Used Zammad version: 4.0
Operating system: Client: Android / IOS
Browser + version: Chrome, Safari
Actual / Expected behavior:
In the Overviews there are a several columns with fixed width. In the mobile view you just see dots and cant adjust the column-width so you can read the e.g. title. Is there a trick/way to adjust it.
No there isn’t.
This is done by application logic or CSS (depends on the part) and thus is a “root” issue.
However, on mobile devices you usually can’t extend such columns on mobile sites.
At least I don’t know a way to do it.
Suggestion for overviews would be to reduce the columns you display for better overview.
system
Closed
October 15, 2021, 5:28pm
3
