Used Zammad version: 6.5.2-1767354399.5ee205d5
Used Zammad installation type: package (DEB package on Ubuntu)
Operating system: Ubuntu 24.04 LTS (Noble)
Browser + version: N/A (Server-side CSP configuration issue)
Context:
During a security audit of our Zammad instance, we identified that the Content Security Policy (CSP) header includes two directives that are flagged as security concerns by our security scanning tools:
'unsafe-eval'in thescript-srcdirective'unsafe-inline'in thestyle-srcdirective
Current CSP header (example from our instance):
base-uri 'self';
default-src 'self' ws: wss:;
font-src 'self' data:;
img-src * data: blob:;
object-src 'none';
script-src 'self' 'unsafe-eval' 'nonce-[...]';
style-src 'self' 'unsafe-inline';
frame-src www.youtube.com player.vimeo.com
We located the CSP configuration file at: /opt/zammad/config/initializers/content_security_policy.rb
We would like to harden the CSP configuration by removing or replacing the 'unsafe-eval' and 'unsafe-inline' directives while maintaining full Zammad functionality.
The current CSP configuration includes these “unsafe” directives, which:
- Increase the attack surface for potential XSS (Cross-Site Scripting) attacks
- Are flagged by security scanning tools as vulnerabilities
- May not align with strict security compliance requirements (SOC 2, ISO 27001, etc.)
Questions:
- Is there a roadmap or plan to remove these
'unsafe-*'directives from Zammad’s default CSP?
- We understand this may require significant code refactoring
- Are these directives essential for Zammad’s core functionality?
- If yes, which specific features depend on them?
- Would disabling/restricting them break any critical features?
- Has anyone successfully hardened the CSP on their Zammad instance?
- What approach did you take?
- Did it require code modifications?
- Any documented workarounds?
- Is it safe to modify
/opt/zammad/config/initializers/content_security_policy.rbdirectly?
- Would our changes be overwritten during package updates?
- Is there a recommended way to override CSP settings?
- Would manually overriding the CSP header at the reverse proxy level (nginx/Apache) be viable?
- Or would this likely break Zammad’s JavaScript/CSS functionality?
Additional Context:
We understand that:
- Refactoring code to remove
eval()usage is complex - Moving inline scripts/styles to external files requires significant development effort
- These changes could potentially introduce regressions
We’re trying to assess whether this is:
- A known architectural limitation of Zammad’s current design
- Something being addressed in future releases
- Something that requires a custom fork or patch
Any guidance from the Zammad team or community experiences would be greatly appreciated! We’re happy to contribute back any solutions we develop or test proposed fixes.
