Is it possible to restrict the option to create a ticket template to a defined user group (role)?
I would like to create these templates as an administrator so that only these would be available for the agents.
and / or the option to disable the possibility to use a template.
I think I did not explain it good.
It is not a problem that the templates available for all users.
I would like to restrict the option to create a template.
