Disable indentation
  • Used Zammad version: 6.4.1
  • Used Zammad installation type: Docker Compose
  • Operating system: Ubuntu 24
  • Browser + version: not relevant
The text looks like a normal reply and is not indented with the bar on the left.
When an agent replies, the test that was there before gets indented when it is selected to send the whole conversation back to the customer.
Can this somehow be disabled to look more like a normal e-mail, so without the indentation?
You are talking about quotation.
You can globally disable the quotation or, which is much cleverer, mark the parts you want to reference and use that as quotation. That’s much better for your customer, because they know exactly what you’re referring to.
See:
