] [desk] loaded module [x-pack-ilm]
[2021-01-15T01:01:40,596][INFO ][o.e.p.PluginsService ] [desk] loaded module [x-pack-logstash]
[2021-01-15T01:01:40,596][INFO ][o.e.p.PluginsService ] [desk] loaded module [x-pack-ml]
[2021-01-15T01:01:40,596][INFO ][o.e.p.PluginsService ] [desk] loaded module [x-pack-monitoring]
[2021-01-15T01:01:40,596][INFO ][o.e.p.PluginsService ] [desk] loaded module [x-pack-ql]
[2021-01-15T01:01:40,596][INFO ][o.e.p.PluginsService ] [desk] loaded module [x-pack-rollup]
[2021-01-15T01:01:40,597][INFO ][o.e.p.PluginsService ] [desk] loaded module [x-pack-security]
[2021-01-15T01:01:40,597][INFO ][o.e.p.PluginsService ] [desk] loaded module [x-pack-sql]
[2021-01-15T01:01:40,597][INFO ][o.e.p.PluginsService ] [desk] loaded module [x-pack-stack]
[2021-01-15T01:01:40,597][INFO ][o.e.p.PluginsService ] [desk] loaded module [x-pack-voting-only-node]
[2021-01-15T01:01:40,598][INFO ][o.e.p.PluginsService ] [desk] loaded module [x-pack-watcher]
[2021-01-15T01:01:40,598][INFO ][o.e.p.PluginsService ] [desk] loaded plugin [ingest-attachment]
[2021-01-15T01:01:40,641][INFO ][o.e.e.NodeEnvironment ] [desk] using [1] data paths, mounts [[/ (/dev/mapper/pve-vm--114--disk--0)]], net usable_space [6.8gb], net total_space [9.7gb], types [ext4]
[2021-01-15T01:01:40,641][INFO ][o.e.e.NodeEnvironment ] [desk] heap size [1gb], compressed ordinary object pointers [true]
[2021-01-15T01:01:40,743][INFO ][o.e.n.Node ] [desk] node name [desk], node ID [9UXbf3Q1R6yDKQLJ__K5fA], cluster name [elasticsearch], roles [transform, master, remote_cluster_client, data, ml, data_content, data_hot, data_warm, data_cold, ingest]
[2021-01-15T01:01:44,165][INFO ][o.e.x.m.p.l.CppLogMessageHandler] [desk] [controller/577] [Main.cc@114] controller (64 bit): Version 7.10.2 (Build 40a3af639d4698) Copyright (c) 2021 Elasticsearch BV
[2021-01-15T01:01:44,792][INFO ][o.e.x.s.a.s.FileRolesStore] [desk] parsed [0] roles from file [/etc/elasticsearch/roles.yml]
[2021-01-15T01:01:45,837][INFO ][o.e.t.NettyAllocator ] [desk] creating NettyAllocator with the following configs: [name=unpooled, suggested_max_allocation_size=256kb, factors={es.unsafe.use_unpooled_allocator=null, g1gc_enabled=true, g1gc_region_size=1mb, heap_size=1gb}]
[2021-01-15T01:01:45,899][INFO ][o.e.d.DiscoveryModule ] [desk] using discovery type [zen] and seed hosts providers [settings]
[2021-01-15T01:01:46,280][WARN ][o.e.g.DanglingIndicesState] [desk] gateway.auto_import_dangling_indices is disabled, dangling indices will not be automatically detected or imported and must be managed manually
[2021-01-15T01:01:46,653][INFO ][o.e.n.Node ] [desk] initialized
[2021-01-15T01:01:46,653][INFO ][o.e.n.Node ] [desk] starting ...
[2021-01-15T01:01:46,749][INFO ][o.e.t.TransportService ] [desk] publish_address {127.0.0.1:9300}, bound_addresses {[::1]:9300}, {127.0.0.1:9300}
[2021-01-15T01:01:47,040][WARN ][o.e.b.BootstrapChecks ] [desk] the default discovery settings are unsuitable for production use; at least one of [discovery.seed_hosts, discovery.seed_providers, cluster.initial_master_nodes] must be configured
[2021-01-15T01:01:47,041][INFO ][o.e.c.c.Coordinator ] [desk] cluster UUID [YS8r1EA0RZqId2tzxK-Ngg]
[2021-01-15T01:01:47,050][INFO ][o.e.c.c.ClusterBootstrapService] [desk] no discovery configuration found, will perform best-effort cluster bootstrapping after [3s] unless existing master is discovered
[2021-01-15T01:01:47,137][INFO ][o.e.c.s.MasterService ] [desk] elected-as-master ([1] nodes joined)[{desk}{9UXbf3Q1R6yDKQLJ__K5fA}{I7VPlrG1SV-kMpEgB9az9w}{127.0.0.1}{127.0.0.1:9300}{cdhilmrstw}{ml.machine_memory=4294967296, xpack.installed=true, transform.node=true, ml.max_open_jobs=20} elect leader, _BECOME_MASTER_TASK_, _FINISH_ELECTION_], term: 3, version: 85, delta: master node changed {previous [], current [{desk}{9UXbf3Q1R6yDKQLJ__K5fA}{I7VPlrG1SV-kMpEgB9az9w}{127.0.0.1}{127.0.0.1:9300}{cdhilmrstw}{ml.machine_memory=4294967296, xpack.installed=true, transform.node=true, ml.max_open_jobs=20}]}
[2021-01-15T01:01:47,218][INFO ][o.e.c.s.ClusterApplierService] [desk] master node changed {previous [], current [{desk}{9UXbf3Q1R6yDKQLJ__K5fA}{I7VPlrG1SV-kMpEgB9az9w}{127.0.0.1}{127.0.0.1:9300}{cdhilmrstw}{ml.machine_memory=4294967296, xpack.installed=true, transform.node=true, ml.max_open_jobs=20}]}, term: 3, version: 85, reason: Publication{term=3, version=85}
[2021-01-15T01:01:47,249][INFO ][o.e.h.AbstractHttpServerTransport] [desk] publish_address {127.0.0.1:9200}, bound_addresses {[::1]:9200}, {127.0.0.1:9200}
[2021-01-15T01:01:47,250][INFO ][o.e.n.Node ] [desk] started
[2021-01-15T01:01:47,500][INFO ][o.e.l.LicenseService ] [desk] license [f3cf3a4d-5ffe-4211-a2d4-a5db603a02e7] mode [basic] - valid
[2021-01-15T01:01:47,501][INFO ][o.e.x.s.s.SecurityStatusChangeListener] [desk] Active license is now [BASIC]; Security is disabled
[2021-01-15T01:01:47,504][INFO ][o.e.g.GatewayService ] [desk] recovered [9] indices into cluster_state
[2021-01-15T01:01:48,473][INFO ][o.e.c.r.a.AllocationService] [desk] Cluster health status changed from [RED] to [YELLOW] (reason: [shards started [[zammad_production_organization][0]]]).
[2021-01-15T01:30:00,002][INFO ][o.e.x.s.SnapshotRetentionTask] [desk] starting SLM retention snapshot cleanup task
[2021-01-15T01:30:00,004][INFO ][o.e.x.s.SnapshotRetentionTask] [desk] there are no repositories to fetch, SLM retention snapshot cleanup task complete
- Zammad log (when sending message to Telegram bot):
root@desk:~# tail -f /var/log/zammad/production.log
I, [2021-01-15T10:40:41.520612 #109-47155045989480] INFO -- : Started POST "/api/v1/channels_telegram_webhook/{TOKEN}?bid=1590784921" for 10.0.0.100 at 2021-01-15 10:40:41 +0000
I, [2021-01-15T10:40:41.526019 #109-47155045989480] INFO -- : Processing by ChannelsTelegramController#webhook as HTML
I, [2021-01-15T10:40:41.526118 #109-47155045989480] INFO -- : Parameters: {"update_id"=>432820168, "message"=>{"message_id"=>31, "from"=>{"id"=>545000260, "is_bot"=>false, "first_name"=>"fname", "last_name"=>"lname", "username"=>"phynecs", "language_code"=>"en"}, "chat"=>{"id"=>545345260, "first_name"=>"fname", "last_name"=>"lname", "username"=>"phynecs", "type"=>"private"}, "date"=>1610707241, "text"=>"asd"}, "bid"=>"1590784921", "callback_token"=>"{TOKEN}"}
I, [2021-01-15T10:40:41.554760 #109-47155045989480] INFO -- : Enqueued SearchIndexJob (Job ID: c76927da-2d67-4afb-90cb-406793143424) to DelayedJob(default) with arguments: "User", 5
I, [2021-01-15T10:40:41.560343 #109-47155045989480] INFO -- : Enqueued SearchIndexAssociationsJob (Job ID: 147fdc6e-dab6-462c-ba5d-102770888f7a) to DelayedJob(default) with arguments: "User", 5
I, [2021-01-15T10:40:41.566412 #109-47155045989480] INFO -- : Won't enqueue SearchIndexJob (Job ID: 91a70d4d-57b4-4cb1-a422-4342cea1256f) because of already existing job with lock key 'SearchIndexJob/User/5'.
I, [2021-01-15T10:40:41.566556 #109-47155045989480] INFO -- : Enqueued SearchIndexJob (Job ID: 91a70d4d-57b4-4cb1-a422-4342cea1256f) to DelayedJob(default) with arguments: "User", 5
W, [2021-01-15T10:40:41.567602 #109-47155045989480] WARN -- : Scoped order is ignored, it's forced to be batch order.
I, [2021-01-15T10:40:41.585811 #109-47155045989480] INFO -- : Enqueued SearchIndexJob (Job ID: d3b164d3-4614-43b6-b6c7-bc92a31e392e) to DelayedJob(default) with arguments: "Ticket", 4
I, [2021-01-15T10:40:41.590706 #109-47155045989480] INFO -- : Enqueued SearchIndexAssociationsJob (Job ID: 3e1da4bc-7017-4ebd-99bc-e08eedb29743) to DelayedJob(default) with arguments: "Ticket", 4
I, [2021-01-15T10:40:41.595425 #109-47155045989480] INFO -- : Won't enqueue SearchIndexJob (Job ID: c5ac36d6-7091-4e39-8b47-d8161e4bdde7) because of already existing job with lock key 'SearchIndexJob/User/5'.
I, [2021-01-15T10:40:41.595573 #109-47155045989480] INFO -- : Enqueued SearchIndexJob (Job ID: c5ac36d6-7091-4e39-8b47-d8161e4bdde7) to DelayedJob(default) with arguments: "User", 5
I, [2021-01-15T10:40:41.654072 #109-47155045989480] INFO -- : Won't enqueue SearchIndexJob (Job ID: 24dba566-f6a3-47b8-895f-14b94f6cfff2) because of already existing job with lock key 'SearchIndexJob/Ticket/4'.
I, [2021-01-15T10:40:41.654216 #109-47155045989480] INFO -- : Enqueued SearchIndexJob (Job ID: 24dba566-f6a3-47b8-895f-14b94f6cfff2) to DelayedJob(default) with arguments: "Ticket", 4
I, [2021-01-15T10:40:41.655776 #109-47155045989480] INFO -- : Won't enqueue SearchIndexAssociationsJob (Job ID: 357338b4-7304-4f0e-a6d2-bb9010fe7027) because of already existing job with lock key 'SearchIndexAssociationsJob/Ticket/4'.
I, [2021-01-15T10:40:41.655906 #109-47155045989480] INFO -- : Enqueued SearchIndexAssociationsJob (Job ID: 357338b4-7304-4f0e-a6d2-bb9010fe7027) to DelayedJob(default) with arguments: "Ticket", 4
I, [2021-01-15T10:40:41.660413 #109-47155045989480] INFO -- : Won't enqueue SearchIndexJob (Job ID: 7a3e500e-b5c9-40b8-88de-a5de11bd7b4d) because of already existing job with lock key 'SearchIndexJob/User/5'.
I, [2021-01-15T10:40:41.660554 #109-47155045989480] INFO -- : Enqueued SearchIndexJob (Job ID: 7a3e500e-b5c9-40b8-88de-a5de11bd7b4d) to DelayedJob(default) with arguments: "User", 5
I, [2021-01-15T10:40:41.732019 #109-47155045989480] INFO -- : Enqueued TransactionJob (Job ID: 9f7bf72b-6ad2-4253-af55-9d911cb3eb59) to DelayedJob(default) with arguments: {:object=>"Ticket", :object_id=>4, :user_id=>5, :created_at=>#<GlobalID:0x000055c6473d93d0 @uri=#<URI::GID gid://zammad/Time/2021-01-15T10%3A40%3A41Z>>, :type=>"update", :article_id=>18}, {:reset_user_id=>true, :interface_handle=>"application_server"}
I, [2021-01-15T10:40:41.746815 #109-47155045989480] INFO -- : Enqueued TicketUserTicketCounterJob (Job ID: 2a2dd60c-5437-4e8b-b6ea-060ae32b0b58) to DelayedJob(default) with arguments: 5, 5
I, [2021-01-15T10:40:41.750641 #109-47155045989480] INFO -- : Completed 200 OK in 224ms (Views: 0.1ms | ActiveRecord: 41.4ms)
- Telegram Webhook Info
root@desk:~# curl "https://api.telegram.org/bot{TGTOKEN}/getWebhookInfo"
"ok": true,
"result": {
"url": "https://desk.{DOMAIN}.net/api/v1/channels_telegram_webhook/{TOKEN}?bid=1590784921",
"has_custom_certificate": false,
"pending_update_count": 0,
"max_connections": 40,
"ip_address": "{IPADDR}"
- further info
root@desk:~# free -h
total used free shared buff/cache available
Mem: 4.0Gi 2.1Gi 1.5Gi 37Mi 409Mi 1.9Gi
Swap: 4.0Gi 0.0Ki 4.0Gi
root@desk:~# df -h
Filesystem Size Used Avail Use% Mounted on
/dev/mapper/pve-vm--114--disk--0 9.8G 2.5G 6.9G 27% /
none 492K 4.0K 488K 1% /dev
udev 16G 0 16G 0% /dev/tty
tmpfs 16G 8.0K 16G 1% /dev/shm
tmpfs 16G 8.3M 16G 1% /run
tmpfs 5.0M 0 5.0M 0% /run/lock
tmpfs 16G 0 16G 0% /sys/fs/cgroup
- ticket gets opend in zammad when sending
/start
and a message to the connected Bot
- when sending
/start
the bot responds with the welcome message but no ticket will be created
- send
/start
to the bot and after the welcome message send a question
further Info
- I’m new to Zammad, so perhaps I misconfigured something
- I’m using an LDAP backend for the Agents
- The Server is installed on a Proxmox LXC container
- I don’t know of any other errors
- I’ll gladly send more info if needed
- thanks in advance for any help I get
- the server is behind an nginx proxy which also does the SSL fronting
