Disable activity stream / configurable in role settings
Hello!
We are running Zammad with a lot of different groups & roles and so I was thinking that it would be useful to configure which roles are allowed to see what the other agents are doing (logging in, modifying tickets etc). A lot of companies are binded to the strict data policies in our country and it would benefit everyone who is taking care of it seriously.
Best regards
LittleITworld
Hey @LittleITworld,
i found out yesterday that if the permisson “Read” in the Role Settings is not set
that the activity stream shows only the activity for your Group or Role.
Best regards
timgrm
grafik
The dashboard always shows the activity stream; it cannot be disabled.
In a system with sensitive tickets, the activity stream surfaces changes across the agent’s whole scope — activity that is not relevant to (or not meant for) the individual agent.
There is no configuration option for the activity stream.
A configuration option to hide the activity stream (per system or per role).
Ticket#10231017
