I am working with JavaScript and JQuery.
Below is the:
- HTML for a small test
- JavaScript for the test
- Production.log from when the test was run
When I comment out the addition of the attachment to the article in the JSON I am sending the ticket is created. When I have the attachment I get the error and a ticket is created but without the article (or the attachment).
Thank you for your help.
HTML:
<!DOCTYPE html>
<html id="" class="no-js" dir="rtl" lang="he">
<head>
<meta http-equiv="X-UA-Compatible" content="IE=edge">
<meta http-equiv="content-type" content="text/html; charset=UTF-8">
<meta charset="utf-8">
<script src="https://ajax.googleapis.com/ajax/libs/jquery/1.12.4/jquery.min.js"></script>
<script src="https://ajax.googleapis.com/ajax/libs/jqueryui/1.12.1/jquery-ui.min.js"></script>
<script src="Test.js"></script>
</head>
<body>
<form id="open-ticket" onsubmit="OpenTicket();">
<button type="submit" value="Submit">Open Ticket</button>
</form>
</body>
</html>
JavaScript:
// Prevent Default handling of form submission as we want to stay on the same page
$(document).bind("submit", function (e) {
e.preventDefault();
console.log("submit intercepted");
function OpenTicket() {
var theTicket = {};
theTicket["title"] = "Ticket Title";
theTicket["group"] = "Help Desk";
var theArticle = {};
theArticle["subject"] = "Article Title";
theArticle["body"] = "Note Body";
theArticle["type"] = "note";
theArticle["internal"] = false;
var firstAttachment = {};
firstAttachment["filename"] = "filename.txt";
firstAttachment["data"] = "content in base64";
firstAttachment["mime-type"] = "text/plain";
var theAttachments = {};
theAttachments[0] = firstAttachment;
theArticle["attachments"] = theAttachments; //comment out this line and it works.
theTicket["article"] = theArticle;
theTicket["customer"] = "shimons@most.gov.il";
theTicket["note"] = "some note";
$.ajax({
beforeSend: function (xhr) {
xhr.setRequestHeader("Authorization", "Token token=<myToken>");
type: "POST",
url: "http://server/api/v1/tickets",
dataType: "json",
data: theTicket,
success: function (data) {
alert("Ticket Opened!");
error: function (errMsg) {
alert(errMsg.responseJSON.error);
return false;
Production.log:
I, [2018-12-17T12:28:49.410599 #2755-47290442799460] INFO -- : # 200
I, [2018-12-17T12:28:49.419312 #2755-47290442799460] INFO -- : 2018-12-17T12:28:49+0200: [Worker(host:Zammad pid:2755)] Job BackgroundJobSearchIndex (id=63855) COMPLETED after 0.1125
I, [2018-12-17T12:28:49.427040 #2755-47290442799460] INFO -- : 2018-12-17T12:28:49+0200: [Worker(host:Zammad pid:2755)] Job BackgroundJobSearchIndex (id=63858) RUNNING
I, [2018-12-17T12:28:49.519654 #2755-47290442799460] INFO -- : # curl -X POST "http://127.0.0.1:9200/zammad_production/User/5" \
I, [2018-12-17T12:28:49.533523 #2755-47290442799460] INFO -- : # 200
I, [2018-12-17T12:28:49.538077 #2755-47290442799460] INFO -- : 2018-12-17T12:28:49+0200: [Worker(host:Zammad pid:2755)] Job BackgroundJobSearchIndex (id=63858) COMPLETED after 0.1108
I, [2018-12-17T12:28:49.544250 #2755-47290442799460] INFO -- : 2018-12-17T12:28:49+0200: [Worker(host:Zammad pid:2755)] Job BackgroundJobSearchIndex (id=63859) RUNNING
I, [2018-12-17T12:28:49.627109 #2755-47290442799460] INFO -- : # curl -X POST "http://127.0.0.1:9200/zammad_production/Organization/2" \
I, [2018-12-17T12:28:49.641772 #2755-47290442799460] INFO -- : # 200
I, [2018-12-17T12:28:49.645937 #2755-47290442799460] INFO -- : 2018-12-17T12:28:49+0200: [Worker(host:Zammad pid:2755)] Job BackgroundJobSearchIndex (id=63859) COMPLETED after 0.1015
I, [2018-12-17T12:28:55.064904 #2755-47290443435800] INFO -- : execute Ticket.process_escalation (try_count 0)...
I, [2018-12-17T12:28:57.728766 #2755-47290442799460] INFO -- : 2018-12-17T12:28:57+0200: [Worker(host:Zammad pid:2755)] Job BackgroundJobSearchIndex (id=63861) RUNNING
I, [2018-12-17T12:28:57.829663 #2755-47290442799460] INFO -- : # curl -X POST "http://127.0.0.1:9200/zammad_production/Ticket/46" \
I, [2018-12-17T12:28:57.960177 #2755-47290442799460] INFO -- : # 201
I, [2018-12-17T12:28:57.968658 #2755-47290442799460] INFO -- : 2018-12-17T12:28:57+0200: [Worker(host:Zammad pid:2755)] Job BackgroundJobSearchIndex (id=63861) COMPLETED after 0.2397
I, [2018-12-17T12:28:57.974093 #2755-47290442799460] INFO -- : 2018-12-17T12:28:57+0200: [Worker(host:Zammad pid:2755)] Job BackgroundJobSearchIndex (id=63862) RUNNING
I, [2018-12-17T12:28:58.076056 #2755-47290442799460] INFO -- : # curl -X POST "http://127.0.0.1:9200/zammad_production/User/5" \
I, [2018-12-17T12:28:58.116585 #2755-47290442799460] INFO -- : # 200
I, [2018-12-17T12:28:58.120147 #2755-47290442799460] INFO -- : 2018-12-17T12:28:58+0200: [Worker(host:Zammad pid:2755)] Job BackgroundJobSearchIndex (id=63862) COMPLETED after 0.1459
I, [2018-12-17T12:28:58.127065 #2755-47290442799460] INFO -- : 2018-12-17T12:28:58+0200: [Worker(host:Zammad pid:2755)] Job BackgroundJobSearchIndex (id=63863) RUNNING
I, [2018-12-17T12:28:58.293062 #2755-47290442799460] INFO -- : # curl -X POST "http://127.0.0.1:9200/zammad_production/Organization/2" \
I, [2018-12-17T12:28:58.313648 #2755-47290442799460] INFO -- : # 200
I, [2018-12-17T12:28:58.317739 #2755-47290442799460] INFO -- : 2018-12-17T12:28:58+0200: [Worker(host:Zammad pid:2755)] Job BackgroundJobSearchIndex (id=63863) COMPLETED after 0.1905
I, [2018-12-17T12:28:58.321273 #2755-47290442799460] INFO -- : 2018-12-17T12:28:58+0200: [Worker(host:Zammad pid:2755)] Job BackgroundJobSearchIndex (id=63868) RUNNING
I, [2018-12-17T12:28:58.405354 #2755-47290442799460] INFO -- : # curl -X POST "http://127.0.0.1:9200/zammad_production/User/5" \
I, [2018-12-17T12:28:58.426291 #2755-47290442799460] INFO -- : # 200
I, [2018-12-17T12:28:58.430362 #2755-47290442799460] INFO -- : 2018-12-17T12:28:58+0200: [Worker(host:Zammad pid:2755)] Job BackgroundJobSearchIndex (id=63868) COMPLETED after 0.1089
I, [2018-12-17T12:28:58.434466 #2755-47290442799460] INFO -- : 2018-12-17T12:28:58+0200: [Worker(host:Zammad pid:2755)] Job BackgroundJobSearchIndex (id=63869) RUNNING
I, [2018-12-17T12:28:58.486103 #2755-47290442799460] INFO -- : # curl -X POST "http://127.0.0.1:9200/zammad_production/Organization/2" \
I, [2018-12-17T12:28:58.499142 #2755-47290442799460] INFO -- : # 200
I, [2018-12-17T12:28:58.505048 #2755-47290442799460] INFO -- : 2018-12-17T12:28:58+0200: [Worker(host:Zammad pid:2755)] Job BackgroundJobSearchIndex (id=63869) COMPLETED after 0.0704
I, [2018-12-17T12:28:59.524276 #2755-70139402579020] INFO -- : execute Channel.fetch (try_count 0)...
I, [2018-12-17T12:29:08.773654 #2755-70139668208660] INFO -- : execute Job.run (try_count 0)...
I, [2018-12-17T12:29:10.017725 #2764-46947288246080] INFO -- : Started POST "/api/v1/tickets" for 127.0.0.1 at 2018-12-17 12:29:10 +0200
I, [2018-12-17T12:29:10.038141 #2764-46947288246080] INFO -- : Processing by TicketsController#create as JSON
I, [2018-12-17T12:29:10.038298 #2764-46947288246080] INFO -- : Parameters: {"title"=>"Ticket Title", "group"=>"Help Desk", "article"=>{"subject"=>"Article Title", "body"=>"Note Body", "type"=>"note", "internal"=>"false", "attachments"=>{"0"=>{"filename"=>"filename.txt", "data"=>"content in base64", "mime-type"=>"text/plain"}}}, "customer"=>"shimons@most.gov.il", "note"=>"some note"}
E, [2018-12-17T12:29:14.162580 #2764-46947288246080] ERROR -- : undefined method `each_with_index' for #<ActionController::Parameters:0x00007f6868dcb8b0> (NoMethodError)
/opt/zammad/app/controllers/concerns/creates_ticket_articles.rb:82:in `article_create'
/opt/zammad/app/controllers/tickets_controller.rb:166:in `block in create'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.6.1/lib/active_record/locking/pessimistic.rb:81:in `block in with_lock'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.6.1/lib/active_record/connection_adapters/abstract/database_statements.rb:235:in `block in transaction'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.6.1/lib/active_record/connection_adapters/abstract/transaction.rb:194:in `block in within_new_transaction'
/opt/zammad/vendor/ruby-2.4.4/lib/ruby/2.4.0/monitor.rb:214:in `mon_synchronize'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.6.1/lib/active_record/connection_adapters/abstract/transaction.rb:191:in `within_new_transaction'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.6.1/lib/active_record/connection_adapters/abstract/database_statements.rb:235:in `transaction'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.6.1/lib/active_record/transactions.rb:210:in `transaction'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.6.1/lib/active_record/transactions.rb:299:in `transaction'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.6.1/lib/active_record/locking/pessimistic.rb:79:in `with_lock'
/opt/zammad/app/controllers/tickets_controller.rb:154:in `create'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.6.1/lib/action_controller/metal/basic_implicit_render.rb:4:in `send_action'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.6.1/lib/abstract_controller/base.rb:186:in `process_action'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.6.1/lib/action_controller/metal/rendering.rb:30:in `process_action'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.6.1/lib/abstract_controller/callbacks.rb:20:in `block in process_action'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.6.1/lib/active_support/callbacks.rb:131:in `run_callbacks'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.6.1/lib/abstract_controller/callbacks.rb:19:in `process_action'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.6.1/lib/action_controller/metal/rescue.rb:20:in `process_action'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.6.1/lib/action_controller/metal/instrumentation.rb:32:in `block in process_action'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.6.1/lib/active_support/notifications.rb:166:in `block in instrument'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.6.1/lib/active_support/notifications/instrumenter.rb:21:in `instrument'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.6.1/lib/active_support/notifications.rb:166:in `instrument'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.6.1/lib/action_controller/metal/instrumentation.rb:30:in `process_action'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.6.1/lib/action_controller/metal/params_wrapper.rb:252:in `process_action'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.6.1/lib/active_record/railties/controller_runtime.rb:22:in `process_action'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.6.1/lib/abstract_controller/base.rb:124:in `process'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/actionview-5.1.6.1/lib/action_view/rendering.rb:30:in `process'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.6.1/lib/action_controller/metal.rb:189:in `dispatch'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.6.1/lib/action_controller/metal.rb:253:in `dispatch'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.6.1/lib/action_dispatch/routing/route_set.rb:49:in `dispatch'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.6.1/lib/action_dispatch/routing/route_set.rb:31:in `serve'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.6.1/lib/action_dispatch/journey/router.rb:50:in `block in serve'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.6.1/lib/action_dispatch/journey/router.rb:33:in `each'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.6.1/lib/action_dispatch/journey/router.rb:33:in `serve'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.6.1/lib/action_dispatch/routing/route_set.rb:844:in `call'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/omniauth-1.7.1/lib/omniauth/strategy.rb:190:in `call!'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/omniauth-1.7.1/lib/omniauth/strategy.rb:168:in `call'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/omniauth-1.7.1/lib/omniauth/builder.rb:63:in `call'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/rack-2.0.6/lib/rack/etag.rb:25:in `call'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/rack-2.0.6/lib/rack/conditional_get.rb:38:in `call'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/rack-2.0.6/lib/rack/head.rb:12:in `call'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/rack-2.0.6/lib/rack/session/abstract/id.rb:232:in `context'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/rack-2.0.6/lib/rack/session/abstract/id.rb:226:in `call'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.6.1/lib/action_dispatch/middleware/cookies.rb:613:in `call'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.6.1/lib/action_dispatch/middleware/callbacks.rb:26:in `block in call'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.6.1/lib/active_support/callbacks.rb:97:in `run_callbacks'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.6.1/lib/action_dispatch/middleware/callbacks.rb:24:in `call'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.6.1/lib/action_dispatch/middleware/debug_exceptions.rb:59:in `call'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.6.1/lib/action_dispatch/middleware/show_exceptions.rb:31:in `call'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/railties-5.1.6.1/lib/rails/rack/logger.rb:36:in `call_app'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/railties-5.1.6.1/lib/rails/rack/logger.rb:24:in `block in call'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.6.1/lib/active_support/tagged_logging.rb:69:in `block in tagged'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.6.1/lib/active_support/tagged_logging.rb:26:in `tagged'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.6.1/lib/active_support/tagged_logging.rb:69:in `tagged'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/railties-5.1.6.1/lib/rails/rack/logger.rb:24:in `call'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.6.1/lib/action_dispatch/middleware/remote_ip.rb:79:in `call'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.6.1/lib/action_dispatch/middleware/request_id.rb:25:in `call'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/rack-2.0.6/lib/rack/method_override.rb:22:in `call'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/rack-2.0.6/lib/rack/runtime.rb:22:in `call'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.6.1/lib/active_support/cache/strategy/local_cache_middleware.rb:27:in `call'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.6.1/lib/action_dispatch/middleware/executor.rb:12:in `call'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.6.1/lib/action_dispatch/middleware/static.rb:125:in `call'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/rack-2.0.6/lib/rack/sendfile.rb:111:in `call'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/railties-5.1.6.1/lib/rails/engine.rb:522:in `call'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/puma-3.11.0/lib/puma/configuration.rb:225:in `call'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/puma-3.11.0/lib/puma/server.rb:624:in `handle_request'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/puma-3.11.0/lib/puma/server.rb:438:in `process_client'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/puma-3.11.0/lib/puma/server.rb:302:in `block in run'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/puma-3.11.0/lib/puma/thread_pool.rb:120:in `block in spawn_thread'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/logging-2.2.2/lib/logging/diagnostic_context.rb:474:in `block in create_with_logging_context'
I, [2018-12-17T12:29:14.240352 #2764-46947288246080] INFO -- : Completed 500 Internal Server Error in 4202ms (Views: 0.4ms | ActiveRecord: 3091.3ms)
I, [2018-12-17T12:29:14.611342 #2755-47290442799460] INFO -- : 2018-12-17T12:29:14+0200: [Worker(host:Zammad pid:2755)] Job Observer::UserDeviceLogJob (id=63887) RUNNING
I, [2018-12-17T12:29:14.920109 #2755-47290442799460] INFO -- : 2018-12-17T12:29:14+0200: [Worker(host:Zammad pid:2755)] Job Observer::UserDeviceLogJob (id=63887) COMPLETED after 0.3086
I, [2018-12-17T12:29:14.926443 #2755-47290442799460] INFO -- : 2018-12-17T12:29:14+0200: [Worker(host:Zammad pid:2755)] Job BackgroundJobSearchIndex (id=62870) RUNNING
I, [2018-12-17T12:29:15.030524 #2755-47290442799460] INFO -- : # curl -X POST "http://127.0.0.1:9200/zammad_production/StatsStore/1" \
I, [2018-12-17T12:29:15.072262 #2755-47290442799460] INFO -- : # 200
I, [2018-12-17T12:29:15.077882 #2755-47290442799460] INFO -- : 2018-12-17T12:29:15+0200: [Worker(host:Zammad pid:2755)] Job BackgroundJobSearchIndex (id=62870) COMPLETED after 0.1511
I, [2018-12-17T12:29:15.114138 #2755-47290442799460] INFO -- : 2018-12-17T12:29:15+0200: [Worker(host:Zammad pid:2755)] Job BackgroundJobSearchIndex (id=62871) RUNNING
I, [2018-12-17T12:29:15.240416 #2755-47290442799460] INFO -- : # curl -X POST "http://127.0.0.1:9200/zammad_production/StatsStore/2" \
I, [2018-12-17T12:29:15.269670 #2755-47290442799460] INFO -- : # 200
I, [2018-12-17T12:29:15.273512 #2755-47290442799460] INFO -- : 2018-12-17T12:29:15+0200: [Worker(host:Zammad pid:2755)] Job BackgroundJobSearchIndex (id=62871) COMPLETED after 0.1592
I, [2018-12-17T12:29:15.277612 #2755-47290442799460] INFO -- : 2018-12-17T12:29:15+0200: [Worker(host:Zammad pid:2755)] Job BackgroundJobSearchIndex (id=62872) RUNNING
I, [2018-12-17T12:29:15.421362 #2755-47290442799460] INFO -- : # curl -X POST "http://127.0.0.1:9200/zammad_production/StatsStore/4" \
I, [2018-12-17T12:29:16.616364 #2755-47290442799460] INFO -- : # 200
I, [2018-12-17T12:29:16.627538 #2755-47290442799460] INFO -- : 2018-12-17T12:29:16+0200: [Worker(host:Zammad pid:2755)] Job BackgroundJobSearchIndex (id=62872) COMPLETED after 1.3497
I, [2018-12-17T12:29:16.631684 #2755-47290442799460] INFO -- : 2018-12-17T12:29:16+0200: [Worker(host:Zammad pid:2755)] Job BackgroundJobSearchIndex (id=63888) RUNNING
I, [2018-12-17T12:29:16.859173 #2755-47290442799460] INFO -- : # curl -X POST "http://127.0.0.1:9200/zammad_production/Ticket/47" \
I, [2018-12-17T12:29:16.893759 #2755-47290442799460] INFO -- : # 201
I, [2018-12-17T12:29:16.897072 #2755-47290442799460] INFO -- : 2018-12-17T12:29:16+0200: [Worker(host:Zammad pid:2755)] Job BackgroundJobSearchIndex (id=63888) COMPLETED after 0.2652
I, [2018-12-17T12:29:16.900844 #2755-47290442799460] INFO -- : 2018-12-17T12:29:16+0200: [Worker(host:Zammad pid:2755)] Job BackgroundJobSearchIndex (id=63889) RUNNING
I, [2018-12-17T12:29:17.009021 #2755-47290442799460] INFO -- : # curl -X POST "http://127.0.0.1:9200/zammad_production/User/5" \
I, [2018-12-17T12:29:17.055278 #2755-47290442799460] INFO -- : # 200
I, [2018-12-17T12:29:17.057481 #2764-46947275981140] INFO -- : Started GET "/api/v1/ticket_customer?customer_id=5&_=1544957250252" for 127.0.0.1 at 2018-12-17 12:29:17 +0200
I, [2018-12-17T12:29:17.060891 #2755-47290442799460] INFO -- : 2018-12-17T12:29:17+0200: [Worker(host:Zammad pid:2755)] Job BackgroundJobSearchIndex (id=63889) COMPLETED after 0.1599
I, [2018-12-17T12:29:17.078944 #2764-46947275028020] INFO -- : Started GET "/api/v1/ticket_customer?customer_id=5&_=1545042413535" for 127.0.0.1 at 2018-12-17 12:29:17 +0200
I, [2018-12-17T12:29:17.083340 #2755-47290442799460] INFO -- : 2018-12-17T12:29:17+0200: [Worker(host:Zammad pid:2755)] Job BackgroundJobSearchIndex (id=63890) RUNNING
I, [2018-12-17T12:29:17.123720 #2764-46947275028020] INFO -- : Processing by TicketsController#ticket_customer as JSON
I, [2018-12-17T12:29:17.124309 #2764-46947275028020] INFO -- : Parameters: {"customer_id"=>"5", "_"=>"1545042413535"}
I, [2018-12-17T12:29:17.212110 #2755-47290442799460] INFO -- : # curl -X POST "http://127.0.0.1:9200/zammad_production/Organization/2" \
I, [2018-12-17T12:29:17.240627 #2764-46947275028020] INFO -- : Completed 200 OK in 116ms (Views: 24.1ms | ActiveRecord: 27.7ms)
I, [2018-12-17T12:29:17.279522 #2755-47290442799460] INFO -- : # 200
I, [2018-12-17T12:29:17.280718 #2764-46947275981140] INFO -- : Processing by TicketsController#ticket_customer as JSON
I, [2018-12-17T12:29:17.280823 #2764-46947275981140] INFO -- : Parameters: {"customer_id"=>"5", "_"=>"1544957250252"}
I, [2018-12-17T12:29:17.301375 #2755-47290442799460] INFO -- : 2018-12-17T12:29:17+0200: [Worker(host:Zammad pid:2755)] Job BackgroundJobSearchIndex (id=63890) COMPLETED after 0.2178
I, [2018-12-17T12:29:17.304936 #2755-47290442799460] INFO -- : 2018-12-17T12:29:17+0200: [Worker(host:Zammad pid:2755)] Job Observer::Ticket::UserTicketCounter::BackgroundJob (id=63891) RUNNING
I, [2018-12-17T12:29:17.899838 #2764-46947275981140] INFO -- : Completed 200 OK in 619ms (Views: 404.7ms | ActiveRecord: 43.7ms)
I, [2018-12-17T12:29:19.349941 #2755-47290442799460] INFO -- : 2018-12-17T12:29:19+0200: [Worker(host:Zammad pid:2755)] Job Observer::Ticket::UserTicketCounter::BackgroundJob (id=63891) COMPLETED after 2.0448
I, [2018-12-17T12:29:19.356154 #2755-47290442799460] INFO -- : 2018-12-17T12:29:19+0200: [Worker(host:Zammad pid:2755)] Job BackgroundJobSearchIndex (id=63895) RUNNING
I, [2018-12-17T12:29:19.691080 #2755-47290442799460] INFO -- : # curl -X POST "http://127.0.0.1:9200/zammad_production/User/5" \
I, [2018-12-17T12:29:19.780488 #2755-47290442799460] INFO -- : # 200
I, [2018-12-17T12:29:19.802278 #2755-47290442799460] INFO -- : 2018-12-17T12:29:19+0200: [Worker(host:Zammad pid:2755)] Job BackgroundJobSearchIndex (id=63895) COMPLETED after 0.4458
I, [2018-12-17T12:29:19.806695 #2755-47290442799460] INFO -- : 2018-12-17T12:29:19+0200: [Worker(host:Zammad pid:2755)] Job BackgroundJobSearchIndex (id=63896) RUNNING
I, [2018-12-17T12:29:20.078013 #2755-47290442799460] INFO -- : # curl -X POST "http://127.0.0.1:9200/zammad_production/Organization/2" \
I, [2018-12-17T12:29:20.109922 #2755-47290442799460] INFO -- : # 200
I, [2018-12-17T12:29:20.124801 #2755-47290442799460] INFO -- : 2018-12-17T12:29:20+0200: [Worker(host:Zammad pid:2755)] Job BackgroundJobSearchIndex (id=63896) COMPLETED after 0.3151
I, [2018-12-17T12:29:20.536645 #2764-46947284693060] INFO -- : Started GET "/api/v1/users/5?full=true&_=1545042413536" for 127.0.0.1 at 2018-12-17 12:29:20 +0200
I, [2018-12-17T12:29:20.542303 #2764-46947284275420] INFO -- : Started GET "/api/v1/organizations/2?full=true&_=1545042413537" for 127.0.0.1 at 2018-12-17 12:29:20 +0200
I, [2018-12-17T12:29:20.555957 #2764-46947284275420] INFO -- : Processing by OrganizationsController#show as JSON
I, [2018-12-17T12:29:20.556088 #2764-46947284275420] INFO -- : Parameters: {"full"=>"true", "_"=>"1545042413537", "id"=>"2"}
I, [2018-12-17T12:29:20.577118 #2764-46947288246080] INFO -- : Started GET "/api/v1/ticket_customer?customer_id=5&_=1545042413538" for 127.0.0.1 at 2018-12-17 12:29:20 +0200
I, [2018-12-17T12:29:20.591962 #2764-46947288246080] INFO -- : Processing by TicketsController#ticket_customer as JSON
I, [2018-12-17T12:29:20.592150 #2764-46947288246080] INFO -- : Parameters: {"customer_id"=>"5", "_"=>"1545042413538"}
I, [2018-12-17T12:29:21.325787 #2764-46947284275420] INFO -- : Completed 200 OK in 769ms (Views: 58.5ms | ActiveRecord: 554.7ms)
I, [2018-12-17T12:29:21.388606 #2764-46947284693060] INFO -- : Processing by UsersController#show as JSON
I, [2018-12-17T12:29:21.404918 #2764-46947284693060] INFO -- : Parameters: {"full"=>"true", "_"=>"1545042413536", "id"=>"5"}
I, [2018-12-17T12:29:21.910717 #2764-46947288246080] INFO -- : Execute trigger (auto reply (on new tickets)/1) for this object (Ticket:47/Loop:1)
I, [2018-12-17T12:29:21.915285 #2764-46947284693060] INFO -- : Completed 200 OK in 510ms (Views: 12.3ms | ActiveRecord: 59.8ms)
I, [2018-12-17T12:29:22.263614 #2764-46947288246080] INFO -- : Unable to send trigger based notification to shimons@most.gov.il because no email address is set for group 'Help Desk'
I, [2018-12-17T12:29:22.290573 #2764-46947288246080] INFO -- : Completed 200 OK in 1698ms (Views: 54.6ms | ActiveRecord: 754.1ms)
I, [2018-12-17T12:29:24.176440 #2755-47290442799460] INFO -- : 2018-12-17T12:29:24+0200: [Worker(host:Zammad pid:2755)] Job Transaction::BackgroundJob (id=63897) RUNNING
I, [2018-12-17T12:29:25.521991 #2755-47290442799460] INFO -- : Send notification to: gideonn@most.gov.il (from:Notification Master <noreply@zammad.most.local>/subject:New Ticket (Ticket Title) [# ׳§׳¨׳™׳׳”27046])
I, [2018-12-17T12:29:26.277249 #2755-47290442799460] INFO -- : Send notification to: shimons@most.gov.il (from:Notification Master <noreply@zammad.most.local>/subject:New Ticket (Ticket Title) [# ׳§׳¨׳™׳׳”27046])
I, [2018-12-17T12:29:26.897340 #2755-47290442799460] INFO -- : 2018-12-17T12:29:26+0200: [Worker(host:Zammad pid:2755)] Job Transaction::BackgroundJob (id=63897) COMPLETED after 2.7206
I, [2018-12-17T12:29:28.550684 #2764-46947275028020] INFO -- : Started GET "/api/v1/online_notifications/?full=true&_=1545042413539" for 127.0.0.1 at 2018-12-17 12:29:28 +0200
I, [2018-12-17T12:29:28.567327 #2764-46947275028020] INFO -- : Processing by OnlineNotificationsController#index as JSON
I, [2018-12-17T12:29:28.567523 #2764-46947275028020] INFO -- : Parameters: {"full"=>"true", "_"=>"1545042413539"}
I, [2018-12-17T12:29:28.869127 #2764-46947275028020] INFO -- : Completed 200 OK in 301ms (Views: 146.4ms | ActiveRecord: 21.7ms)
I, [2018-12-17T12:29:29.549046 #2755-70139402579020] INFO -- : execute Channel.fetch (try_count 0)...
I, [2018-12-17T12:29:31.217210 #2755-47290412035920] INFO -- : Scheduler running...
I, [2018-12-17T12:29:31.228275 #2755-47290412035920] INFO -- : Running job thread for 'Check streams for Channel' (Channel.stream) status is: sleep
I, [2018-12-17T12:29:31.228451 #2755-47290412035920] INFO -- : Running job thread for 'Check Channels' (Channel.fetch) status is: sleep
I, [2018-12-17T12:29:31.228567 #2755-47290412035920] INFO -- : Running job thread for 'Import OTRS diff load' (Import::OTRS.diff_worker) status is: sleep
I, [2018-12-17T12:29:31.229043 #2755-47290412035920] INFO -- : Running job thread for 'Generate Session data' (Sessions.jobs) status is: sleep
I, [2018-12-17T12:29:31.229304 #2755-47290412035920] INFO -- : Running job thread for 'Process escalation tickets' (Ticket.process_escalation) status is: sleep
I, [2018-12-17T12:29:31.231099 #2755-47290412035920] INFO -- : Running job thread for 'Execute jobs' (Job.run) status is: sleep
I, [2018-12-17T12:29:55.018103 #2755-47290442799460] INFO -- : 2018-12-17T12:29:55+0200: [Worker(host:Zammad pid:2755)] Job BackgroundJobSearchIndex (id=63871) RUNNING
I, [2018-12-17T12:29:55.094413 #2755-47290442799460] INFO -- : # curl -X POST "http://127.0.0.1:9200/zammad_production/StatsStore/1" \
