Customer And Agent Role
  • Used Zammad version: Version 6.3.1-1721369835.e7da6df9.centos8
  • Used Zammad installation type: ( package)
  • Operating system: almalinux 8
  • Browser + version: edge aktuell
user who are only assingned to customer role
can open tickets in webinterface succesfully
user who are Members have additional
Agent Rights for a different Ticket Group
for Example IOT-Servers
cannot create A Normal Customer Ticket in the Standart Ticket Group
IT-USER…
they can Only Create tickets in the Additional Group,
they are assigned as Agents
which additional Rights must be added ?
I would also say I have this problem.
For my system I had to do a workaround where everyone except for guest users is technically an agent.
You’ve got a base tier of agents that can send tickets to a first tier of groups. Give them at least visibility into the other groups so that they can see tickets that get escalated. For tickets that get escalated, I add roles that correspond to that agent’s function so that they can edit/take ownership of the ticket.
Hopefully this makes sense. I think it’s a very mid workaround, as most ticketing systems I’ve seen have a customer and an agent portal that one can switch between. Maybe one day :slight_smile:
thanks for your information
i found a solution near to yours
the idea if the other group rights was fine
i added the rights for creating tickets for the normal user ticket group
now this works for me
