hungnh
October 31, 2018, 9:20am
1
Important:
Chat window appear on website
No chat window appear due to conflict jquery
My website is: https://demo.newtel.com.vn
It use jquery1.12.4 for a lot of plugin
When i add zammad chat, the chat window won’t appear
When i add zammad chat (included the jquery 2.1.4), the chat window appear but all my plugin won’t appear its content
Do you know how to solve it?
Thank you very much
Hannes
October 31, 2018, 12:34pm
2
I would suggest you try the solution from this post here:
How to use multiple versions of jQuery on the same page - Yes, you can use multiple versions of jQuery on the same page. To avoid any kind of conflict, use the jQuery.noConflict() method. jQuery.noConflict() method allows you to use multiple...
regards
hungnh
November 1, 2018, 2:15am
3
I’ve used it. Yes it isn’t conflict anymore, but jquery i wrapped is not working too.
Anyway, I updated the old jquery to version 2.1.4 (like in zammad chat) and it works fine now.
Thank you for your help.
Best Regards
The lovely @mrflix is working on a non-jQuery implementation But I don’t know the current state of it. Maybe he can help?
mrflix
November 2, 2018, 1:56pm
5
Sounds like upgrading the old jquery of the website fixed the issue?
Regarding the jQuery-free version of chat.js – its in a testing phase.
system
Closed
March 2, 2019, 1:57pm
6
