- Used Zammad version: 3.2.x (cant login so i locked in VERSION file)
- Operating system: Ubuntu 16.04 (latest)
- Browser + version: FF and Chrome
Login to Zammad
Logfile:
I, [2020-01-07T15:26:11.795163 #922-47258254810500] INFO -- : Processing by SessionsController#create as JSON
I, [2020-01-07T15:26:11.795239 #922-47258254810500] INFO -- : Parameters: {"username"=>"XXXXXXX, "password"=>"[FILTERED]", "fingerprint"=>"-2082337767"}
I, [2020-01-07T15:26:11.799663 #922-47258254810500] INFO -- : CSRF token verification failed
I, [2020-01-07T15:26:11.800279 #922-47258254810500] INFO -- : Completed 401 Unauthorized in 5ms (Views: 0.2ms | ActiveRecord: 1.5ms)
# this is the apache config for zammad
<VirtualHost *:80>
ServerName XXXXXX
## don't loose time with IP address lookups
HostnameLookups Off
## needed for named virtual hosts
UseCanonicalName Off
## configures the footer on server-generated documents
ServerSignature Off
ProxyRequests Off
ProxyPreserveHost On
<Proxy localhost:3000>
Require local
</Proxy>
RequestHeader set X-Forwarded-Proto https
RequestHeader set X-Forwarded-Ssl on
ProxyPass /assets !
ProxyPass /favicon.ico !
ProxyPass /robots.txt !
ProxyPass /ws ws://localhost:6042/
ProxyPass / http://localhost:3000/
DocumentRoot "/opt/zammad/public"
<Directory />
Options FollowSymLinks
AllowOverride None
</Directory>
<Directory "/opt/zammad/public">
Require all granted
</Directory>
</VirtualHost>
Login into Zammd with diffrent users on diffrent PCs.
Also added the lines to appache from: Fresh install 3.2.x: CSRF token verification failed
