- Used Zammad version: 4.1
- Used Zammad installation type: DEB
- Browser + version: Safari and Firefox on MacOS
Can´t log in. error “CSRF token verification failed!”
It´s quit a new zammad installation. Working fine since some days. But suddenly we can´t log in any more. It starts with a new client registration.
I had a look here and on version 3.2 and 3.3 and 3.6 are also some issues. Then there should be help with the line
RequestHeader set X_FORWARDED_PROTO ‘https’
RequestHeader set X-Forwarded-Ssl on
in the zammad apache conf
But when I do this the apache does not start anymore.
Here th log, when I try to login:
/opt/zammad/app/controllers/application_controller/prevents_csrf.rb:35:in verify_csrf_token' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.4.6/lib/active_support/callbacks.rb:426:in block in make_lambda’
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.4.6/lib/active_support/callbacks.rb:179:in block (2 levels) in halting_and_conditional' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.4.6/lib/abstract_controller/callbacks.rb:34:in block (2 levels) in module:Callbacks’
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.4.6/lib/active_support/callbacks.rb:180:in block in halting_and_conditional' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.4.6/lib/active_support/callbacks.rb:513:in block in invoke_before’
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.4.6/lib/active_support/callbacks.rb:513:in each' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.4.6/lib/active_support/callbacks.rb:513:in invoke_before’
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.4.6/lib/active_support/callbacks.rb:107:in block in run_callbacks' /opt/zammad/app/controllers/application_controller/handles_transitions.rb:14:in handle_transaction’
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.4.6/lib/active_support/callbacks.rb:118:in block in run_callbacks' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.4.6/lib/active_support/callbacks.rb:136:in run_callbacks’
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.4.6/lib/abstract_controller/callbacks.rb:41:in process_action' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.4.6/lib/action_controller/metal/rescue.rb:22:in process_action’
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.4.6/lib/action_controller/metal/instrumentation.rb:34:in block in process_action' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.4.6/lib/active_support/notifications.rb:168:in block in instrument’
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.4.6/lib/active_support/notifications/instrumenter.rb:23:in instrument' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.4.6/lib/active_support/notifications.rb:168:in instrument’
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.4.6/lib/action_controller/metal/instrumentation.rb:32:in process_action' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.4.6/lib/action_controller/metal/params_wrapper.rb:256:in process_action’
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.6/lib/active_record/railties/controller_runtime.rb:24:in process_action' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.4.6/lib/abstract_controller/base.rb:134:in process’
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/actionview-5.2.4.6/lib/action_view/rendering.rb:32:in process' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.4.6/lib/action_controller/metal.rb:191:in dispatch’
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.4.6/lib/action_controller/metal.rb:252:in dispatch' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.4.6/lib/action_dispatch/routing/route_set.rb:52:in dispatch’
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.4.6/lib/action_dispatch/routing/route_set.rb:34:in serve' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.4.6/lib/action_dispatch/journey/router.rb:52:in block in serve’
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.4.6/lib/action_dispatch/journey/router.rb:35:in each' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.4.6/lib/action_dispatch/journey/router.rb:35:in serve’
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.4.6/lib/action_dispatch/routing/route_set.rb:840:in call' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/omniauth-1.9.1/lib/omniauth/strategy.rb:420:in call_app!’
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/omniauth-saml-1.10.1/lib/omniauth/strategies/saml.rb:89:in other_phase' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/omniauth-1.9.1/lib/omniauth/strategy.rb:190:in call!’
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/omniauth-1.9.1/lib/omniauth/strategy.rb:169:in call' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/omniauth-1.9.1/lib/omniauth/strategy.rb:192:in call!’
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/omniauth-1.9.1/lib/omniauth/strategy.rb:169:in call' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/omniauth-1.9.1/lib/omniauth/builder.rb:45:in call’
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/rack-2.2.3/lib/rack/tempfile_reaper.rb:15:in call' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/rack-2.2.3/lib/rack/etag.rb:27:in call’
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/rack-2.2.3/lib/rack/conditional_get.rb:40:in call' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/rack-2.2.3/lib/rack/head.rb:12:in call’
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.4.6/lib/action_dispatch/http/content_security_policy.rb:18:in call' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/rack-2.2.3/lib/rack/session/abstract/id.rb:266:in context’
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/rack-2.2.3/lib/rack/session/abstract/id.rb:260:in call' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.4.6/lib/action_dispatch/middleware/cookies.rb:670:in call’
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.4.6/lib/action_dispatch/middleware/callbacks.rb:28:in block in call' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.4.6/lib/active_support/callbacks.rb:98:in run_callbacks’
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.4.6/lib/action_dispatch/middleware/callbacks.rb:26:in call' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.4.6/lib/action_dispatch/middleware/debug_exceptions.rb:61:in call’
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.4.6/lib/action_dispatch/middleware/show_exceptions.rb:33:in call' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/railties-5.2.4.6/lib/rails/rack/logger.rb:38:in call_app’
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/railties-5.2.4.6/lib/rails/rack/logger.rb:26:in block in call' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.4.6/lib/active_support/tagged_logging.rb:71:in block in tagged’
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.4.6/lib/active_support/tagged_logging.rb:28:in tagged' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.4.6/lib/active_support/tagged_logging.rb:71:in tagged’
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/railties-5.2.4.6/lib/rails/rack/logger.rb:26:in call' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.4.6/lib/action_dispatch/middleware/remote_ip.rb:81:in call’
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.4.6/lib/action_dispatch/middleware/request_id.rb:27:in call' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/rack-2.2.3/lib/rack/method_override.rb:24:in call’
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/rack-2.2.3/lib/rack/runtime.rb:22:in call' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.4.6/lib/active_support/cache/strategy/local_cache_middleware.rb:29:in call’
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.4.6/lib/action_dispatch/middleware/executor.rb:14:in call' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.4.6/lib/action_dispatch/middleware/static.rb:127:in call’
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/rack-2.2.3/lib/rack/sendfile.rb:110:in call' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/railties-5.2.4.6/lib/rails/engine.rb:524:in call’
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/puma-4.3.8/lib/puma/configuration.rb:228:in call' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/puma-4.3.8/lib/puma/server.rb:718:in handle_request’
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/puma-4.3.8/lib/puma/server.rb:472:in process_client' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/puma-4.3.8/lib/puma/server.rb:328:in block in run’
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/puma-4.3.8/lib/puma/thread_pool.rb:134:in block in spawn_thread' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/logging-2.2.2/lib/logging/diagnostic_context.rb:474:in block in create_with_logging_context’
I, [2021-08-06T21:16:53.931500 #959000-47388310455080] INFO – : Completed 401 Unauthorized in 4ms (Views: 0.2ms | ActiveRecord: 2.2ms)
I, [2021-08-06T21:17:13.419263 #959004-47292058950680] INFO – : execute Channel.fetch (try_count 0)…
To much “block…” but It doesn’t say me something.
Any hinds?
Al
