I try to install zammad version 3.3.x on Ubuntu 22.04 LTS. Also I tried to install from package.
But now it seems the package URL is not exist and when I want to open the URL in browser I got Not found error.
I used this command to add repository:
We want to upgrade our Os version to Ubuntu 22.04 LTS.
Also, we want to Migrate the existing zammad 3.1.x (Os : Centos7) to new Ubuntu server and zamamd latest version.
As I understand we are not able to migrate that directly. But also I have problem with migration steps.
Could you please explain more about to do steps?
Note that you may want to update to ~ Zammad 5.0.x on the source system. This is the last version that supports older postgresql installations but also comes with the new improved backup and restore scripts.
Also I set FULL_FS_DUMP to no as you mentioned.
But I have still error when I am trying to run zammad run rails r "Rails.cache.clear"
I got this error.
29: from /opt/zammad/bin/rails:8:in `<main>'
28: from /opt/zammad/bin/rails:8:in `require_relative'
27: from /opt/zammad/config/boot.rb:3:in `<top (required)>'
26: from /opt/zammad/vendor/ruby-2.5.5/lib/ruby/2.5.0/rubygems/core_ext/kernel_require.rb:39:in `require'
25: from /opt/zammad/vendor/ruby-2.5.5/lib/ruby/2.5.0/rubygems/core_ext/kernel_require.rb:135:in `rescue in require'
24: from /opt/zammad/vendor/ruby-2.5.5/lib/ruby/2.5.0/rubygems/core_ext/kernel_require.rb:135:in `require'
23: from /opt/zammad/vendor/bundle/ruby/2.5.0/gems/bundler-1.17.3/lib/bundler/setup.rb:10:in `<top (required)>'
22: from /opt/zammad/vendor/bundle/ruby/2.5.0/gems/bundler-1.17.3/lib/bundler.rb:101:in `setup'
21: from /opt/zammad/vendor/bundle/ruby/2.5.0/gems/bundler-1.17.3/lib/bundler.rb:135:in `definition'
20: from /opt/zammad/vendor/bundle/ruby/2.5.0/gems/bundler-1.17.3/lib/bundler/definition.rb:34:in `build'
19: from /opt/zammad/vendor/bundle/ruby/2.5.0/gems/bundler-1.17.3/lib/bundler/dsl.rb:13:in `evaluate'
18: from /opt/zammad/vendor/bundle/ruby/2.5.0/gems/bundler-1.17.3/lib/bundler/dsl.rb:234:in `to_definition'
17: from /opt/zammad/vendor/bundle/ruby/2.5.0/gems/bundler-1.17.3/lib/bundler/dsl.rb:234:in `new'
16: from /opt/zammad/vendor/bundle/ruby/2.5.0/gems/bundler-1.17.3/lib/bundler/definition.rb:120:in `initialize'
15: from /opt/zammad/vendor/bundle/ruby/2.5.0/gems/bundler-1.17.3/lib/bundler/definition.rb:674:in `converge_sources'
14: from /opt/zammad/vendor/bundle/ruby/2.5.0/gems/bundler-1.17.3/lib/bundler/source_list.rb:104:in `replace_sources!'
13: from /opt/zammad/vendor/bundle/ruby/2.5.0/gems/bundler-1.17.3/lib/bundler/source_list.rb:85:in `lock_sources'
12: from /opt/zammad/vendor/bundle/ruby/2.5.0/gems/bundler-1.17.3/lib/bundler/source_list.rb:85:in `sort_by'
11: from /opt/zammad/vendor/bundle/ruby/2.5.0/gems/bundler-1.17.3/lib/bundler/source_list.rb:85:in `each'
10: from /opt/zammad/vendor/bundle/ruby/2.5.0/gems/bundler-1.17.3/lib/bundler/source/git.rb:76:in `to_s'
9: from /opt/zammad/vendor/bundle/ruby/2.5.0/gems/bundler-1.17.3/lib/bundler/source/git.rb:225:in `revision'
8: from /opt/zammad/vendor/bundle/ruby/2.5.0/gems/bundler-1.17.3/lib/bundler/source/git.rb:299:in `git_proxy'
7: from /opt/zammad/vendor/bundle/ruby/2.5.0/gems/bundler-1.17.3/lib/bundler/source/git.rb:216:in `cache_path'
6: from /opt/zammad/vendor/bundle/ruby/2.5.0/gems/bundler-1.17.3/lib/bundler/source/git.rb:321:in `git_scope'
5: from /opt/zammad/vendor/bundle/ruby/2.5.0/gems/bundler-1.17.3/lib/bundler/source/git.rb:287:in `uri_hash'
4: from /opt/zammad/vendor/bundle/ruby/2.5.0/gems/bundler-1.17.3/lib/bundler/shared_helpers.rb:225:in `digest'
3: from /opt/zammad/vendor/ruby-2.5.5/lib/ruby/2.5.0/digest.rb:98:in `Digest'
2: from /opt/zammad/vendor/ruby-2.5.5/lib/ruby/2.5.0/digest.rb:98:in `synchronize'
1: from /opt/zammad/vendor/ruby-2.5.5/lib/ruby/2.5.0/digest.rb:100:in `block in Digest'
/opt/zammad/vendor/ruby-2.5.5/lib/ruby/2.5.0/digest.rb:16:in `const_missing': library not found for class Digest::SHA1 -- digest/sha1 (LoadError)
Old server: Centos7 , Zammad version: 3.1.x (3.1.0)
New Server: Ubuntu 16.04 LTS , Zammad version: 3.1.x
