Important:
- Used Zammad version: zammad-2.5.0-1529668954.708c86ba.centos7.x86_64
- Used Zammad installation source: (source, package, …) repo
- Operating system: CentOS Linux release 7.5.1804 (Core)
- Browser + version: Google Chrome 67.0.3396.87
- not getting a 500 when visiting the Check_MK integration page (usually I see the latest calls to debug them)
- getting a 500 errror
I, [2018-06-27T07:58:04.020106 #1307] INFO -- : Started GET "/api/v1/http_logs/check_mk?limit=50&_=1529941048387" for 185.121.33.41 at 2018-06-27 07:58:04 +0000
I, [2018-06-27T07:58:04.025242 #1307] INFO -- : Processing by HttpLogsController#index as JSON
I, [2018-06-27T07:58:04.025331 #1307] INFO -- : Parameters: {"limit"=>"50", "_"=>"1529941048387", "facility"=>"check_mk"}
E, [2018-06-27T07:58:04.089893 #1307] ERROR -- : "\xC3" from ASCII-8BIT to UTF-8 (Encoding::UndefinedConversionError)
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.5/lib/active_support/core_ext/object/json.rb:36:in `encode'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.5/lib/active_support/core_ext/object/json.rb:36:in `to_json'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.5/lib/active_support/json/encoding.rb:55:in `to_json'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/json-2.1.0/lib/json/common.rb:224:in `generate'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.5/lib/active_support/json/encoding.rb:100:in `stringify'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.5/lib/active_support/json/encoding.rb:33:in `encode'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.5/lib/active_support/json/encoding.rb:20:in `encode'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.5/lib/active_support/core_ext/object/json.rb:39:in `to_json'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.5/lib/action_controller/metal/renderers.rb:156:in `block in <module:Renderers>'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.5/lib/action_controller/metal/renderers.rb:149:in `block in _render_to_body_with_renderer'
/opt/zammad/vendor/ruby-2.4.4/lib/ruby/2.4.0/set.rb:324:in `each_key'
/opt/zammad/vendor/ruby-2.4.4/lib/ruby/2.4.0/set.rb:324:in `each'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.5/lib/action_controller/metal/renderers.rb:145:in `_render_to_body_with_renderer'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.5/lib/action_controller/metal/renderers.rb:141:in `render_to_body'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.5/lib/abstract_controller/rendering.rb:24:in `render'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.5/lib/action_controller/metal/rendering.rb:36:in `render'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.5/lib/action_controller/metal/instrumentation.rb:44:in `block (2 levels) in render'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.5/lib/active_support/core_ext/benchmark.rb:12:in `block in ms'
/opt/zammad/vendor/ruby-2.4.4/lib/ruby/2.4.0/benchmark.rb:308:in `realtime'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.5/lib/active_support/core_ext/benchmark.rb:12:in `ms'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.5/lib/action_controller/metal/instrumentation.rb:44:in `block in render'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.5/lib/action_controller/metal/instrumentation.rb:87:in `cleanup_view_runtime'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.5/lib/active_record/railties/controller_runtime.rb:29:in `cleanup_view_runtime'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.5/lib/action_controller/metal/instrumentation.rb:43:in `render'
/opt/zammad/app/controllers/application_controller/renders_models.rb:152:in `model_index_render_result'
/opt/zammad/app/controllers/http_logs_controller.rb:14:in `index'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.5/lib/action_controller/metal/basic_implicit_render.rb:4:in `send_action'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.5/lib/abstract_controller/base.rb:186:in `process_action'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.5/lib/action_controller/metal/rendering.rb:30:in `process_action'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.5/lib/abstract_controller/callbacks.rb:20:in `block in process_action'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.5/lib/active_support/callbacks.rb:131:in `run_callbacks'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.5/lib/abstract_controller/callbacks.rb:19:in `process_action'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.5/lib/action_controller/metal/rescue.rb:20:in `process_action'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.5/lib/action_controller/metal/instrumentation.rb:32:in `block in process_action'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.5/lib/active_support/notifications.rb:166:in `block in instrument'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.5/lib/active_support/notifications/instrumenter.rb:21:in `instrument'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.5/lib/active_support/notifications.rb:166:in `instrument'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.5/lib/action_controller/metal/instrumentation.rb:30:in `process_action'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.5/lib/action_controller/metal/params_wrapper.rb:252:in `process_action'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.5/lib/active_record/railties/controller_runtime.rb:22:in `process_action'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.5/lib/abstract_controller/base.rb:124:in `process'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/actionview-5.1.5/lib/action_view/rendering.rb:30:in `process'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.5/lib/action_controller/metal.rb:189:in `dispatch'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.5/lib/action_controller/metal.rb:253:in `dispatch'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.5/lib/action_dispatch/routing/route_set.rb:49:in `dispatch'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.5/lib/action_dispatch/routing/route_set.rb:31:in `serve'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.5/lib/action_dispatch/journey/router.rb:50:in `block in serve'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.5/lib/action_dispatch/journey/router.rb:33:in `each'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.5/lib/action_dispatch/journey/router.rb:33:in `serve'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.5/lib/action_dispatch/routing/route_set.rb:844:in `call'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/omniauth-1.7.1/lib/omniauth/strategy.rb:190:in `call!'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/omniauth-1.7.1/lib/omniauth/strategy.rb:168:in `call'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/omniauth-1.7.1/lib/omniauth/builder.rb:63:in `call'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/rack-2.0.5/lib/rack/etag.rb:25:in `call'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/rack-2.0.5/lib/rack/conditional_get.rb:25:in `call'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/rack-2.0.5/lib/rack/head.rb:12:in `call'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/rack-2.0.5/lib/rack/session/abstract/id.rb:232:in `context'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/rack-2.0.5/lib/rack/session/abstract/id.rb:226:in `call'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.5/lib/action_dispatch/middleware/cookies.rb:613:in `call'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.5/lib/action_dispatch/middleware/callbacks.rb:26:in `block in call'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.5/lib/active_support/callbacks.rb:97:in `run_callbacks'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.5/lib/action_dispatch/middleware/callbacks.rb:24:in `call'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.5/lib/action_dispatch/middleware/debug_exceptions.rb:59:in `call'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.5/lib/action_dispatch/middleware/show_exceptions.rb:31:in `call'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/railties-5.1.5/lib/rails/rack/logger.rb:36:in `call_app'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/railties-5.1.5/lib/rails/rack/logger.rb:24:in `block in call'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.5/lib/active_support/tagged_logging.rb:69:in `block in tagged'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.5/lib/active_support/tagged_logging.rb:26:in `tagged'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.5/lib/active_support/tagged_logging.rb:69:in `tagged'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/railties-5.1.5/lib/rails/rack/logger.rb:24:in `call'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.5/lib/action_dispatch/middleware/remote_ip.rb:79:in `call'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.5/lib/action_dispatch/middleware/request_id.rb:25:in `call'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/rack-2.0.5/lib/rack/method_override.rb:22:in `call'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/rack-2.0.5/lib/rack/runtime.rb:22:in `call'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.5/lib/active_support/cache/strategy/local_cache_middleware.rb:27:in `call'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.5/lib/action_dispatch/middleware/executor.rb:12:in `call'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.5/lib/action_dispatch/middleware/static.rb:125:in `call'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/rack-2.0.5/lib/rack/sendfile.rb:111:in `call'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/railties-5.1.5/lib/rails/engine.rb:522:in `call'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/puma-3.11.0/lib/puma/configuration.rb:225:in `call'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/puma-3.11.0/lib/puma/server.rb:624:in `handle_request'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/puma-3.11.0/lib/puma/server.rb:438:in `process_client'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/puma-3.11.0/lib/puma/server.rb:302:in `block in run'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/puma-3.11.0/lib/puma/thread_pool.rb:120:in `block in spawn_thread'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/logging-2.2.2/lib/logging/diagnostic_context.rb:474:in `block in create_with_logging_context'
I, [2018-06-27T07:58:04.090690 #1307] INFO -- : Completed 500 Internal Server Error in 65ms (Views: 0.2ms | ActiveRecord: 3.5ms)
- Enable Check_MK integration, configure check_mk to send alerts via custom script, update from 2.4.0 to 2.5.0
I don’t know if this was introduced by the update or if just broke at a certain point, used to work when set up… Now I wanted to investigate on how to handle HOST_STATUS along the already working SERVICE_STATUS notifications… I went to the integration page to check the contents of the API calls but got the error.
