- Used Zammad version: 6.3
- Used Zammad installation type: not sure
- Operating system: windows 11
- Browser + version: chrome + Version 144.0.7559.133
we are using REST api “/api/v1/tickets” and if we are not sending any expected_resolution_date field zammad should have empty value in DB for it.
we are using REST api “/api/v1/tickets” and we are not sending any expected_resolution_date field but stil zammad taking default dateTime to the exact minute and storing in DB.
I have below settings in object manager from zammadUI.
if i create ticket direct from zammad UI, then it is fine
expected_resolution_date is empty as it should be.
but if i use from API /api/v1/tickets then somehow default value is set not sure which setting is responsible in zammad for this.
Could anyone please help on this?
Thanks
