oh the last part is actually the easiest.
in fact i already to set up a pipeline yesterday…
for whoever might come across the same issue, here is a small howto.
regarding my situation: i’m using rocky 9.1 as a host syste and i already have a repository for the docker compose files and overrides so how i started was that i added ‘zammad’ as subrepo to my existing repo and checked out the tag of the release i’m using (5.4.0).
please note that the following is only a reconstruction from the top of my head but it should be easy to figure out for your system since it roughly follows: Install from source — Zammad documentation
in general we are setting this up so that the user ‘rocky’ that is the main unprivileged user can use the asset generation pipeline
# as root
# keys necessary to install some of the packages
gpg2 --keyserver hkp://keyserver.ubuntu.com --recv-keys 409B6B1796C275462A1703113804BB82D39DC0E3 7D2BAF1CF37B13E2069D6956105BD0E739499BDB
# setup sources for node and yarn
curl -fsSL https://rpm.nodesource.com/setup_lts.x | bash -
curl -sL https://dl.yarnpkg.com/rpm/yarn.repo | tee /etc/yum.repos.d/yarn.repo
# install necessary packages we have in the repo already
dnf install -y nodejs yarn imlib2-devel postgresql-server libpq-devel
# install rvm
curl -L https://get.rvm.io | bash -s stable
# setup postgres;
# unfortunately we need this since the asset generation
# process of zammad requires the database to be setup
/usr/bin/postgresql-setup --initdb
systemctl enable postgresql
systemctl start postgresql
sudo -i -u postgres createuser -d rocky
# now install ruby and other necessary gems
# note: this could probably be use a user writeable
# location instead but i didn't bother since i'm using
# this from a VM and the process only has to be done once
# also i dont know ruby and rvm that well ;)
source /etc/profile.d/rvm.sh
rvm install ruby-3.1.3
rvm use 3.1.3
gem install bundler rake rails
# make it writeable so user cann add gems as well
chown rocky:rocky -R /usr/local/rvm
# as rocky
# enter main git repo
cd ~/zammad-docker-compose
# add zammad repo as submodule using tag 5.4.0
git submodule add https://github.com/zammad/zammad.git
cd zammad
git checkout 5.4.0
cd ..
git add zammad
# install bundles for project
cd zammad
bundle config set without "test mysql"
bundle install
# use default database config; suffices to run the build process
# if there is anything needed from production
# i probably need to sync the databases
# but at this point i just dont know
cp config/database/database.yml config/database.yml
# this should now work
rake assets:precompile
For the docker part i’m just using a new container with an image that has ‘rsync’ and mount both folders. At the moment I simply copy over the assets over the existing ones …
version: '3'
sync_assets:
image: <any image that has 'rsync' or a tool you like>
volumes:
- zammad-data:/opt/zammad
- ./zammad/public:/opt/public
command: rsync --progress -av --delete /opt/public/ /opt/zammad/public/
volumes:
zammad-data:
driver: local
zammad-backup:
driver: local
Note: I dont like the copy step in particular but unfortunately it doesn’t seem to be possible to bind mount a host folder onto a folder thats on the volume. Seems like docker mounts the binding first and then it gets lost when the volume is mounted
after building the assets i just run
docker compose -f docker-compose.assets.yml run -T --rm sync_assets
to get the assets onto the data volume
