Hey there,
I’m currently trying to connect my checkmk instance to my zammad instance, but for mails it doesn’t work cause the resolving mails are not matched with existing tickets. So if host A goes down it creates one ticket and if host A goes up again it creates another ticket.
I guess it’s the same error like this github issue:
opened 10:57AM - 28 Nov 18 UTC
bug
verified
integration
prioritised by payment
### Infos:
* Used Zammad version: 2.7.x
* Installation method (source, packa… ge, ..): n/a
* Operating system: n/a
* Database + version: n/a
* Elasticsearch version: n/a
* Browser + version: n/a
* Ticket-ID: #1031272
### Expected behavior:
* When sending a E-Mail about Service problems regarding the same system, Zammad will append a new article to the same ticket, if the state of the host changes (e.g. State changes back to "OK") or further information are send by check_mk.
Nagios does work the same way.
### Actual behavior:
* Zammad opens a new ticket on each E-Mail check_mk sends, no matter if it's about the same host. It will also not close resolved issue tickets as result of that.
* Configure check_mk
* change a state of a host to anything other than OK (e.g. Critical) and wait for check_mk to send the E-Mail
* After the E-Mail has been received by Zammad, re check the service state (which will cause a self heal and E-Mail with State "OK")
=> Zammad will not append the article to the same ticket.
As this works in Nagios and our Integration page clearly says "[...] by API or E-Mail [...]" I think this is a bug or should at least get improvement
Are there any updates on that bug? The issue has been open for a relatively long time.
Mails are preferred cause I can see graphs etc. in the ticket without feeling the need to login to checkmk itself.
Thanks in advance!
No news. I unlocked it, feel free to bump it to wakey wakey our devs.
Thanks! Will definitely do that.
system
Closed
March 25, 2025, 3:10pm
4
