I could possible see that I have to put the variable on a different container.
Tipps for me on how to pass the json to the right(? maybe all) container/s
But what after visiting works is the main URL:
Old so used to setup screen. I’m still here to get rid of you!11
Ok anyway, after we are here, just click it…
pasting in some awesome credentials with upper and lower numbers and just a little blood of my firstborn child… and then a but
So something works
now stuff might get a little more interesting
## hit autowizzardy
zammad-scheduler_1 | I, [2021-09-22T13:18:21.997340 #1-47203169039160] INFO -- : execute StatsStore.cleanup (try_count 0)...
zammad-scheduler_1 | I, [2021-09-22T13:18:21.999394 #1-47203169039160] INFO -- : ended StatsStore.cleanup took: 0.013482423 seconds.
zammad-railsserver_1 | I, [2021-09-22T13:18:26.517849 #1-47432698411520] INFO -- : Started GET "/" for 9.12.9.4 at 2021-09-22 13:18:26 +0000
zammad-railsserver_1 | I, [2021-09-22T13:18:26.530755 #1-47432698411520] INFO -- : Processing by InitController#index as HTML
zammad-railsserver_1 | I, [2021-09-22T13:18:26.531876 #1-47432698411520] INFO -- : Rendering init/index.html.erb within layouts/application
zammad-railsserver_1 | I, [2021-09-22T13:18:26.532192 #1-47432698411520] INFO -- : Rendered init/index.html.erb within layouts/application (0.2ms)
zammad-railsserver_1 | I, [2021-09-22T13:18:26.534231 #1-47432698411520] INFO -- : Completed 200 OK in 3ms (Views: 1.4ms | ActiveRecord: 0.4ms)
waf_1 | <donttouchmygarbage.url> 9.12.9.4 - - [22/Sep/2021:13:18:26 +0000] "GET / HTTP/2.0" 200 1180 "-" "Mozilla/5.0 (X11; Fedora; Linux x86_64; rv:92.0) Gecko/20100101 Firefox/92.0"
zammad-railsserver_1 | I, [2021-09-22T13:18:27.122348 #1-47432698410780] INFO -- : Started POST "/api/v1/signshow" for 9.12.9.4 at 2021-09-22 13:18:27 +0000
zammad-railsserver_1 | I, [2021-09-22T13:18:27.132192 #1-47432698410780] INFO -- : Processing by SessionsController#show as JSON
zammad-railsserver_1 | I, [2021-09-22T13:18:27.132389 #1-47432698410780] INFO -- : Parameters: {"fingerprint"=>"429385428"}
zammad-railsserver_1 | I, [2021-09-22T13:18:27.186685 #1-47432698410780] INFO -- : Completed 200 OK in 54ms (Views: 7.5ms | ActiveRecord: 11.6ms)
waf_1 | <donttouchmygarbage.url> 9.12.9.4 - - [22/Sep/2021:13:18:27 +0000] "POST /api/v1/signshow HTTP/2.0" 200 3118 "-" "Mozilla/5.0 (X11; Fedora; Linux x86_64; rv:92.0) Gecko/20100101 Firefox/92.0"
zammad-railsserver_1 | I, [2021-09-22T13:18:27.240436 #1-47432698410500] INFO -- : Started GET "/api/v1/translations/lang/en-gb?_=1632316706851" for 9.12.9.4 at 2021-09-22 13:18:27 +0000
zammad-railsserver_1 | I, [2021-09-22T13:18:27.248952 #1-47432698410500] INFO -- : Processing by TranslationsController#lang as JSON
zammad-railsserver_1 | I, [2021-09-22T13:18:27.249057 #1-47432698410500] INFO -- : Parameters: {"_"=>"1632316706851", "locale"=>"en-gb"}
zammad-railsserver_1 | I, [2021-09-22T13:18:27.251792 #1-47432698410500] INFO -- : Completed 200 OK in 3ms (Views: 0.3ms | ActiveRecord: 0.4ms)
waf_1 | <donttouchmygarbage.url> 9.12.9.4 - - [22/Sep/2021:13:18:27 +0000] "GET /api/v1/translations/lang/en-gb?_=1632316706851 HTTP/2.0" 200 119 "-" "Mozilla/5.0 (X11; Fedora; Linux x86_64; rv:92.0) Gecko/20100101 Firefox/92.0"
zammad-railsserver_1 | I, [2021-09-22T13:18:27.387518 #1-47432698411140] INFO -- : Started GET "/api/v1/getting_started/auto_wizard/631a167d79113eafe51c84194d2bee7d4542944f2fedcb3987d97bbea4350805caa26228eea73e595827ed48eb9fd317c9ad69123f2a75507136a17f002b4435?_=1632316706852" for 9.12.9.4 at 2021-09-22 13:18:27 +0000
zammad-railsserver_1 | I, [2021-09-22T13:18:27.401142 #1-47432698411140] INFO -- : Processing by GettingStartedController#auto_wizard_admin as JSON
zammad-railsserver_1 | I, [2021-09-22T13:18:27.401214 #1-47432698411140] INFO -- : Parameters: {"_"=>"1632316706852", "token"=>"631a167d79113eafe51c84194d2bee7d4542944f2fedcb3987d97bbea4350805caa26228eea73e595827ed48eb9fd317c9ad69123f2a75507136a17f002b4435"}
zammad-railsserver_1 | I, [2021-09-22T13:18:27.701741 #1-47432698411140] INFO -- : Setting.set('developer_mode', false)
zammad-railsserver_1 | I, [2021-09-22T13:18:27.712746 #1-47432698411140] INFO -- : Setting.set('product_name', "Support System")
zammad-railsserver_1 | I, [2021-09-22T13:18:27.721657 #1-47432698411140] INFO -- : Setting.set('system_online_service', true)
zammad-railsserver_1 | I, [2021-09-22T13:18:28.244199 #1-47432698411140] INFO -- : Can't fetch image for 'test@mycrappy.url' (maybe no avatar available), http code: 422
zammad-railsserver_1 | I, [2021-09-22T13:18:28.372121 #1-47432698411140] INFO -- : Fetched image for 'mycrappy.url', http code: 200
zammad-railsserver_1 | I, [2021-09-22T13:18:28.417892 #1-47432698411140] INFO -- : NOTICE create - self.created_by_id is different: 1/3
zammad-railsserver_1 | I, [2021-09-22T13:18:28.457223 #1-47432698411140] INFO -- : Setting.set('product_logo', "bd7d94fe6d9fe0e21e7acd145f32105d.png")
zammad-railsserver_1 | I, [2021-09-22T13:18:28.471947 #1-47432698411140] INFO -- : Setting.set('product_logo', "bd7d94fe6d9fe0e21e7acd145f32105d.png")
zammad-railsserver_1 | E, [2021-09-22T13:18:28.474846 #1-47432698411140] ERROR -- : No lookup value found for 'organization': "Your Support Team22" (Exceptions::UnprocessableEntity)
zammad-railsserver_1 | /opt/zammad/app/models/application_model/can_associations.rb:381:in `block in association_name_to_id_convert'
zammad-railsserver_1 | /opt/zammad/app/models/application_model/can_associations.rb:349:in `map'
zammad-railsserver_1 | /opt/zammad/app/models/application_model/can_associations.rb:349:in `association_name_to_id_convert'
zammad-railsserver_1 | /opt/zammad/app/models/application_model/can_creates_and_updates.rb:77:in `create_or_update_with_ref'
zammad-railsserver_1 | /opt/zammad/lib/auto_wizard.rb:114:in `block in setup'
zammad-railsserver_1 | /opt/zammad/lib/auto_wizard.rb:102:in `each'
zammad-railsserver_1 | /opt/zammad/lib/auto_wizard.rb:102:in `setup'
zammad-railsserver_1 | /opt/zammad/app/controllers/getting_started_controller.rb:84:in `auto_wizard_admin'
zammad-railsserver_1 | /usr/local/bundle/gems/actionpack-5.2.4.6/lib/action_controller/metal/basic_implicit_render.rb:6:in `send_action'
zammad-railsserver_1 | /usr/local/bundle/gems/actionpack-5.2.4.6/lib/abstract_controller/base.rb:194:in `process_action'
zammad-railsserver_1 | /usr/local/bundle/gems/actionpack-5.2.4.6/lib/action_controller/metal/rendering.rb:30:in `process_action'
zammad-railsserver_1 | /usr/local/bundle/gems/actionpack-5.2.4.6/lib/abstract_controller/callbacks.rb:42:in `block in process_action'
zammad-railsserver_1 | /usr/local/bundle/gems/activesupport-5.2.4.6/lib/active_support/callbacks.rb:109:in `block in run_callbacks'
zammad-railsserver_1 | /opt/zammad/app/controllers/application_controller/has_secure_content_security_policy_for_downloads.rb:18:in `block (4 levels) in <module:HasSecureContentSecurityPolicyForDownloads>'
zammad-railsserver_1 | /usr/local/bundle/gems/activesupport-5.2.4.6/lib/active_support/notifications.rb:180:in `subscribed'
zammad-railsserver_1 | /opt/zammad/app/controllers/application_controller/has_secure_content_security_policy_for_downloads.rb:17:in `block (3 levels) in <module:HasSecureContentSecurityPolicyForDownloads>'
zammad-railsserver_1 | /opt/zammad/app/controllers/application_controller/has_secure_content_security_policy_for_downloads.rb:16:in `block (2 levels) in <module:HasSecureContentSecurityPolicyForDownloads>'
zammad-railsserver_1 | /usr/local/bundle/gems/activesupport-5.2.4.6/lib/active_support/callbacks.rb:118:in `instance_exec'
zammad-railsserver_1 | /usr/local/bundle/gems/activesupport-5.2.4.6/lib/active_support/callbacks.rb:118:in `block in run_callbacks'
zammad-railsserver_1 | /opt/zammad/app/controllers/application_controller/handles_transitions.rb:14:in `handle_transaction'
zammad-railsserver_1 | /usr/local/bundle/gems/activesupport-5.2.4.6/lib/active_support/callbacks.rb:136:in `run_callbacks'
zammad-railsserver_1 | /usr/local/bundle/gems/actionpack-5.2.4.6/lib/abstract_controller/callbacks.rb:41:in `process_action'
zammad-railsserver_1 | /usr/local/bundle/gems/actionpack-5.2.4.6/lib/action_controller/metal/rescue.rb:22:in `process_action'
zammad-railsserver_1 | /usr/local/bundle/gems/actionpack-5.2.4.6/lib/action_controller/metal/instrumentation.rb:34:in `block in process_action'
zammad-railsserver_1 | /usr/local/bundle/gems/activesupport-5.2.4.6/lib/active_support/notifications.rb:168:in `block in instrument'
zammad-railsserver_1 | /usr/local/bundle/gems/activesupport-5.2.4.6/lib/active_support/notifications/instrumenter.rb:23:in `instrument'
zammad-railsserver_1 | /usr/local/bundle/gems/activesupport-5.2.4.6/lib/active_support/notifications.rb:168:in `instrument'
zammad-railsserver_1 | /usr/local/bundle/gems/actionpack-5.2.4.6/lib/action_controller/metal/instrumentation.rb:32:in `process_action'
zammad-railsserver_1 | /usr/local/bundle/gems/actionpack-5.2.4.6/lib/action_controller/metal/params_wrapper.rb:256:in `process_action'
zammad-railsserver_1 | /usr/local/bundle/gems/activerecord-5.2.4.6/lib/active_record/railties/controller_runtime.rb:24:in `process_action'
zammad-railsserver_1 | /usr/local/bundle/gems/actionpack-5.2.4.6/lib/abstract_controller/base.rb:134:in `process'
zammad-railsserver_1 | /usr/local/bundle/gems/actionview-5.2.4.6/lib/action_view/rendering.rb:32:in `process'
zammad-railsserver_1 | /usr/local/bundle/gems/actionpack-5.2.4.6/lib/action_controller/metal.rb:191:in `dispatch'
zammad-railsserver_1 | /usr/local/bundle/gems/actionpack-5.2.4.6/lib/action_controller/metal.rb:252:in `dispatch'
zammad-railsserver_1 | /usr/local/bundle/gems/actionpack-5.2.4.6/lib/action_dispatch/routing/route_set.rb:52:in `dispatch'
zammad-railsserver_1 | /usr/local/bundle/gems/actionpack-5.2.4.6/lib/action_dispatch/routing/route_set.rb:34:in `serve'
zammad-railsserver_1 | /usr/local/bundle/gems/actionpack-5.2.4.6/lib/action_dispatch/journey/router.rb:52:in `block in serve'
zammad-railsserver_1 | /usr/local/bundle/gems/actionpack-5.2.4.6/lib/action_dispatch/journey/router.rb:35:in `each'
zammad-railsserver_1 | /usr/local/bundle/gems/actionpack-5.2.4.6/lib/action_dispatch/journey/router.rb:35:in `serve'
zammad-railsserver_1 | /usr/local/bundle/gems/actionpack-5.2.4.6/lib/action_dispatch/routing/route_set.rb:840:in `call'
zammad-railsserver_1 | /usr/local/bundle/gems/omniauth-1.9.1/lib/omniauth/strategy.rb:420:in `call_app!'
zammad-railsserver_1 | /usr/local/bundle/gems/omniauth-saml-1.10.1/lib/omniauth/strategies/saml.rb:89:in `other_phase'
zammad-railsserver_1 | /usr/local/bundle/gems/omniauth-1.9.1/lib/omniauth/strategy.rb:190:in `call!'
zammad-railsserver_1 | /usr/local/bundle/gems/omniauth-1.9.1/lib/omniauth/strategy.rb:169:in `call'
zammad-railsserver_1 | /usr/local/bundle/gems/omniauth-1.9.1/lib/omniauth/strategy.rb:192:in `call!'
zammad-railsserver_1 | /usr/local/bundle/gems/omniauth-1.9.1/lib/omniauth/builder.rb:45:in `call'
zammad-railsserver_1 | /usr/local/bundle/gems/rack-2.2.3/lib/rack/tempfile_reaper.rb:15:in `call'
zammad-railsserver_1 | /usr/local/bundle/gems/rack-2.2.3/lib/rack/etag.rb:27:in `call'
zammad-railsserver_1 | /usr/local/bundle/gems/rack-2.2.3/lib/rack/conditional_get.rb:27:in `call'
zammad-railsserver_1 | /usr/local/bundle/gems/rack-2.2.3/lib/rack/head.rb:12:in `call'
zammad-railsserver_1 | /usr/local/bundle/gems/actionpack-5.2.4.6/lib/action_dispatch/http/content_security_policy.rb:18:in `call'
zammad-railsserver_1 | /usr/local/bundle/gems/rack-2.2.3/lib/rack/session/abstract/id.rb:266:in `context'
zammad-railsserver_1 | /usr/local/bundle/gems/rack-2.2.3/lib/rack/session/abstract/id.rb:260:in `call'
zammad-railsserver_1 | /usr/local/bundle/gems/actionpack-5.2.4.6/lib/action_dispatch/middleware/cookies.rb:670:in `call'
zammad-railsserver_1 | /usr/local/bundle/gems/actionpack-5.2.4.6/lib/action_dispatch/middleware/callbacks.rb:28:in `block in call'
zammad-railsserver_1 | /usr/local/bundle/gems/activesupport-5.2.4.6/lib/active_support/callbacks.rb:98:in `run_callbacks'
zammad-railsserver_1 | /usr/local/bundle/gems/actionpack-5.2.4.6/lib/action_dispatch/middleware/callbacks.rb:26:in `call'
zammad-railsserver_1 | /usr/local/bundle/gems/actionpack-5.2.4.6/lib/action_dispatch/middleware/debug_exceptions.rb:61:in `call'
zammad-railsserver_1 | /usr/local/bundle/gems/actionpack-5.2.4.6/lib/action_dispatch/middleware/show_exceptions.rb:33:in `call'
zammad-railsserver_1 | /usr/local/bundle/gems/railties-5.2.4.6/lib/rails/rack/logger.rb:38:in `call_app'
zammad-railsserver_1 | /usr/local/bundle/gems/railties-5.2.4.6/lib/rails/rack/logger.rb:26:in `block in call'
zammad-railsserver_1 | /usr/local/bundle/gems/activesupport-5.2.4.6/lib/active_support/tagged_logging.rb:71:in `block in tagged'
zammad-railsserver_1 | /usr/local/bundle/gems/activesupport-5.2.4.6/lib/active_support/tagged_logging.rb:28:in `tagged'
zammad-railsserver_1 | /usr/local/bundle/gems/activesupport-5.2.4.6/lib/active_support/tagged_logging.rb:71:in `tagged'
zammad-railsserver_1 | /usr/local/bundle/gems/railties-5.2.4.6/lib/rails/rack/logger.rb:26:in `call'
zammad-railsserver_1 | /usr/local/bundle/gems/actionpack-5.2.4.6/lib/action_dispatch/middleware/remote_ip.rb:81:in `call'
zammad-railsserver_1 | /usr/local/bundle/gems/actionpack-5.2.4.6/lib/action_dispatch/middleware/request_id.rb:27:in `call'
zammad-railsserver_1 | /usr/local/bundle/gems/rack-2.2.3/lib/rack/method_override.rb:24:in `call'
zammad-railsserver_1 | /usr/local/bundle/gems/rack-2.2.3/lib/rack/runtime.rb:22:in `call'
zammad-railsserver_1 | /usr/local/bundle/gems/activesupport-5.2.4.6/lib/active_support/cache/strategy/local_cache_middleware.rb:29:in `call'
zammad-railsserver_1 | /usr/local/bundle/gems/actionpack-5.2.4.6/lib/action_dispatch/middleware/executor.rb:14:in `call'
zammad-railsserver_1 | /usr/local/bundle/gems/actionpack-5.2.4.6/lib/action_dispatch/middleware/static.rb:127:in `call'
zammad-railsserver_1 | /usr/local/bundle/gems/rack-2.2.3/lib/rack/sendfile.rb:110:in `call'
zammad-railsserver_1 | /usr/local/bundle/gems/railties-5.2.4.6/lib/rails/engine.rb:524:in `call'
zammad-railsserver_1 | /usr/local/bundle/gems/puma-4.3.8/lib/puma/configuration.rb:228:in `call'
zammad-railsserver_1 | /usr/local/bundle/gems/puma-4.3.8/lib/puma/server.rb:718:in `handle_request'
zammad-railsserver_1 | /usr/local/bundle/gems/puma-4.3.8/lib/puma/server.rb:472:in `process_client'
zammad-railsserver_1 | /usr/local/bundle/gems/puma-4.3.8/lib/puma/server.rb:328:in `block in run'
zammad-railsserver_1 | /usr/local/bundle/gems/puma-4.3.8/lib/puma/thread_pool.rb:134:in `block in spawn_thread'
zammad-railsserver_1 | /usr/local/bundle/gems/logging-2.2.2/lib/logging/diagnostic_context.rb:474:in `block in create_with_logging_context'
zammad-railsserver_1 | I, [2021-09-22T13:18:28.475539 #1-47432698411140] INFO -- : Completed 422 Unprocessable Entity in 1074ms (Views: 0.1ms | ActiveRecord: 250.7ms)
waf_1 | <donttouchmygarbage.url> 9.12.9.4 - - [22/Sep/2021:13:18:28 +0000] "GET /api/v1/getting_started/auto_wizard/631a167d79113eafe51c84194d2bee7d4542944f2fedcb3987d97bbea4350805caa26228eea73e595827ed48eb9fd317c9ad69123f2a75507136a17f002b4435?_=1632316706852 HTTP/2.0" 422 159 "-" "Mozilla/5.0 (X11; Fedora; Linux x86_64; rv:92.0) Gecko/20100101 Firefox/92.0"
zammad-scheduler_1 | I, [2021-09-22T13:18:29.183557 #1-47203189601560] INFO -- : 2021-09-22T13:18:29+0000: [Worker(host:aa1db5848acf pid:1)] Job SearchIndexAssociationsJob [6a6635a2-7a19-4e10-9f6d-fac0113d841d] from DelayedJob(default) with arguments: ["Organization", 2] (id=14) (queue=default) RUNNING
zammad-scheduler_1 | I, [2021-09-22T13:18:29.313035 #1-47203189601560] INFO -- : 2021-09-22T13:18:29+0000: [Worker(host:aa1db5848acf pid:1)] Job SearchIndexAssociationsJob [6a6635a2-7a19-4e10-9f6d-fac0113d841d] from DelayedJob(default) with arguments: ["Organization", 2] (id=14) (queue=default) COMPLETED after 0.1292
zammad-scheduler_1 | I, [2021-09-22T13:18:29.317842 #1-47203189601560] INFO -- : 2021-09-22T13:18:29+0000: [Worker(host:aa1db5848acf pid:1)] Job SearchIndexAssociationsJob [e9861fae-49f0-4294-abb0-6c161634901d] from DelayedJob(default) with arguments: ["Organization", 3] (id=15) (queue=default) RUNNING
zammad-elasticsearch_1 | {"type": "server", "timestamp": "2021-09-22T13:18:29,381Z", "level": "INFO", "component": "o.e.c.m.MetadataMappingService", "cluster.name": "docker-cluster", "node.name": "387d9e0ac581", "message": "[zammad_production_organization/in6QA4ilSg6QcaF9pupYcg] update_mapping [_doc]", "cluster.uuid": "fERnnjgkQ2umzpCkl9xuHw", "node.id": "MyBclUG3SBSbau4Xb18vAw" }
zammad-scheduler_1 | I, [2021-09-22T13:18:29.768786 #1-47203189601560] INFO -- : 2021-09-22T13:18:29+0000: [Worker(host:aa1db5848acf pid:1)] Job SearchIndexAssociationsJob [e9861fae-49f0-4294-abb0-6c161634901d] from DelayedJob(default) with arguments: ["Organization", 3] (id=15) (queue=default) COMPLETED after 0.4507
zammad-scheduler_1 | I, [2021-09-22T13:18:29.798887 #1-47203189601560] INFO -- : 2021-09-22T13:18:29+0000: [Worker(host:aa1db5848acf pid:1)] Job SearchIndexAssociationsJob [23513878-5fe2-4b3f-9a35-c3b108b68a20] from DelayedJob(default) with arguments: ["User", 3] (id=17) (queue=default) RUNNING
zammad-elasticsearch_1 | {"type": "server", "timestamp": "2021-09-22T13:18:29,925Z", "level": "INFO", "component": "o.e.c.m.MetadataMappingService", "cluster.name": "docker-cluster", "node.name": "387d9e0ac581", "message": "[zammad_production_user/NnpPXGwyQFazdggebKTsGQ] update_mapping [_doc]", "cluster.uuid": "fERnnjgkQ2umzpCkl9xuHw", "node.id": "MyBclUG3SBSbau4Xb18vAw" }
zammad-scheduler_1 | I, [2021-09-22T13:18:30.993312 #1-47203189601560] INFO -- : 2021-09-22T13:18:30+0000: [Worker(host:aa1db5848acf pid:1)] Job SearchIndexAssociationsJob [23513878-5fe2-4b3f-9a35-c3b108b68a20] from DelayedJob(default) with arguments: ["User", 3] (id=17) (queue=default) COMPLETED after 1.1942
zammad-scheduler_1 | I, [2021-09-22T13:18:30.998622 #1-47203189601560] INFO -- : 2021-09-22T13:18:30+0000: [Worker(host:aa1db5848acf pid:1)] Job SearchIndexJob [f84eff4b-8185-446f-9f27-329447060857] from DelayedJob(default) with arguments: ["Group", 1] (id=18) (queue=default) RUNNING
zammad-scheduler_1 | I, [2021-09-22T13:18:31.055685 #1-47203189601560] INFO -- : 2021-09-22T13:18:31+0000: [Worker(host:aa1db5848acf pid:1)] Job SearchIndexJob [f84eff4b-8185-446f-9f27-329447060857] from DelayedJob(default) with arguments: ["Group", 1] (id=18) (queue=default) COMPLETED after 0.0569
zammad-scheduler_1 | I, [2021-09-22T13:18:31.061941 #1-47203189601560] INFO -- : 2021-09-22T13:18:31+0000: [Worker(host:aa1db5848acf pid:1)] Job SearchIndexJob [c9d97e6f-d6cd-44d1-a532-45136b10f314] from DelayedJob(default) with arguments: ["User", 3] (id=19) (queue=default) RUNNING
zammad-scheduler_1 | I, [2021-09-22T13:18:31.159216 #1-47203189601560] INFO -- : 2021-09-22T13:18:31+0000: [Worker(host:aa1db5848acf pid:1)] Job SearchIndexJob [c9d97e6f-d6cd-44d1-a532-45136b10f314] from DelayedJob(default) with arguments: ["User", 3] (id=19) (queue=default) COMPLETED after 0.0971
zammad-scheduler_1 | I, [2021-09-22T13:18:31.164211 #1-47203189601560] INFO -- : 2021-09-22T13:18:31+0000: [Worker(host:aa1db5848acf pid:1)] Job SearchIndexJob [fd8317bf-966b-4052-824e-3b77c2620d4b] from DelayedJob(default) with arguments: ["Organization", 3] (id=20) (queue=default) RUNNING
zammad-scheduler_1 | I, [2021-09-22T13:18:31.277340 #1-47203189601560] INFO -- : 2021-09-22T13:18:31+0000: [Worker(host:aa1db5848acf pid:1)] Job SearchIndexJob [fd8317bf-966b-4052-824e-3b77c2620d4b] from DelayedJob(default) with arguments: ["Organization", 3] (id=20) (queue=default) COMPLETED after 0.1130
zammad-scheduler_1 | I, [2021-09-22T13:18:32.009320 #1-47203138861260] INFO -- : execute HttpLog.cleanup (try_count 0)...
zammad-scheduler_1 | I, [2021-09-22T13:18:32.011648 #1-47203138861260] INFO -- : ended HttpLog.cleanup took: 0.015443571 seconds.
zammad-scheduler_1 | I, [2021-09-22T13:18:32.012055 #1-47203179361320] INFO -- : execute Channel.fetch (try_count 0)...
zammad-scheduler_1 | I, [2021-09-22T13:18:32.013544 #1-47203179361320] INFO -- : ended Channel.fetch took: 0.011389435 seconds.
zammad-scheduler_1 | I, [2021-09-22T13:18:39.299043 #1-47203189601560] INFO -- : 2021-09-22T13:18:39+0000: [Worker(host:aa1db5848acf pid:1)] Job TicketCreateScreenJob [b68d8008-a928-455b-89e2-c5fc7bce9dcf] from DelayedJob(default) with arguments: [] (id=16) (queue=default) RUNNING
zammad-scheduler_1 | I, [2021-09-22T13:18:39.340094 #1-47203189601560] INFO -- : 2021-09-22T13:18:39+0000: [Worker(host:aa1db5848acf pid:1)] Job TicketCreateScreenJob [b68d8008-a928-455b-89e2-c5fc7bce9dcf] from DelayedJob(default) with arguments: [] (id=16) (queue=default) COMPLETED after 0.0408
zammad-scheduler_1 | I, [2021-09-22T13:18:39.344288 #1-47203189601560] INFO -- : 2021-09-22T13:18:39+0000: [Worker(host:aa1db5848acf pid:1)] Job CollectionUpdateJob [e84e55c2-efa7-4790-a106-27ac7922b9a6] from DelayedJob(default) with arguments: ["Group"] (id=21) (queue=default) RUNNING
zammad-scheduler_1 | W, [2021-09-22T13:18:39.367759 #1-47203189601560] WARN -- : Scoped order is ignored, it's forced to be batch order.
zammad-scheduler_1 | I, [2021-09-22T13:18:39.384109 #1-47203189601560] INFO -- : 2021-09-22T13:18:39+0000: [Worker(host:aa1db5848acf pid:1)] Job CollectionUpdateJob [e84e55c2-efa7-4790-a106-27ac7922b9a6] from DelayedJob(default) with arguments: ["Group"] (id=21) (queue=default) COMPLETED after 0.0397
zammad-scheduler_1 | I, [2021-09-22T13:18:42.016193 #1-47203168769600] INFO -- : execute Cti::Log.cleanup (try_count 0)...
zammad-scheduler_1 | I, [2021-09-22T13:18:42.019422 #1-47203168769600] INFO -- : ended Cti::Log.cleanup took: 0.015151484 seconds.
zammad-scheduler_1 | I, [2021-09-22T13:18:52.026593 #1-47203169991440] INFO -- : execute ImapAuthenticationMigrationCleanupJob.perform_now (try_count 0)...
zammad-scheduler_1 | I, [2021-09-22T13:18:52.034726 #1-47203169991440] INFO -- : ended ImapAuthenticationMigrationCleanupJob.perform_now took: 0.01925306 seconds.
zammad-scheduler_1 | I, [2021-09-22T13:19:02.027509 #1-47203179361320] INFO -- : execute Channel.fetch (try_count 0)...
zammad-scheduler_1 | I, [2021-09-22T13:19:02.029279 #1-47203179361320] INFO -- : ended Channel.fetch took: 0.013908667 seconds.
zammad-scheduler_1 | I, [2021-09-22T13:19:02.032693 #1-47203171016100] INFO -- : execute Job.run (try_count 0)...
zammad-scheduler_1 | I, [2021-09-22T13:19:02.034710 #1-47203171016100] INFO -- : ended Job.run took: 0.01485032 seconds.
might be related to
zammad-railsserver_1 | E, [2021-09-22T13:18:28.474846 #1-47432698411140] ERROR – : No lookup value found for ‘organization’: “Your Support Team22” (Exceptions::UnprocessableEntity)
lets see if stuff works out when I find something related to organisation
most welcome,
Keep questions flowing. currently, I know stuff that I ll forget soon
not yet completely happy with it.
Important settings (settings you cant change in the UI anymore) are missing like fqdn, and http_type. idk if system_id is something important to set.
I currently use the browser’s developer tools to dig me through but meh…
Currently searching for the Groups setup.
also came across some oddities.
Like running rails zammad:setup:auto_wizard auto_wizard.json inside of the container (hoped I can test out changes faster) gives me a reset to I, [2021-09-23T13:28:06.357431 #44-47388411042140] INFO -- : Setting.set('product_name', "Zammad Test System").
anyway? Is there maybe API documentation I didnt stumbled across yet?
