For Clarfification: What can and can’t do the customer_id: guess if used in a Create post?
From the docu im not sure: what happens if I use
“customer_id”: “guess:NonRegisteredUser@example”
Will the user be created if there is no match to the Mail adress and then be owner of the Ticket - what is with the User Name? What if the User isn’t created? is it case sensitive ?
Kind regards
Noah
Edit: Since im a ‚new User‘ and can’t post a pic or Link, the Box i refer is found under Rest API → Ticket endpoints → Create
