Create/Edit new code features on Package Installed source code
  • Used Zammad version: 4.1
  • Operating system: Debian
  • Browser + version: Opera
  • Write/Edit code from source
  • Could not implement the code changes
  • Edited the login file (changed the login button text) on /opt/zammad/app/assets/javascripts/app/views/login.jst.eco
  • Try to run the systemctl restart zammd but didn´t work
When you are on Zammad 4.1, before you try anything else, please update your system. The version is more than two years old.
When you want to do any code changes, you can check: Packages Tutorial - #12 by rolfschmidt
But keep in mind, that any code change can be broken after every update.
if you run in production mode then you will need to precompile assets after js changes as well.
root> zammad run rake assets:precompile
root> systemctl restart zammad
