- Used Zammad version: 3.6.0
- Used Zammad installation source: via DEB
- Browser + version: Chrome 86.0.4240.80
New Tickets appearing in the dashboard.
When I add an email account, I get the message that there are 2 mails already on the server. The verification completes without any error message, but the new tickets do not appear. When I check the production.log, I can see error messages like this (I removed personal information from the log):
I, [2020-11-26T12:01:54.184811 #862-47115581284660] INFO – : Completed 401 Unauthorized in 1ms (Views: 0.1ms | ActiveRecord: 0.0ms)
I, [2020-11-26T12:01:55.274479 #862-47115581284440] INFO – : Started POST “/api/v1/channels_email_inbound” for xxx at 2020-11-26 12:01:55 +0000
I, [2020-11-26T12:01:55.278455 #862-47115581284440] INFO – : Processing by ChannelsEmailController#inbound as JSON
I, [2020-11-26T12:01:55.278515 #862-47115581284440] INFO – : Parameters: {“adapter”=>“pop3”, “options”=>{“host”=>“mail.agenturserver.de”, “user”=>“xxx”, “password”=>"[FILTERED]", “ssl”=>true, “port”=>“995”}, “channel_id”=>3}
I, [2020-11-26T12:01:55.283089 #862-47115581284440] INFO – : fetching pop3 (mail.agenturserver.de/xxx port=995,ssl=true)
I, [2020-11-26T12:01:55.508541 #862-47115581284440] INFO – : check only mode, fetch no emails
I, [2020-11-26T12:01:55.559068 #862-47115581284440] INFO – : Completed 200 OK in 280ms (Views: 0.2ms | ActiveRecord: 0.5ms)
I, [2020-11-26T12:01:57.556917 #862-47115581285680] INFO – : Started POST “/api/v1/channels_email_outbound” for xxx at 2020-11-26 12:01:57 +0000
I, [2020-11-26T12:01:57.561431 #862-47115581285680] INFO – : Processing by ChannelsEmailController#outbound as JSON
I, [2020-11-26T12:01:57.561493 #862-47115581285680] INFO – : Parameters: {“adapter”=>“smtp”, “options”=>{“host”=>“mail.agenturserver.de”, “user”=>“xxx”, “password”=>"[FILTERED]", “port”=>“25”}, “email”=>“xxx”, “channel_id”=>3}
I, [2020-11-26T12:01:57.817178 #862-47115581285680] INFO – : Completed 200 OK in 256ms (Views: 0.2ms | ActiveRecord: 0.4ms)
I, [2020-11-26T12:01:57.856233 #862-47115581286100] INFO – : Started POST “/api/v1/channels_email_verify” for xxx at 2020-11-26 12:01:57 +0000
I, [2020-11-26T12:01:57.860160 #862-47115581286100] INFO – : Processing by ChannelsEmailController#verify as JSON
I, [2020-11-26T12:01:57.860234 #862-47115581286100] INFO – : Parameters: {“inbound”=>{“adapter”=>“pop3”, “options”=>{“host”=>“mail.agenturserver.de”, “user”=>“xxx”, “password”=>"[FILTERED]", “ssl”=>true, “port”=>“995”}, “channel_id”=>3}, “outbound”=>{“adapter”=>“smtp”, “options”=>{“host”=>“mail.agenturserver.de”, “user”=>“xxx”, “password”=>"[FILTERED]", “port”=>“25”}, “email”=>“xxx”, “channel_id”=>3}, “meta”=>{}, “channel_id”=>3, “group_id”=>1, “email”=>“xxx”}
I, [2020-11-26T12:01:58.755866 #903-46973898324380] INFO – : Scheduler running…
I, [2020-11-26T12:01:58.760898 #903-46973898324380] INFO – : Running job thread for ‘Check streams for Channel’ (Channel.stream) status is: sleep
I, [2020-11-26T12:01:58.760961 #903-46973898324380] INFO – : Running job thread for ‘Generate Session data’ (Sessions.jobs) status is: sleep
I, [2020-11-26T12:02:01.143186 #862-47115581285180] INFO – : Started POST “/api/v1/message_send” for xxx at 2020-11-26 12:02:01 +0000
I, [2020-11-26T12:02:01.147521 #862-47115581285180] INFO – : Processing by LongPollingController#message_send as JSON
I, [2020-11-26T12:02:01.147572 #862-47115581285180] INFO – : Parameters: {“data”=>{“event”=>“login”}}
I, [2020-11-26T12:02:01.147949 #862-47115581285180] INFO – : CSRF token verification failed
I, [2020-11-26T12:02:01.148032 #862-47115581285180] INFO – : CSRF token verification failed! (Exceptions::NotAuthorized)
I do not have any problems with the login. My nginx config looks like this:
server {
listen xxx:443 ssl http2;
server_name xxx.de;
server_name www.xxx.de;
server_name ipv4.xxx.de;
ssl_certificate /opt/psa/var/certificates/xxx;
ssl_certificate_key /opt/psa/var/certificates/xxx;
client_max_body_size 128m;
root "/xxx/zammad/public";
access_log "/var/www/vhosts/system/xxx/logs/proxy_access_ssl_log";
error_log "/var/www/vhosts/system/xxx/logs/proxy_error_log";
#extension letsencrypt begin
location ^~ /.well-known/acme-challenge/ {
root /var/www/vhosts/default/htdocs;
types { }
default_type text/plain;
satisfy any;
auth_basic off;
allow all;
location ~ ^/\.well-known/acme-challenge.*/\. {
deny all;
#extension letsencrypt end
#extension sslit begin
#extension sslit end
location ~ /\.ht {
deny all;
disable_symlinks if_not_owner "from=/var/www/vhosts/xxx";
add_header X-Powered-By PleskLin;
location /ws {
proxy_http_version 1.1;
proxy_read_timeout 86400;
proxy_pass http://127.0.0.1:6042;
location / {
# Change this line in an SSO setup
proxy_read_timeout 300;
proxy_pass http://127.0.0.1:3000;
gzip on;
gzip_proxied any;
server {
listen 82.165.126.234:80;
server_name xxx.de;
location / {
- Fresh install on Ubuntu 20.04
- Add email account and try to receive emails
Could you please help me with this issue?
Thanks,
Mark
I had to set the permissions manually with: sudo chown -R zammad /opt/zammad
