Dashboard counts twitter tickets but twitter is not configured?!
  • Used Zammad version: 5.3.1
  • Browser + version: Edge 109
Twitter should show 0% of new tickets on the dashboard.
Twitter show 8% but twitter is not configured in zammad.
I don’t know but in our instance the dashboard counts twitter tickets but twitter is not configured. Out zammad instance is only internal and cant from outside.
Is that maybe a bug?
kalender
Do you by chance use Zammads API?
You technically can add twitter type ticket articles without having it configured at all.
Hey,
thanks for your answer.
No, we don’t use the API. Only the web interface and email. Our users are authenticated by LDAP.
That’s indeed odd. Do you still see the twitter entries by now? If you’re not using that at all it should “disappear” after some period of time. If not possibly your scheduler is not running completely and doesn’t generate the statistical data correctly. Possibly in combination with a “faked” statistic. That is technically possible for demoing reasons but shouldn’t be the case productive.
