When submitting the login form, a “CSRF token verification failed!” error is shown and login fails
Deploy Zammad with docker-compose according to the documentation
Configure Caddy in front of Zammad for TLS termination (one-line reverse_proxy call or commandline)
Access Zammad and run first-run wizard - it should succeed and log you into the admin account
Try logging in to Zammad in another browser or private window - this should throw the error and login fails
I have tried adding NGINX_SERVER_SCHEME=https to the .env file and rebuilding the compose env, to no avail. zammad-nginx looks to be configured correctly, passing the $scheme it gets from downstream. Caddy’s logs say that it passes X-Forwarded-Proto: https to nginx (excerpt below):
http_type setting is set to https, which I assume was done automatically by the first-run wizard. I believe that is the correct setting? But I am not sure from reading the docs what that setting should be and why.
Thank you! FQDN was set correctly already. HTTP Type is already set to HTTPS. I tried setting RAILS_TRUSTED_PROXIES in .env, but it doesn’t seem to make a difference either.
(the gateway and reverse proxy is at 10.0.0.1, the container running docker compose is at 10.0.3.70)
Docker compose logs excerpt:
zammad-docker-compose-zammad-nginx-1 | 10.0.0.1 - - [24/May/2023:18:50:28 +0000] "GET / HTTP/1.1" 200 1569 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:109.0) Gecko/20100101 Firefox/114.0"
zammad-docker-compose-zammad-railsserver-1 | I, [2023-05-24T18:50:43.342016#1-113320] INFO -- : Started POST "/api/v1/signin" for 10.0.0.1 at 2023-05-24 18:50:43 +0000
zammad-docker-compose-zammad-railsserver-1 | I, [2023-05-24T18:50:43.368095#1-113320] INFO -- : CSRF token verification failed
zammad-docker-compose-zammad-railsserver-1 | I, [2023-05-24T18:50:43.368389#1-113320] INFO -- : CSRF token verification failed! (Exceptions::NotAuthorized)
zammad-docker-compose-zammad-railsserver-1 | app/controllers/application_controller/prevents_csrf.rb:36:in `verify_csrf_token'
zammad-docker-compose-zammad-railsserver-1 | app/controllers/application_controller/has_download.rb:21:in `block (4 levels) in <module:HasDownload>'
zammad-docker-compose-zammad-railsserver-1 | app/controllers/application_controller/has_download.rb:20:in `block (3 levels) in <module:HasDownload>'
zammad-docker-compose-zammad-railsserver-1 | app/controllers/application_controller/has_download.rb:19:in `block (2 levels) in <module:HasDownload>'
zammad-docker-compose-zammad-railsserver-1 | app/controllers/application_controller/handles_transitions.rb:16:in `handle_transaction'
zammad-docker-compose-zammad-railsserver-1 | I, [2023-05-24T18:50:43.369634#1-113320] INFO -- : Completed 401 Unauthorized in 25ms (Views: 0.1ms | ActiveRecord: 20.1ms | Allocations: 2577)
zammad-docker-compose-zammad-nginx-1 | 10.0.0.1 - - [24/May/2023:18:50:43 +0000] "POST /api/v1/signin HTTP/1.1" 401 102 "https://fqdn.here/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:109.0) Gecko/20100101 Firefox/114.0"
I even tried recreating the entire compose env (sans volumes) to no avail.
You put your vars in the yml file instead of the .env - but the .env is still supposed to work, right?
I might try putting the variables directly into the yml as well …
… and only when overriding zammad-init it would at least show up in the rails env config. However the problem persists unchanged.
I also tried flipping the http_type setting, but that made no observable difference either.
I also tried setting NGINX_SERVER_SCHEME=https for both zammad-init and zammad-nginx, but no luck there either.
I feel like I’m going crazy ^^ I might have to dig deeper into how exactly the docker setup is constructed (where I hoped that docker compose would make things easier…) - I must’ve missed something stupidly obvious.
I guess since the default docker-compose.yml file does not have a reference to NGINX_SERVER_SCHEME, the .env value does not override it. Ultimately this feels like it comes down to a documentation issue. I run a Caddy reverse_proxy on another server and the documentation regarding proxying Zammad in Docker did not appear to apply to that situation.
