- Used Zammad version: 3.6.0-1610545422.444c3a5d.buster amd64
- Used Zammad installation source: apt-package from: https://dl.packager.io/srv/deb/zammad/zammad/stable/debian 10 main
- Operating system: Debian 10.7
- Browser + version: Google Chrome Version 87.0.4280.141 (64-Bit)
- CTI connection established with our NetPhone (Telekom branded “Swyx”) telephone system and call routing
- Not really sure since it seems something isn’t working as it should. I guess when a CTI call is incoming, a new ticket or the customer page should open.
- Here’s the actual behavior, whats happening when a call is incoming, gets picked up by the agent (who is also in the notify-map) and hung up a few seconds afterwards. When the call is incoming, there’s a “+”-Button to open a new ticket. When accepting the call however, it’s gone and the call just remains in the overall list and you can’t really do anything from there.
Also, we receive the following POST error in the http-logs of the CTI integration menu:
The error-log ID shown in the screenshot refers to the following log from the server:
I, [2021-01-15T09:11:55.841404 #20729-70046885162700] INFO -- : Started POST "/api/v1/cti/gi5idl6[***censored***]zYBeB3Jt8" for [***censored***] at 2021-01-15 09:11:55 +0100
I, [2021-01-15T09:11:55.844767 #20729-70046885162700] INFO -- : Processing by Integration::CtiController#event as */*
I, [2021-01-15T09:11:55.844832 #20729-70046885162700] INFO -- : Parameters: {"event"=>"answer", "from"=>" 141", "to"=>"145", "direction"=>"in", "callId"=>"566537", "user"=>[""], "answeringNumber"=>"49
", "token"=>"gi5idl6[***censored***]BeB3Jt8"}
I, [2021-01-15T09:11:55.872328 #20729-70046885162700] INFO -- : Enqueued SearchIndexJob (Job ID: 2338e8f4-b462-48ce-ad0a-bbf19c9339ba) to DelayedJob(default) with arguments: "Cti::Log", 43
I, [2021-01-15T09:11:55.876199 #20729-70046885162700] INFO -- : Enqueued SearchIndexAssociationsJob (Job ID: e63fd9ca-4a7e-42b2-a7da-07d8ffed94b4) to DelayedJob(default) with arguments: "Cti::Log", 43
E, [2021-01-15T09:11:55.887312 #20729-70046885162700] ERROR -- : undefined method `downcase' for [""]:Array (NoMethodError)
/opt/zammad/app/models/cti/driver/base.rb:183:in `push_open_ticket_screen_recipient'
/opt/zammad/app/models/cti/driver/base.rb:131:in `push_open_ticket_screen'
/opt/zammad/app/models/cti/driver/base.rb:47:in `process'
/opt/zammad/app/controllers/integration/cti_controller.rb:13:in `event'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.4.4/lib/action_controller/metal/basic_implicit_render.rb:6:in `send_action'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.4.4/lib/abstract_controller/base.rb:194:in `process_action'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.4.4/lib/action_controller/metal/rendering.rb:30:in `process_action'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.4.4/lib/abstract_controller/callbacks.rb:42:in `block in process_action'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.4.4/lib/active_support/callbacks.rb:109:in `block in run_callbacks'
/opt/zammad/app/controllers/application_controller/has_secure_content_security_policy_for_downloads.rb:18:in `block (4 levels) in <module:HasSecureContentSecurityPolicyForDownloads>'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.4.4/lib/active_support/notifications.rb:180:in `subscribed'
/opt/zammad/app/controllers/application_controller/has_secure_content_security_policy_for_downloads.rb:17:in `block (3 levels) in <module:HasSecureContentSecurityPolicyForDownloads>'
/opt/zammad/app/controllers/application_controller/has_secure_content_security_policy_for_downloads.rb:16:in `block (2 levels) in <module:HasSecureContentSecurityPolicyForDownloads>'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.4.4/lib/active_support/callbacks.rb:118:in `instance_exec'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.4.4/lib/active_support/callbacks.rb:118:in `block in run_callbacks'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.4.4/lib/active_support/callbacks.rb:136:in `run_callbacks'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.4.4/lib/abstract_controller/callbacks.rb:41:in `process_action'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.4.4/lib/action_controller/metal/rescue.rb:22:in `process_action'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.4.4/lib/action_controller/metal/instrumentation.rb:34:in `block in process_action'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.4.4/lib/active_support/notifications.rb:168:in `block in instrument'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.4.4/lib/active_support/notifications/instrumenter.rb:23:in `instrument'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.4.4/lib/active_support/notifications.rb:168:in `instrument'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.4.4/lib/action_controller/metal/instrumentation.rb:32:in `process_action'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.4.4/lib/action_controller/metal/params_wrapper.rb:256:in `process_action'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/railties/controller_runtime.rb:24:in `process_action'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.4.4/lib/abstract_controller/base.rb:134:in `process'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/actionview-5.2.4.4/lib/action_view/rendering.rb:32:in `process'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.4.4/lib/action_controller/metal.rb:191:in `dispatch'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.4.4/lib/action_controller/metal.rb:252:in `dispatch'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.4.4/lib/action_dispatch/routing/route_set.rb:52:in `dispatch'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.4.4/lib/action_dispatch/routing/route_set.rb:34:in `serve'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.4.4/lib/action_dispatch/journey/router.rb:52:in `block in serve'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.4.4/lib/action_dispatch/journey/router.rb:35:in `each'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.4.4/lib/action_dispatch/journey/router.rb:35:in `serve'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.4.4/lib/action_dispatch/routing/route_set.rb:840:in `call'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/omniauth-1.9.1/lib/omniauth/strategy.rb:420:in `call_app!'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/omniauth-saml-1.10.1/lib/omniauth/strategies/saml.rb:89:in `other_phase'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/omniauth-1.9.1/lib/omniauth/strategy.rb:190:in `call!'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/omniauth-1.9.1/lib/omniauth/strategy.rb:169:in `call'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/omniauth-1.9.1/lib/omniauth/strategy.rb:192:in `call!'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/omniauth-1.9.1/lib/omniauth/builder.rb:45:in `call'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/rack-2.2.3/lib/rack/tempfile_reaper.rb:15:in `call'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/rack-2.2.3/lib/rack/etag.rb:27:in `call'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/rack-2.2.3/lib/rack/conditional_get.rb:40:in `call'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/rack-2.2.3/lib/rack/head.rb:12:in `call'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.4.4/lib/action_dispatch/http/content_security_policy.rb:18:in `call'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/rack-2.2.3/lib/rack/session/abstract/id.rb:266:in `context'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/rack-2.2.3/lib/rack/session/abstract/id.rb:260:in `call'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.4.4/lib/action_dispatch/middleware/cookies.rb:670:in `call'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.4.4/lib/action_dispatch/middleware/callbacks.rb:28:in `block in call'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.4.4/lib/active_support/callbacks.rb:98:in `run_callbacks'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.4.4/lib/action_dispatch/middleware/callbacks.rb:26:in `call'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.4.4/lib/action_dispatch/middleware/debug_exceptions.rb:61:in `call'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.4.4/lib/action_dispatch/middleware/show_exceptions.rb:33:in `call'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/railties-5.2.4.4/lib/rails/rack/logger.rb:38:in `call_app'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/railties-5.2.4.4/lib/rails/rack/logger.rb:26:in `block in call'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.4.4/lib/active_support/tagged_logging.rb:71:in `block in tagged'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.4.4/lib/active_support/tagged_logging.rb:28:in `tagged'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.4.4/lib/active_support/tagged_logging.rb:71:in `tagged'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/railties-5.2.4.4/lib/rails/rack/logger.rb:26:in `call'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.4.4/lib/action_dispatch/middleware/remote_ip.rb:81:in `call'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.4.4/lib/action_dispatch/middleware/request_id.rb:27:in `call'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/rack-2.2.3/lib/rack/method_override.rb:24:in `call'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/rack-2.2.3/lib/rack/runtime.rb:22:in `call'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.4.4/lib/active_support/cache/strategy/local_cache_middleware.rb:29:in `call'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.4.4/lib/action_dispatch/middleware/executor.rb:14:in `call'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.4.4/lib/action_dispatch/middleware/static.rb:127:in `call'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/rack-2.2.3/lib/rack/sendfile.rb:110:in `call'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/railties-5.2.4.4/lib/rails/engine.rb:524:in `call'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/puma-3.12.6/lib/puma/configuration.rb:227:in `call'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/puma-3.12.6/lib/puma/server.rb:706:in `handle_request'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/puma-3.12.6/lib/puma/server.rb:476:in `process_client'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/puma-3.12.6/lib/puma/server.rb:334:in `block in run'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/puma-3.12.6/lib/puma/thread_pool.rb:135:in `block in spawn_thread'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/logging-2.2.2/lib/logging/diagnostic_context.rb:474:in `block in create_with_logging_context'
E, [2021-01-15T09:11:55.889644 #20729-70046885162700] ERROR -- : Error ID 2HBLHXIs: undefined method `downcase' for [""]:Array
I, [2021-01-15T09:11:55.895122 #20729-70046885162700] INFO -- : Completed 500 Internal Server Error in 50ms (Views: 0.1ms | ActiveRecord: 11.7ms)
- Call, pick up, talk a bit, hang up and check the https-log
Roundup
Our error seems to be with undefined method `downcase’ for [“”]:Array (NoMethodError), do you know what’s up with that and how we can fix this?
Thanks and best regards,
Frederik
