Creating a field
Hi
I would like to add an empty field to make a note in the right column in this section. Kind of near where I have it highlighted.
Would I do that in the “Objects” menu settings and under “Ticket”? Then I would need to do a system restart?
Also in the object menu what does it mean by “position”
The documentation has you covered:
https://admin-docs.zammad.org/en/latest/system/objects.html
Looks like that was it, thanks
Is the full system restart option within the dashboard? Or is that something an admin has to do?
Hi!
The full restart option has to be set by the admin
This post explains it fairly well
Ok thanks for the reply
