Currently, Ctrl+Shift+t is mapped to “Enable/disable inline translations”.
Unfortunately, the same keyboard shortcut is used to reopen a closed tab in Firefox.
As a result, you’re unable to reopen a closed tab in Firefox while you’re on the Zammad tab.
I think it would be great if this shortcut gets remapped to something else.
There’s already an enhancement issue for this:
