Correct configuration on trigger tickets
  • Used Zammad version: 5.0.x
  • Browser + version: Chrome
Cuando en el ticket el agente fue el último en responder y transcurren 2 dias, sin respuesta, el ticket debe de cerrarse.
I’m trying to create a trigger to close some tickets, when in the ticket the agent was the last to respond and 2 days elapse, with no response, the ticket must be closed, in the image below it is only 2 minutes while we do tests, but also this did not work. If you have a correct configuration, I will grateful for your help.
Always it’s happening
Hey @JDRodriguez ,
triggers only run when a ticket gets updated:
https://admin-docs.zammad.org/en/latest/manage/trigger.html
You even specified in your trigger that the tickets needs to get updated while trying to achive:
So if you really want to close a ticket “after time x has passed” with no interaction whatsoever you’re probably better off with a scheduler:
https://admin-docs.zammad.org/en/latest/manage/scheduler.html
Be careful with your goal though. Currently a customer could reply all he wants but couldn’t prevent the ticket from being closed.
cheers
