CTI integration - Create a Ticket "+" after answered the call
  • Used Zammad version: 3.3
  • Used Zammad installation source: DEB
  • Operating system: Ubuntu 18.04 LTS
  • Browser + version: Google Chrome - latest
Hello to everyone,
is it possible to open a ticket via the generic CTI integration “+” after the call is answered? I know i can go in the journal and klick on the customer and than i can say --> new ticket. But it would great when the connected calls also stay on the left site.
Is this a thing in zammad or is this a thing make by the integration bridge from the pbx site?
Best regards,
Jesse
  • Get a call via the CTI integration see the caller in the left menu with the “+”, get on the phone and answer the call to look if i have to create a ticket. Now i when the call is answered i will see the call as connected on the left and can click on the “+” to open a new ticket.
  • The “+” and the CTI entry on the left will go away when i answer the call.
  • Receive a call via the CTI integration.
Yes that’s perfectly possible.
Your best shot will be the “notify map”.
The wording is a bit missleading here.
You simply map the agents extension with the agent account in Zammad.
As soon as you’ve done this and the mapped extension picks up the call, Zammad will automatically open a new ticket dialogue for the agent you have mapped.
Note: This requires the phone system to communicate the picking up extension, this is usually the case.
Thanks for the quick answer @MrGeneration :slight_smile:
I am trying to locate this setting. Checked multiple time the agent creation page and all.
Could you please point out where I can get the notify map setting.
thank you.
In the CTI settings that you activated for your CTI functionality. The last table.
thank you for the reply. I am wonder after setting up notify map with agent extension and agent account. I no longer get the call pop up even.
My only challenge is to display caller name/details with incoming call.
please advise
thank you again.
Ensure that your user database contains the number thats calling…?
This is also the case with me …
the left menu with the “+”, Only works if sends the “to” value in the “Event: newCall”.
If i submit the “to” (Notify Map number) in “Event: answer” Zamed will not pop the window.
