Docker-compose environment, webhooks
I first posted this issue on github
Maybe it’s preferred to ask this in the forum, so forgive me for copying this here:
Infos
  • Docker version: 18.06.1-ce
  • Docker-compose version: 1.13.0, build 1719ceb
  • Operating system (Docker host): Photon OS
I have a stack running zammad and a stack running an instance of webhook.site
Both run on the same docker host 192.168.97.160
Zammad is run behind HAproxy on a pfsense and reachable worldwide with a working https:// URL (using LetsEncrypt).
Configured a webhook plus a trigger in Zammad, the logs in Zammad show that the webhook is triggered, but I don’t see the request in the “webhook.site” GUI. Testing from my browser or local PC (curl) works fine.
So the question is: do I have to do anything special to the Zammad Docker stack to allow these outgoing requests maybe?
Expected behavior
  • webhooks created and triggered in Zammad show up in the webhook test site
Actual behavior
  • no requests get to the test “receiver”
Steps to reproduce the behavior
Sorry if I ask something obvious, I am new to webhooks …
additional
finding logs like:
zammad-scheduler_1      | I, [2022-11-18T10:40:26.758610 #1-109460]  INFO -- : 2022-11-18T10:40:26+0000: [Worker(host:07fde5f684aa pid:1)] Job TriggerWebhookJob [4db1488c-6040-4895-803e-f69bcb35a3d0] from DelayedJob(default) with arguments: [{"_aj_globalid"=>"gid://zammad/Trigger/5"}, {"_aj_globalid"=>"gid://zammad/Ticket/88"}, {"_aj_globalid"=>"gid://zammad/Ticket::Article/180"}] (id=6893) (queue=default) RUNNING
zammad-scheduler_1      | E, [2022-11-18T10:40:30.886436 #1-109460] ERROR -- : 2022-11-18T10:40:30+0000: [Worker(host:07fde5f684aa pid:1)] Job TriggerWebhookJob [4db1488c-6040-4895-803e-f69bcb35a3d0] from DelayedJob(default) with arguments: [{"_aj_globalid"=>"gid://zammad/Trigger/5"}, {"_aj_globalid"=>"gid://zammad/Ticket/88"}, {"_aj_globalid"=>"gid://zammad/Ticket::Article/180"}] (id=6893) (queue=default) FAILED (4 prior attempts) with TriggerWebhookJob::RequestError: TriggerWebhookJob::RequestError
zammad-scheduler_1      | E, [2022-11-18T10:40:30.886513 #1-109460] ERROR -- : 2022-11-18T10:40:30+0000: [Worker(host:07fde5f684aa pid:1)] Job TriggerWebhookJob [4db1488c-6040-4895-803e-f69bcb35a3d0] from DelayedJob(default) with arguments: [{"_aj_globalid"=>"gid://zammad/Trigger/5"}, {"_aj_globalid"=>"gid://zammad/Ticket/88"}, {"_aj_globalid"=>"gid://zammad/Ticket::Article/180"}] (id=6893) (queue=default) FAILED permanently because of 5 consecutive failures
Found Failed to run background job TriggerWebhookJob
My “other side” replies with Code 200, at least it seems to be configured like that.
Maybe important: the zammad-stack runs version 5.2.3-18
I am not sure which of the zammad containers actually calls the webhook.
I tried to join the webhook tester container to the zammad docker network and use the container IP in the URL. Still nothing popping up there.
The scheduler calls this kind of webhook. Usually in “normal” (aka non docker environments) the production.log would contain the information you’re looking for.
Looking into the log section of the webhook administration may help as well to find the reason why you can’t successfully talk to the remote system.
