- Used Zammad version: 2
- Used Zammad installation source: (source, package, …) package
- Operating system: CentOS 7.2
- Browser + version: FF 56
- Default Database creation
- Could not create
Hi
I am trying to install zammad package using yum but while installation it gives up error saying-
createdb: database creation failed: ERROR: new encoding (UTF8) is incompatible with the encoding of the template database (SQL_ASCII)
HINT: Use the same encoding as in the template database, or use template0 as template.
Since the database has not imported, zammad has not started in port no 3000
Have installed it in CentOS 7 in another location few days back, this errors did not props up.
Regards
