CLOSED: Question about {ticket.number} and {ticket.id}
  • Used Zammad version: 6.5.2-1767354399.5ee205d5.noble
  • Operating system: Ubuntu 24.04.3 LTS
  • Browser + version: different
Hello everyone,
I’ve just noticed on my Zammad test system that {ticket.number} has recently started to differ from {ticket.id}. Since I’m ‘testing’ here, it’s possible that I’ve broken something.
So my question is: Is this normal, or should the numbers be synchronised? What could be the reason that they are no longer synchronised? Can this be fixed, and should it be fixed?
Many thanks,
Regards, H-BLOGX
Ticket number != Ticket id. Afaik the ticket id is the internal database identifier. Both are not synced. As i remember, the ticket number contains a prefix (if set) and you can set a checksum at the end of the ticket number.
Hey @H-BLOGX ,
thanks for reaching out to clarify this misunderstanding.
You’re all good. As @richie_77 already explained (thanks)
To elaborate a little more, for you to get a full clear picture. Zammad distinguish in general 2 types of ticket identifier.
  • The business identifier = ticket number (or in colloquial terms: the ticket hook, see Admin Docu → Ticket) is used by agents, and customers to refer to the same ticket.
  • The technical identifier = ticket id is used in the direct link …/zoom/ticket.id to open the ticket in the browser. Plus in case you want to modify Zammad, use webhooks, the API, or contribute code-wise, you’ll need that id to change, update, whatever apply changes to that ticket.
Simple example is a domain such as www.google.de (“business identifier” for us to use in browser) which will resolve in an IP address xxx.xxx.xxx.xxx (“technical identifier” for programmers to maintain the routing).
Best regards and a great weekend
De Long
hello Dr4gon,
thank you for the explanation. now i known, what it means
kind regards H-BLOGX
