I have installed Zammad from source and using Apache as a web server, I followed the documentation on setting up Apache configuration. I am using localhost and haven’t set FQDN for now. After setting up a web server, I opened the Firefox browser and entered localhost to start Zammad’s first configuration.
It shows loading word but nothing came up, when I checked the browser log I found this:
Status
403
Forbidden
VersionHTTP/1.1
Transferred399 B (199 B size)
Referrer Policystrict-origin-when-cross-origin
DNS ResolutionSystem
Since I installed it from the source, it is difficult to show the steps. But here is my zammad.conf file content
# this is the apache config for zammad
ServerTokens Prod
ServerName localhost
<VirtualHost *:80>
## don't loose time with IP address lookups
HostnameLookups Off
## needed for named virtual hosts
UseCanonicalName Off
## configures the footer on server-generated documents
ServerSignature Off
ProxyRequests Off
ProxyPreserveHost On
<Proxy 127.0.0.1:3002>
Require local
</Proxy>
ProxyPass /assets !
ProxyPass /favicon.ico !
ProxyPass /apple-touch-icon.png !
ProxyPass /robots.txt !
# legacy web socket server
ProxyPass /ws ws://127.0.0.1:6042/
# action cable
ProxyPass /cable ws://127.0.0.1:3002/cable
ProxyPass / http://127.0.0.1:3002/
RequestHeader unset X-Forwarded-User
DocumentRoot "/opt/zammad/public"
<Directory />
Options FollowSymLinks
AllowOverride None
</Directory>
<Directory "/opt/zammad/public">
Require all granted
</Directory>
</VirtualHost>
I thought the zammad is accessible on port 80, and I set ServerName to localhost. Therefore when I enter localhost on the browser it should load Zammad not with the proxy port, that’s what confusing me. Apache by default is listening on port 80 therefore Zammad should be accessible with localhost on browser
If you have more than one application on the host that runs Zammad and apache, then using mere localhost is not enough. You potentially are viewing a different localhost as you’re expecting.
This is something you have to figure out and we can’t help with.
@MrGeneration I think I haven’t explained my question clearly.
In general, I want to access Zammad in port 80 which is the default port for which Apache listens to. But in my case I am accessing it on the port I set manually on Proxy. If that is how it works fine, I just didn’t understand the Proxy (URL, PORT). In conclusion, Zammad will be accessed in Proxy URL and PORT instead of on default HTTP (80) OR HTTPS(443). Correct me if I am wrong.
I haven’t read this one I think that’s why I was confused.
Want to test locally first or use a different Proxy we don’t support? The main application (rails server) is listening on http://127.0.0.1:3000.
If you’re using a proxy server, also ensure that you proxy the websockets as well. The websocket server listens on ws://127.0.0.1:6042.
