Custom package installation gives error
  • Used Zammad version: 6.4.1-1735815640.3ddf2933.noble
  • Browser + version: Firefox latest
  • Run zammad run rake zammad:package:post_install without issues after installing custom package
  • Running zammad run rake zammad:package:post_install gives the following error output
Executing all pending package migrations...
done.
> zammad run rake zammad:package:precompile
/opt/zammad/.heroku/node/lib/node_modules/corepack/dist/lib/corepack.cjs:23509
              throw new UsageError(`This project is configured to use ${result.spec.name} because ${result.target} has a "packageManager" field`);
UsageError: This project is configured to use pnpm because /opt/zammad/package.json has a "packageManager" field
    at Engine.findProjectSpec (/opt/zammad/.heroku/node/lib/node_modules/corepack/dist/lib/corepack.cjs:23509:21)
    at async Engine.executePackageManagerRequest (/opt/zammad/.heroku/node/lib/node_modules/corepack/dist/lib/corepack.cjs:23539:24)
    at async Object.runMain (/opt/zammad/.heroku/node/lib/node_modules/corepack/dist/lib/corepack.cjs:24232:5) {
  clipanion: { type: 'usage' }
Node.js v22.1.0
  • Install a custom package
  • Get the error
Thanks,
Skip
I am getting this error every time I run zammad run rake assets:precompile too
You really should read the release notes.
I must be blind, I cannot see any reference to that here :see_no_evil:
Any pointer?
Thanks
How about going chronologically
Thanks for the hint.
Given the highlighted text I am not sure how that is relevant as I am using a package installation
Is any more specific clarification available? Does that mean that since I am using a package I can ignore the error? I cannot see anything in this regard in the release notes.
Thanks
I believe this conflict occurs because Yarn is no longer being used, and Corepack is trying to start via yarn.js. To prevent conflicts with pnpm or npm, I removed the Yarn modules. After that, the error message no longer appeared.
rm -rf /opt/zammad/.heroku/node/lib/node_modules/yarn
rm -rf /opt/zammad/.heroku/node/bin/yarn
rm -rf /opt/zammad/.heroku/node/bin/yarnpkg
I hope this is the correct approach, but everything is at your own risk. Please make a backup before proceeding.
After removing Yarn, try running the following command again:
zammad run rake assets:precompile && systemctl restart zammad-web
You can ignore the error. It is a false positive which isn’t resolved. The team did not find a way to suppress that error yet. The error should not impact the functionality of your system.
